Topic: Using AccelStepper to listen to USB (Read 1 time) previous topic - next topic
kid1000002000
Hello,
I am brand new to the electronics world and am seeking help. I have googled as much as I can but am just overwhelmed by the sheer volume of information and need someone to help me sort it all out and get started.
Goal: to use the Arduino Lorenzo as stepper motors control in conjunction with a easydrivers 4.2, and gphoto2, running on a computer.
I am confused on a few things: The AccelStepper library seems to do exactly what I want; acceleration is something I will require to be gentle to the DSLR. However, I would like to be able to issue commands from the laptop, to the arduino, to the easy driver. It seems to me that (this is my first sketch, so be patient with me!) to make the arduino execute stepper commands, you burn (upload?) a file to the ATMega chip over USB and it executes it. So, in the AccelStepper examples that I have found, these run in a continuous loop executing whatever stepper commands you included with the burn/upload.
However, what I want to do is have the arduino listen for input from the computer before executing usb-contained stepper commands. I plan to start out issuing these commands via BASH and eventually in a python program.
My main question is, what is the best way to do this? Do you just re-upload the AccelStepper library + commands each time you want one of the motors to do something? Is there a way to configure AccelStepper to loop on the Arduino, listening for USB commands, and then execute them (if so, do you have an example)? Or would you use another library completely that is designed just for this sort of thing? My biggest question is, what is the most efficient way to go about this and not be uploading something all the time that isn't a complete waste of USB communication, and isn't re-burning/re-defining the entire "OS" onto the ATMega all the time, or uploading the library with each command execution? Or is this exactly what you do?
Thank you for your help (and patience)!
dxw00d
The Arduino implements a virtual serial port over USB. All you need to do is send serial data from your PC, and use the Serial functions in your Arduino sketch to control what it is doing.
http://arduino.cc/en/Reference/Serial
PaulS
No. You can get the "what to do" information from the serial port, as dxw00d points out.
Maybe, but that is not the intent of that library. The listen to the serial port part should be part of the sketch, not the library.
Yes. The HardwareSerial class (implemented as Serial) is what you need.
kid1000002000
