Topic: Replacement for AVR libc ATOMIC_BLOCK macros, now for DUE and other platforms. (Read 14826 times) previous topic - next topic
pYro_65
[UPDATED V1.2.1b]
Hi all,
I have been working on a project that requires safety from interrupts so I did a bit of research, and found the ATOMIC_BLOCK macros.
They seem to be widely accepted as an easy way of controlling the global interrupt flag. After using it for a while I decided I'm not to keen on the syntax created from using the macros, my main reason is it looks like a function definition nested inside another function, which is not allowed in c++. Also, I have a need for some objects to be able to automatically control their atomic operations, I needed a more user friendly approach.
The idea I have come up with is quite simple. All you have to do is declare a variable of the class of blocking operation you want. The class has no callable methods. It works purely on side effects. The atomic operation lasts for the lifetime of the variable, therefore you can return from a function and still expect the global interrupt flag to be restored. This removes the need to use a temporary to store the value while the interrupt flag is restored before return.
Here is a comparison breakdown.
ATOMIC_BLOCK macros
Blocking type.
  • ATOMIC_BLOCK
  • NONATOMIC_BLOCK
Blocking mode.
  • ATOMIC_RESTORESTATE
  • NONATOMIC_RESTORESTATE
  • ATOMIC_FORCEON
  • NONATOMIC_FORCEOFF
New method. (V1.1)
Blocking type.
  • AtomicBlock
  • NonAtomicBlock
Blocking mode.
  • Atomic_RestoreState
  • Atomic_Force
Extensions for inline atomic blocks.
  • Protect function
V1.2 Now supports:
AVR 8-bit processors
  • Arduino 8-bit family ( Compiled / Tested )
  • Teensy 2.0 ( Not Compiled / Not Tested )
  • Teensy++ 2.0 ( Not Compiled / Not Tested )
ARM Cortex-M3
  • Arduino DUE ( Compiled / Not Tested )
  • Olimex STM32 / Leaflabs Maple. ( Compiled / Not Tested )
ARM Cortex-M4
  • Teensy 3.0 ( Compiled / Not Tested )
I have also extended the functionality with a safe mode ( v1.0) . ATOMIC_BLOCK( ATOMIC_RESTORESTATE ) simply writes an old copy of the status register into SREG. With the safe mode, only the global interrupt bit is touched. This can be used by adding a 'Safe' suffix to the blocking type, or passing  '_Safe' with the blocking mode.
There are 12 blocking variations, 8 of which are unique. A complete breakdown of the library is at the top of the file provided ( AtomicBlock.h ). Without safe mode on ( safe mode has no effect when using blocking mode 'Atomic_Force' ) the library will emulate ATOMIC_BLOCK functionality with no extra overhead.
Here is a short example of how to use the library with variable declarations.
#include "AtomicBlock.h"
void setup() { return; }
//New method
 AtomicBlock< Atomic_RestoreState > a_Block;
   NonAtomicBlock< Atomic_Force > a_NoBlock;
 return;
//Old method ( macros )
 ATOMIC_BLOCK( ATOMIC_RESTORESTATE ){
   NONATOMIC_BLOCK( NONATOMIC_FORCEOFF ){
 return;
The 'Protect' function usage.
Each blocking type contains a function named 'Protect'. It can be used to
protect any kind of element.
E.g.
   - Typedefs make using 'Protect' easier.
      typedef AtomicBlock< Atomic_Force > MyBlock;
      For the sake of these examples 'i' is an 'int', and inc is the funciton below.
void inc( int &i_Val ) { ++i_Val; }
   - Protected writes.
MyBlock::Protect( i ) = analogRead( A0 );
   - Protected reads.
Serial.println( MyBlock::Protect( i ) );
   - Protected non-member function calls.
MyBlock::Protect( inc )( i );
   - Protected pointers.
*( &MyBlock::Protect( i ) ) = 77;
(*MyBlock::Protect( &i ))++;
   - No unnessecary instructions.
   - This will not produce any code.
MyBlock::Protect( 1 + 2 + 3 + 4 + 5 );
   - These two lines produce exactly the same code.
digitalWrite( MyBlock::Protect( 13 ), digitalRead( MyBlock::Protect( 13 ) ) ^ 1 );
digitalWrite( 13, digitalRead( 13 ) ^ 1 );
      - This will only turn interrupts on and off once.
MyBlock::Protect( MyBlock::Protect( MyBlock::Protect( MyBlock::Protect( i ) ) ) );
CAUTION: 'Protect' will only protect one element. Statements as arguments are not going to work as you may expect.
   E.g.
      - Wrong use. (argument statement will not be blocked. If you use the result, it will be inside the atomic block.)
MyBlock::Protect( PORTK |= _BV( 5 ) );
      - Correct usage. (just 'Protect' PORTK)
MyBlock::Protect( PORTK ) |= _BV( 5 );
LIMITATIONS:
   * I have chosen not to support any sort of member function protection. Once I have validated the current system
   I can look further into it. The required interface seems to generalise the type system too much and breaks some
   existing functionality as the compiler cannot disambiguate the control paths.
If you aren't logged in you can also download the code from 'google code' here.
I'm after any feedback/ideas for improvment.
Cheers,
Chris.
The files listed in this post are:
  • AtomicBlock.h This file is the original AVR stable version.
  • AtomicBlock_121b.h This file is the new multi-platform (beta) version.
Forum Mod anyone?
https://arduino.land/Moduino/
westfw
[the old syntax] looks like a function definition nested inside another function
I dunno.  It looks like a pretty common macro structure to me; see the recent RunEvery macro, for instance.  ( http://arduino.cc/forum/index.php/topic,124974.0.html )  I've seen a lot of this sort of macro in major C programs (in some ways, it adds object-oriented behavior to C):
FOR_ALL_INTERFACES(idb) {
  FOR_ALL_PACKETS_IN_Q(idb->ipQ) {
    // Blah blah blah.
Your new syntax isn't valid in C code...
And the old form is avr-libc "standard", extending well beyond Arduino.
pYro_65
#2
Oct 02, 2012, 02:50 am Last Edit: Oct 02, 2012, 02:59 am by pYro_65 Reason: 1
It is C++, not C macros.
And it does not use any gcc specific attributes making it far more portable.
From avr-libc for the ATOMIC_BLOCK macros.
Note:
The macros in this header file require the ISO/IEC 9899:1999 ("ISO C99") feature of for loop variables that are declared inside the for loop itself. For that reason, this header file can only be used if the standard level of the compiler (option --std=) is set to either c99 or gnu99.
Forum Mod anyone?
WizenedEE
Note:
Along with this whole thing which is certainly not standard:
#define ATOMIC_RESTORESTATE uint8_t sreg_save \
__attribute__((__cleanup__(__iRestore))) = SREG
Coding Badly
            // protected code goes here
            // destructor has to be called here or very bad things happen
You rely on the fact that the descructor is called precisely at the end of scope.  What happens if the optimizer realizes a_NoBlock is not used and invokes the destructor early?
pYro_65
#5
Oct 02, 2012, 04:22 am Last Edit: Oct 02, 2012, 04:24 am by pYro_65 Reason: 1
The fact that it has side effects cause it to work correctly.
If a class only modifies its internal data, it has no side effects and the compiler can optimise it away.
However this class ( or group of classes ) write to external data during destruction, the status register/SREG. More importantly, it reads from an external source marked as volatile ( SREG ) during construction so the compiler is forced to omit instructions.
Forum Mod anyone?
Coding Badly
I suspect you misunderstood the question.  But it doesn't matter.  The C++ standard states the destructor has to be called and the end of the block.
pYro_65
Yes I didn't quite answer your question, but I'm hoping that I haven't assumed anything with my design. The ATOMIC_BLOCK macros state they cover all exit paths and hopefully this is the same. Please anyone let me know if you think something is not as it should be.
Forum Mod anyone?
pico
I'll try out your new approach by replacing some of the ATOMIC_BLOCK macros I'm currently using a number of programs. I also recently ported the ATOMIC_BLOCK macros over to G++ for an ARM Cortex3 architecture (Leaflabs Maple board) for my own use -- I'll try to port your approach as well to test portability.
I also agree it would be nice for portability to get an implementation that doesn't rely on a relatively exotic feature of the Gnu compilers.
Also, since the original ATOMIC_BLOCK macros are actually based on a "for" loop under the hood to specify the code block, it would be theoretically possible to inadvertantly place a "break" or "continue" statement in such a block, and the compiler would not pick it up as out of place. Not a biggie in practice, but a bug yours doesn't suffer from.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
pYro_65
Cool, if you replace existing ATOMIC_BLOCK macros with my version and you aren't using the safe mode, the compiled size should be the same.
Let me know how it turns out. :)
Forum Mod anyone?
WizenedEE
Actually no. The macros don't use the third part of a for loop, which runs at the end of the oop but can be "break"d, but rather a gcc attribute that says to run this piece of code when this variable is destructed.
Also C++ doesn't support longjmp --- destructors aren't called. I'm pretty sure this wouldn't work (please note I have never used setjmp and am not bothering to look up the syntax ;)
  pinMode(13, OUTPUT);
  if (setjmp()) {
    digitalWrite(13, HIGH);
  else {
    AtomicBlock<Atomic_Force> a;
    longjmp();
  // Interrupts disabled
pYro_65
#11
Oct 03, 2012, 03:56 am Last Edit: Oct 03, 2012, 03:59 am by pYro_65 Reason: 1
Good find, I haven't really read about those functions myself.
But, no that wouldn't work, I don't think ATOMIC_BLOCK would either if you did a 'longjmp' in its scope.
I think this case is fairly well covered as the standard states it completely subverts stack unwinding, and requires 'setjmp' to be set, and is the clients explicit choice. If the user doesn't read documentation on longjmp and mistakes it for an asm jump for example, they have more to worry about than ISR safe code.
It also appears exception handling is the C++ way of "long distance transfer of flow control", which doesn't bypass the C++ stack unwinding semantics.
I'd imagine using it would be quite destructive to a C++ program on a micro controller.
Forum Mod anyone?
Coding Badly
The only caveat (as far as I can tell) is placement.  Constructors are called in order and destructors in reverse order.  If a different class constructor (or destructor) has to be protected, yours has to be first in the block...
  SuperHardwareThingy aThingy;  // Constructor accesses hardware so it must be protected.  It is protected because it comes after the line above.
If accidentally reversed, disaster ensues...
  SuperHardwareThingy aThingy;  // Constructor accesses hardware so it must be protected.  Oops.
The Libc macro does not have the same potential problem.
pico
Actually no.
Actually, yes.
Try compiling the following code. The compiler happily accepts the break and continue statements in the setup() function, but rejects them in the loop() function.
#include <util/atomic.h>
  ATOMIC_BLOCK(ATOMIC_RESTORESTATE)
    int a =0;
    if (a++ > 0) continue;
    else break;
  int a =0;
  else break;
The compiler messages are:
sketch_oct04a.cpp: In function 'void loop()':
sketch_oct04a:16: error: continue statement not within a loop
sketch_oct04a:17: error: break statement not within loop or switch
OTOH, comment out the offending code in the loop() function, and the compiler accepts the break and continue statements in the setup() function happily.
Binary sketch size: 456 bytes (of a 32256 byte maximum)
Since it's a "for" loop, I can't see how the compiler could NOT be expected to accept both break and continue statements as legal C statements in that context (because they are).
A bug, but one of perhaps of theoretical interest only. Still, it's a bug Pyro's approach doesn't suffer from, which was my point.
On a practical note, the other advantage of the ATOMIC_BLOCK macros over anything else that is likely to be a contender is that the macros have been very carefully tested for all the subtle problems that can occur with instruction reordering optimisations, etc. The story behind the development by Dean Camera (abcminiuser) was documented in an interesting thread on AVRFreaks.
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=45041&postdays=0&postorder=asc&highlight=atomic
It would take a fair degree of analysis and testing before any replacement would reach the same level of acceptance, I think.
WizenedEE
Whoops, sorry. I misread your post as "The avr-libc macros won't reenable macros if break is used" which I still believe is false. You are correct that break is still a valid statement, and that this would be an ever greater problem:
volatile int count; // updated by interrupt
while(1) {
  if (digitalRead(2)) {
    break; // Breaks out of outer while
  ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
    if (count > 5) break; // BUG, outer while is not `broken'.
