Topic: 'Func-def not allowed...' error on IR MP3 controller (Read 4071 times) previous topic - next topic
drwhofan
Hi all
I'm mashing Bill Porter's MP3 shield player:
http://www.billporter.info/sparkfun-mp3-shield-arduino-library/comment-page-6/#comments
with Sparkfun's IR controller:
http://www.sparkfun.com/tutorials/291
I'll post the code below.  I need help because at int getIRKey()  {
I get:
a function-definition is not allowed here before '{' taken
sketch_oct02a.cpp: In function 'void loop()':
sketch_oct02a:39: error: a function-definition is not allowed here before '{' token
sketch_oct02a:63: error: expected `}' at end of input
I've used this exact piece of code in another IR controller and not had this problem.  In fact, I just copied it over.  I can't find a bracket solution at all so I'm looking for your help, please.
I can't tell where I haven't closed a bracket, perhaps?   Any thoughts on what I'm doing wrong?
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <SFEMP3Shield.h>
SFEMP3Shield MP3player;
//new ir code
int irPin = A0; //Sensor pin 1 wired to Arduino's pin 2
int statLED = 13; //Toggle the status LED every time Power is pressed
int start_bit = 2200; //Start bit threshold (Microseconds)
int bin_1 = 1000; //Binary 1 threshold (Microseconds)
int bin_0 = 400; //Binary 0 threshold (Microseconds)
   pinMode(irPin, INPUT);
       // turn on the MP3 chip
    MP3player.begin();
  int key = getIRKey();
  if (key !=0) // bingo! bring on the noise! bring on the funk!
        // start playing the sound
  switch(key)
  case 144: MP3player.playTrack(1); break;
  case 145: MP3player.playTrack(2); break;
  case 146: MP3player.playTrack(3); break;
  case 147: MP3player.playTrack(4); break;
int getIRKey() {
  int data[12];
  int i;
  while(pulseIn(irPin, LOW) < start_bit); //Wait for a start bit
  for(i = 0 ; i < 11 ; i++)
    data[i] = pulseIn(irPin, LOW); //Start measuring bits, I only want low pulses
  for(i = 0 ; i < 11 ; i++) //Parse them
    if(data[i] > bin_1) //is it a 1?
      data[i] = 1;
    else if(data[i] > bin_0) //is it a 0?
      data[i] = 0;
      return -1; //Flag the data as invalid; I don't know what it is! Return -1 on invalid data
  int result = 0;
  for(i = 0 ; i < 11 ; i++) //Convert data bits to integer
    if(data[i] == 1) result |= (1<<i);
  return result; //Return key number
AWOL
Look at "loop" and count the closing braces.
Consistent indentation helps prevent this kind of thing
MichaelMeissner
You need another close curly brace after the end of the switch statement, just before the 'int getIRKey() {' line.  I believe the IDE has an option to indent code, and if you use it, it can help identify where you are missing closing brackets.
AWOL
MichaelMeissner
Make that two closing braces
Yes you are right.  I missed the one on the if statement.
drwhofan
The help is much appreciated but I think I'm still in the weeks!
I did this:
switch(key)
  int getIRKey() {
  int data[12];
  int i;
And I get:
expected primary-expression before '}' token
sketch_oct02a:26: error: expected primary-expression before '}' token
sketch_oct02a:26: error: expected `;' before '}' token
sketch_oct02a:28: error: 'key' was not declared in this scope
sketch_oct02a:36: error: expected primary-expression before ')' token
sketch_oct02a:36: error: expected `;' before ')' token
sketch_oct02a:61: error: expected `}' at end of input
Arrch
Do you not understand how to match { with }?
Take a look at a few examples to see how they are supposed to be used together.
drwhofan
I thought I had a clue about it but I guess not, because otherwise I wouldn't be asking for help.
Jimmy60
One method I use to keep the braces matched is I always type both if I type one. Then I put the code inside them.
I also use ctrl-t (format) in the IDE. It will give an error if the brackets don't match. The IDE will also highlight the matching bracket if you put your cursor on one.
Once you figure out the brackets look at the if statement around the switch. You should be able to eliminate that and have the switch handle any value of key.
marcello.romani
#9
Oct 03, 2012, 01:12 am Last Edit: Oct 03, 2012, 08:23 am by tuxduino Reason: 1
It's dead simple. For each { there must be a matching }. In the end, the number of { must be equal to the number of }.
Each { } pair identifies a block of code. Just like a pair of ( ) encloses an expression.
You immediately see something missing here
if ( a== 2
don't you ? Likewise, you should see something missing here too:
while (value < 3) {  k++;
I hope this clarifies the subject.
drwhofan
OK - the example is appreciated - now all my brackets seem to be closed, according to the IDE.
Now, when I compile, I get this:
sparkfun_porter_mashup_2_100212.cpp: In function 'void loop()':
sparkfun_porter_mashup_2_100212:30: error: expected primary-expression before '}' token
sparkfun_porter_mashup_2_100212:30: error: expected `;' before '}' token
sparkfun_porter_mashup_2_100212.cpp: At global scope:
sparkfun_porter_mashup_2_100212:31: error: expected unqualified-id before '{' token
Is that still an indication of a bracket problem?  I googled the error and I get a lot of info about C++ programming.
Thanks.
AWOL
#11
Oct 03, 2012, 07:29 am Last Edit: Oct 03, 2012, 08:41 am by AWOL Reason: 1
Yes, that is an indication of a problem, but without code, we can't tell what it is.
Consistent indentation helps greatly identifying problems like this.
marcello.romani
You probably just need to add the required ; at the end of line 30.
BTW, it's quite hard to debug other people's code just by looking at compilation errors and some source snippet (hint ;) )
drwhofan
Hint taken.   :D
#include <SPI.h>
#include <SdFat.h>
//new ir code
    MP3player.begin();
  switch(key)
int getIRKey() {
  int data[12];
  int i;
      data[i] = 1;
      data[i] = 0;
  int result = 0;
marcello.romani
You probably meant:
  if (key !=0) {
    switch(key) {
