Topic: LCD hookup and programming (Read 788 times) previous topic - next topic
Skoog
I have been working with the arduino and have been having troubles with interfacing it with an LCD 5v from sparkfun.
my problem is
set up the lcd with 4 and then 8 bit
using the LCD header file and cpp files in the hardware libraries.
LCD pin1 GND
LCD pin2 5v
LCD pin3 10k pot from pin2
LCD pin4-pin6 RS-RW-E
LCD Pin7-14 Datalines
LCD pin15-16 LED Back light
my problems start by just pluging the thing in. the Contrast only works correct if I plug the thing to ground. I don't this this is right. The pot should be on the voltage side?
The only thing that I have been able to get out of the thing is
it sets and then boots and then it displays two four blocks
XXXX  - full blocks
XXXX
Does anyone have an idea as to what is going on?
Thanks
transam
What exact model are you using? Are you using the lcd4bit or the liquidcrystal library? Tie pin 5 to ground. See if that helps.
Skoog
Thanks what the pin 5 all about?
transam
You can read data from the lcd or something. If not needed, just ground the pin and it works.
