Loading...
Pages: [1]   Go Down
Author Topic: Old UK TV satellite dish to Boost RF signal  (Read 665 times)
Durham UK
Offline Offline
Full Member
aka Craig Turner
View Profile
WWW
I've got an old concave UK BskyB dish and I would like to use it to "boost" a signal from my RF module attached to arduino. The RF module is a Jeenode type RF12, but my setup is not Jeenode it's attached to an Arduino Uno.
After a bit of research, I think I have to position the receiver module an exact multiple of wavelengths from the center of the dish to get it to work as a collector of "waves" and reflect them towards the RF module efficiently (ie so they mostly add up instead of cancel out).
Using the equation
Code:
wavelength = C / f
(C is velocity of light and f is freq of radiation) I get
Code:
3*10^8 / 868 MHz = 34.56 cm
I would appreciate an experienced look at my logic and Maths and some comment on it.
Am I on the right track?
Cheers
Logged
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The reflector should be 1/4 or 3/4 or 5/4 or 7/4 wavelengths from the back reflector, and as close to the dish's focus as that allows.  ideally you'd use a dipole antenna at the end of a feed coax, but you can try just placing the whole module there.  Make sure the antenna wire is perpendicular to the axis of the dish.
Then experiment a bit !
Logged
Pages: [1]   Go Up
Print
Jump to:
