Topic: Need help with sketch (Read 3979 times) previous topic - next topic
truck56
Howdy I'm a beginner
I am trying to use a DHT11 to monitor temp/humidity ( turn on Led8 when temp drops below threshold1 and use threshold2 for humidity-not entered yet, if I can figure temp first then humid.
I have declared threshold1, but keep getting this error when compiling
Threshold1 was not declared in this scope
Using arduino 1280 and arduino 1.01
Thanks for all replies
#include <dht11.h>
dht11 DHT11;
  const int LEDPIN8 = 8; // heat
  const int LEDPIN9 = 9;// mister
  pinMode (LEDPIN8, OUTPUT); // Heat
  pinMode (LEDPIN9, OUTPUT); // Mister
  DHT11.attach(2);
  const int THRESHOLD1 = 90;   // Heat
  const int THRESHOLD2 = 90;  // Mister
  Serial.println("\n");
  int chk = DHT11.read();
  Serial.print("Read sensor: ");
  switch (chk)
  case 0:
    Serial.println("OK");
    break;
  case -1:
    Serial.println("Checksum error");
    break;
  case -2:
    Serial.println("Time out error");
    break;
  default:
    Serial.println("Unknown error");
  Serial.print("Temperature (°F): ");
  Serial.println(DHT11.fahrenheit(), DEC);
if (chk < THRESHOLD1)           //
    digitalWrite(LEDPIN8, HIGH);
    digitalWrite(LEDPIN8,LOW);
  delay(20000);
AWOL
#1
Oct 02, 2012, 10:49 pm Last Edit: Oct 02, 2012, 10:52 pm by AWOL Reason: 1
The compiler is giving a huge clue.
You've declared it inside setup, so it isn't visible (in scope) in loop.
Ditto your pin numbers.
Please use code tags when posting code.
Also, 0 is always less than 90.
dannable
Or, to put it another way, chk is the device status, not the temperature or humidity...
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
truck56
Using a DHT11 on arduino1280, Trying to turn on LED when threshold met
When I compile it stops on
Temperature = (Temperature (°F): );
and says stray "/" in program, I can't find it
Sorry don't understand code tags yet, don't see #
#include <dht11.h>
dht11 DHT11;
  DHT11.attach(2);
{  const int LEDPIN8 = 8;       // Temp
  const int LEDPIN9 = 9;       // Humidity
pinMode (LEDPIN8, OUTPUT); // Temp
pinMode (LEDPIN9, OUTPUT); // Humidity
{const int THRESHOLD1 = 80;   // Temp
const int THRESHOLD2 = 50;  // humidity
  switch (chk)
  case 0:
    break;
  case -1:
    break;
  case -2:
    break;
  default:
    break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, DEC);
  //Temperature
  Temperature = (DHT11.fahrenheit(), DEC);
   if (Temperature < THRESHOLD1)           // heat
    //Humidity
    Humidity = (float)DHT11.humidity, DEC);
     if (Humidity > THRESHOLD2)           // Humidity
    digitalWrite(LEDPIN9, HIGH);
    digitalWrite(LEDPIN9,LOW);
  delay(20000);
johnwasser
and says stray "/" in program, I can't find it.
It's probably just confused because "Temperature = (Temperature (°F): );" is not a valid statement.  What did you intend that line to do?
truck56
I want to compare it to the threshold1 to turn on the LED
WizenedEE
Stray \ in program usually means you have a unicode character in there. Which is most certainly that degree symbol. Delete it.
Blue Eyes
#7
Oct 03, 2012, 04:11 am Last Edit: Oct 03, 2012, 04:14 am by Blue Eyes Reason: 1
It looks like this line
near the top of the file was supposed to be a variable declaration but some text from a later println got in there.  You make assignments to Temperature and Humidity without having declared them.  There is also a stray "{" before "const int THRESHOLD1".  Try replacing this:
with this:
float Temperature;
float Humidity;
BTW, variable names usually start with a lower case to distinguish them from class names.
truck56
#8
Oct 03, 2012, 07:33 am Last Edit: Oct 03, 2012, 08:24 am by AWOL Reason: 1
When I set the (temp) threshold1 to 60 ( lower limit), which is below my room temp and threshold3 to 80(upper limit), Ledpin8 just flashes once and goes low, never comes on again, unless restart. I wonder if my IF statements are right?  At least a LED comes on. The prog prints temp/humidity OK
#include <dht11.h>
dht11 DHT11;
 DHT11.attach(2);
const int THRESHOLD1 = 60;   // Temp lower limit turn on..60
const int THRESHOLD3 = 100;   // Temp upper limit turn off
const int THRESHOLD2 = 50;  // humidity lower limit turn on
const int THRESHOLD4 = 75;   // humidity upper limit turn off
float Temperature;
float Humidity;
 switch (chk)
 case 0:
   break;
 case -1:
   break;
 case -2:
   break;
 default:
   break;
 Serial.print("Temperature (F): ");
 //Temperature
  if (DHT11.fahrenheit(), DEC < THRESHOLD1)           // temp turn on...less than 60
   //delay(4000);//works on temp
   if (DHT11.fahrenheit(), DEC > THRESHOLD3)           // temp turn off.. more than 80
   //Humidity
   Humidity = (DHT11.humidity, DEC);
    if (DHT11.humidity, DEC < THRESHOLD2)           // Humidity turn on les than 50
   //delay(2000);//no work on hum
 if (DHT11.humidity, DEC > THRESHOLD4)           // Humidity turn off.. more than 75
 delay(200);
Moderator edit: CODE TAGS
AWOL
#9
Oct 03, 2012, 08:26 am Last Edit: Oct 03, 2012, 08:34 am by AWOL Reason: 1
Trying to print a 32 bit float (which is, in reality a pointer to a function anyway) to ten decimal places is a trifle optimistic.
Why have you got all your "pinMode"s in "loop"?
I'd expect to see them in "setup".
What do you expect this
if (DHT11.fahrenheit(), DEC < THRESHOLD1)     to do?
Uncompiled, untested.
#include <dht11.h>
dht11 DHT11;
 DHT11.attach(2);
 switch (chk)
   case 0:
   break;
   case -1:
   break;
   case -2:
   break;
   default:
   break;
 float temperature = DHT11.fahrenheit();
 float humidity = DHT11.humidity ();
 Serial.println(humidity);
 Serial.println(temperature);
 if (temperature < THRESHOLD1)
 if (temperature > THRESHOLD3)
 if (humidity < THRESHOLD2)
 if (humidity > THRESHOLD4)
 delay(200);
I'd be inclined to give the thresholds meaningful names like "LOWER_TEMPERATURE_THRESHOLD" etc.
truck56
to do? If the temp is lower than 60 turn on Ledpin6
Looks like my pinmodes are in setup
The sketch compiles and displays temp/humidity, just won't hold the Led's high between thresholds
AWOL
#11
Oct 03, 2012, 08:56 am Last Edit: Oct 03, 2012, 08:57 am by AWOL Reason: 1
It doesn't do that. It compares the value 10 (aka "DEC") to the value 60 (aka "THRESHOLD1").
Now it is my turn to not understand. (that's a hint to you to post your observations)
marcello.romani
to do?
DEC is just an optional argument of Serial.print(), to ensure the first one is printed as a decimal number, not hex or binary or char.
It's not a typecast operator, like you seem to be using it:
marcello.romani
A note about coding style always use brackets after if(), like this (I have not corrected your code, just added brackets):
if (DHT11.fahrenheit(), DEC > THRESHOLD3) {
//delay(4000);//works on temp       <== where did this go ? Inside the "then" block or not ?
if (DHT11.humidity, DEC < THRESHOLD2) {
if (DHT11.humidity, DEC > THRESHOLD4) {
AWOL
Or to tell how many decimal places to print the value with, if the value is a float. (or a function pointer cast to a float, which isn't recommended)
