Topic: How to get Font from EEPROM (Read 3366 times) previous topic - next topic
taipscode
Oct 02, 2012, 02:10 pm Last Edit: Oct 02, 2012, 02:25 pm by taipscode Reason: 1
Hello every boby.
for (byte c=0; c<8; ++c) {
    for (byte y=0; y<8; ++y) {
           byte data = (byte) pgm_read_byte (&myfont[disp[line][c]][y]);   // fetch data from program memory
             for (byte x=0; x<8; ++x) {
               if (data & (1<<x)) {
                  // on is off
                  int color = 2;
                  if (line > 1)
                    color = 1;
                  set_pixel((7-x) + (line * 8),y + (c*8),color);
                   //set_pixel(x,y,1);
This is available code ,which i downloaded ,but i don't know how to use detail this syntax :
This code is so complex ,can you give me some codes simpler ,because i search on Google serveral days ,but difficult to found  =( =(
Thanks
marcello.romani
EEPROM != PROGMEM
It's difficult to help with just a code snipped. Please post all the info you have, especially what you're trying to achieve.
taipscode
Yes,this is a full source.pde
http://www.mediafire.com/?1o5eptd3avscb61
marcello.romani
Nice!
Have you noticed this line in font.h ?
const prog_uint8_t PROGMEM BitMap[8] = {                                   // Store in program memory to save RAM
PROGMEM is where the program(!) is stored. RAM and EEPROM are other two types of memory you find in Arduino (well, inside the Atmega328P, actually).
pgm_read_byte is a special function that reads a byte from PROGMEM and brings it into RAM, so it can be used by the program.
I won't repeat here with my own (poor) words what has already been written elsewhere in great detail. Search for PROGMEM.
taipscode
I only want how to use this syntax
not const prog_uint8_t PROGMEM BitMap[8] = {
Thanks
marcello.romani
Please read my previous reply.
Also, I don't find it clear what you're trying to do...
taipscode
Yes, i hope you don't reply with not useful  :0
Thanks
marcello.romani
#7
Oct 02, 2012, 02:55 pm Last Edit: Oct 02, 2012, 03:01 pm by tuxduino Reason: 1
That's the wrong smiley to use when asking for FREE help.
Good luck with your project.
(edit: maybe you misunderstood my previous answer: what I meant is that I don't understand what you're trying to achieve; it wasn't a judgement about your project (which I don't know))
fungus
pgm_read_byte() is a function in the Arduino library.
dxw00d
I think it is general avr-libc, rather that Arduino specific.
http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html
XzipbitA
data = (get 8 pixels ) from (a font-character[pointed to by disp[currentline][current_character][current_character_pixel_line].
Which is a complicated way of Saying
if disp[line] = "A simple test"
then disp[line][0] = "A"
      disp[line][1] = " "
      disp[line][2] = "s"
      ... etc
then &myfont[] returns the address of a character inside a font array which holds the (8 x 8 pixels) character.
So &myfont[disp[line][0]] would return the address to the letter "A" in the font array.
&myfont[disp[line][0]][y] would return 8 pixels of row [y] of the letter "A"
This technique is used to convert a letter to pixels. e.g. (8x8 pixel font)
[font=Courier]
.  .  .  X  .  .  .  .
.  .  X  .  X  .  .  .
.  X  .  .  .  X  .  .       =>  A
.  X  X  X  X  X  .  .
X  .  .  .  .  .  X  .
X  .  .  .  .  .  X  .
[/font]
It's reading 8 pixels as a byte.
Your code then loops through this code with for (byte x=0; x<8; ++x)
And draws a pixel on the screen if it found a pixel in the font.
Thats about it.
