Pages: [1] 2   Go Down
Author Topic: Need help with sketch  (Read 863 times)
Howdy I’m a beginner
I am trying to use a DHT11 to monitor temp/humidity ( turn on Led8 when temp drops below threshold1 and use threshold2 for humidity-not entered yet, if I can figure temp first then humid.
I have declared threshold1, but keep getting this error when compiling
Threshold1 was not declared in this scope
Using arduino 1280 and arduino 1.01
Thanks for all replies
#include <dht11.h>
dht11 DHT11;
  const int LEDPIN8 = 8; // heat
  const int LEDPIN9 = 9;// mister
  pinMode (LEDPIN8, OUTPUT); // Heat
  pinMode (LEDPIN9, OUTPUT); // Mister
  DHT11.attach(2);
  const int THRESHOLD1 = 90;   // Heat
  const int THRESHOLD2 = 90;  // Mister
  Serial.println("\n");
  int chk = DHT11.read();
  Serial.print("Read sensor: ");
  switch (chk)
  case 0:
    Serial.println("OK");
    break;
  case -1:
    Serial.println("Checksum error");
    break;
  case -2:
    Serial.println("Time out error");
    break;
  default:
    Serial.println("Unknown error");
  Serial.print("Temperature (°F): ");
  Serial.println(DHT11.fahrenheit(), DEC);
if (chk < THRESHOLD1)           //
    digitalWrite(LEDPIN8, HIGH);
    digitalWrite(LEDPIN8,LOW);
  delay(20000);
UK
Online Online
The compiler is giving a huge clue.
You've declared it inside setup, so it isn't visible (in scope) in loop.
Ditto your pin numbers.
Please use code tags when posting code.
Also, 0 is always less than 90.
« Last Edit: October 02, 2012, 03:52:26 pm by AWOL » Logged
Leeds, England
Quick, chuck it in the bin before the boss finds out...
Or, to put it another way, chk is the device status, not the temperature or humidity...
Using a DHT11 on arduino1280, Trying to turn on LED when threshold met
When I compile it stops on
Temperature = (Temperature (°F): );
and says stray "/" in program, I can't find it
Sorry don't understand code tags yet, don't see #
#include <dht11.h>
dht11 DHT11;
  DHT11.attach(2);
{  const int LEDPIN8 = 8;       // Temp
  const int LEDPIN9 = 9;       // Humidity
 pinMode (LEDPIN8, OUTPUT); // Temp
 pinMode (LEDPIN9, OUTPUT); // Humidity
{const int THRESHOLD1 = 80;   // Temp
const int THRESHOLD2 = 50;  // humidity
  switch (chk)
  case 0:
    break;
  case -1:
    break;
  case -2:
    break;
  default:
    break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, DEC);
  //Temperature
  Temperature = (DHT11.fahrenheit(), DEC);
   if (Temperature < THRESHOLD1)           // heat
    //Humidity
    Humidity = (float)DHT11.humidity, DEC);
     if (Humidity > THRESHOLD2)           // Humidity
    digitalWrite(LEDPIN9, HIGH);
    digitalWrite(LEDPIN9,LOW);
  delay(20000);
Massachusetts, USA
and says stray "/" in program, I can't find it.
It's probably just confused because "Temperature = (Temperature (°F): );" is not a valid statement.  What did you intend that line to do?
I want to compare it to the threshold1 to turn on the LED
Stray \ in program usually means you have a unicode character in there. Which is most certainly that degree symbol. Delete it.
It looks like this line
near the top of the file was supposed to be a variable declaration but some text from a later println got in there.  You make assignments to Temperature and Humidity without having declared them.  There is also a stray "{" before "const int THRESHOLD1".  Try replacing this:
with this:
float Temperature;
float Humidity;
BTW, variable names usually start with a lower case to distinguish them from class names.
« Last Edit: October 02, 2012, 09:14:00 pm by Blue Eyes » Logged
When I set the (temp) threshold1 to 60 ( lower limit), which is below my room temp and threshold3 to 80(upper limit), Ledpin8 just flashes once and goes low, never comes on again, unless restart. I wonder if my IF statements are right?  At least a LED comes on. The prog prints temp/humidity OK
#include <dht11.h>
dht11 DHT11;
  DHT11.attach(2);
const int THRESHOLD1 = 60;   // Temp lower limit turn on..60
const int THRESHOLD3 = 100;   // Temp upper limit turn off
const int THRESHOLD2 = 50;  // humidity lower limit turn on
const int THRESHOLD4 = 75;   // humidity upper limit turn off
float Temperature;
float Humidity;
  switch (chk)
  case 0:
    break;
  case -1:
    break;
  case -2:
    break;
  default:
    break;
  Serial.print("Temperature (F): ");
  //Temperature
   if (DHT11.fahrenheit(), DEC < THRESHOLD1)           // temp turn on...less than 60
    //delay(4000);//works on temp
    if (DHT11.fahrenheit(), DEC > THRESHOLD3)           // temp turn off.. more than 80
    //Humidity
    Humidity = (DHT11.humidity, DEC);
     if (DHT11.humidity, DEC < THRESHOLD2)           // Humidity turn on les than 50
    //delay(2000);//no work on hum
  if (DHT11.humidity, DEC > THRESHOLD4)           // Humidity turn off.. more than 75
  delay(200);
Moderator edit: CODE TAGS
« Last Edit: October 03, 2012, 01:24:09 am by AWOL » Logged
UK
Online Online
Trying to print a 32 bit float (which is, in reality a pointer to a function anyway) to ten decimal places is a trifle optimistic.
Why have you got all your "pinMode"s in "loop"?
I'd expect to see them in "setup".
What do you expect this
to do?
Uncompiled, untested.
#include <dht11.h>
dht11 DHT11;
  DHT11.attach(2);
  switch (chk)
    case 0:
    break;
    case -1:
    break;
    case -2:
    break;
    default:
    break;
  float temperature = DHT11.fahrenheit();
  float humidity = DHT11.humidity ();
  Serial.println(humidity);
  Serial.println(temperature);
  if (temperature < THRESHOLD1)
  if (temperature > THRESHOLD3)
  if (humidity < THRESHOLD2)
  if (humidity > THRESHOLD4)
  delay(200);
I'd be inclined to give the thresholds meaningful names like "LOWER_TEMPERATURE_THRESHOLD" etc.
« Last Edit: October 03, 2012, 01:34:53 am by AWOL » Logged
to do? If the temp is lower than 60 turn on Ledpin6
Looks like my pinmodes are in setup
The sketch compiles and displays temp/humidity, just won't hold the Led's high between thresholds
UK
Online Online
It doesn't do that. It compares the value 10 (aka "DEC") to the value 60 (aka "THRESHOLD1").
Now it is my turn to not understand. (that's a hint to you to post your observations)
« Last Edit: October 03, 2012, 01:57:51 am by AWOL » Logged
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
to do?
DEC is just an optional argument of Serial.print(), to ensure the first one is printed as a decimal number, not hex or binary or char.
It's not a typecast operator, like you seem to be using it:
A note about coding style always use brackets after if(), like this (I have not corrected your code, just added brackets):
if (DHT11.fahrenheit(), DEC > THRESHOLD3) {
//delay(4000);//works on temp       <== where did this go ? Inside the "then" block or not ?
if (DHT11.humidity, DEC < THRESHOLD2) {
if (DHT11.humidity, DEC > THRESHOLD4) {
UK
Online Online
Or to tell how many decimal places to print the value with, if the value is a float. (or a function pointer cast to a float, which isn't recommended)
Pages: [1] 2   Go Up
