Author Topic: Make an acceleromer control a servo.  (Read 2039 times)
Can any one write the code that this guy used to make his servo react the way it does. Thank you! smiley-grin
Massachusetts, USA
The ADXL330 has voltage outputs so you connect it to an analog input.
#include <Servo.h>
const int servoPin = 9;
const in ADXLpin = A0;
Servo myServo;
void setup() {myServo.attach(servoPin);}
    int accel = analogRead(ADXLpin);
    int angle = map(accel, 0, 1023, 0, 180);
    myServo.write(angle);
THANK YOU SO MUCH!!!!
Does anything have to go in the parenthesis with the word angle in it? I have an odd feeling like there should be an angle measure there.
Massachusetts, USA
'angle' is the name if an integer variable, calculated from the acceleration:
Hi again! I have a new question. Would this code be compatible with a Mesmic 2125 accelerometer? Can you explain if any the difference? Thanks a lot! I've learned a lot from asking questions of this forum. You guys are great! smiley-grin
Massachusetts, USA
The Mesmic 2125 accelerometer (http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/memsickit.pdf) outputs a variable-width pulse rather than an analog voltage.  At 0G the output pulse is 5000 microseconds high and each 1G would be a change of 1250 microseconds. A pulse of 3750 microseconds would be -1G and 6250 microseconds would be +1G. The code for that would be something like this:
    int accel = pulseIn(MemsicPin);
    int angle = map(accel, 3750, 6250, 0, 180);  // map -1G through +1G to 0 through 180
Oh, I see! That's so cool! Thanks again, you rock!
