Topic: USB gets turned off? (Read 3551 times) previous topic - next topic
norsk
hey new to coding but i am trying to have it setup so that when i push a 1 button out of 2 it records it for 10 button hits after that i hit a third button  it play back the hits with LEDs each button has a differnt color(red, green) then when i hit third button again it resets.
my problem is that when i hit any of the 3 buttons my ardunio shuts off until i hit the button again.
could anything in my code be causing this or is it a hardware thing?
Code: [Select]
//button 1 is in pin 2
//button 2 is in pin 4
//button 3 is in pin 7
// pin 13 is green
// pin 12 is red
int start = 0;
int total = 0;
int one = 0;
int two = 0;
int three = 0;
int four = 0;
int five = 0;
int six = 0;
int seven = 0;
int eight = 0;
int nine = 0;
int ten =0;
  pinMode(13,OUTPUT);
  pinMode(2,INPUT);
  pinMode(4,INPUT);
  pinMode(7,INPUT);
  pinMode(12,OUTPUT);
  Serial.println(total);
  Serial.println(digitalRead(4));
  if (total == 11 && digitalRead(4) == 1){
    start = 2;
  if (digitalRead(4) == 1 && total == 0) {
    start = 1;  // 1 = start recording
    delay(2000);
  if (start == 1) {
    total = 1;
  if (total == 1) {
    if (digitalRead(2) == 1) { // red = 1
      one = 1;
      total = 2;
    else if (digitalRead(7) == 1) { // green = 2
      one = 2;
      total = 2;
    else {
      one = 0;
      total = 1;
    delay(2000);
  if (total == 2) {
      two = 1;
      total = 2;
      two = 2;
      total = 2;
    else {
      two == 0;
      total = 3;
    delay(2000);
  if (total == 3) {
      three = 1;
      total = 4;
      three = 2;
      total = 4;
    else {
      three == 0;
      total = 3;
    delay(2000);
  if (total == 4) {
      four = 1;
      total = 5;
      four = 2;
      total = 5;
    else {
      four == 0;
      total = 4;
    delay(2000);
  if (total == 5) {
      five = 1;
      total = 6;
      five = 2;
      total = 6;
    else {
      five == 0;
      total = 5;
    delay(2000);
  if (total == 6) {
      six = 1;
      total = 7;
      six = 2;
      total = 7;
    else {
      six == 0;
      total = 6;
    delay(2000);
  if (total == 7) {
      seven = 1;
      total = 8;
      seven = 2;
      total = 8;
    else {
      seven == 0;
      total = 7;
    delay(2000);
  if (total == 8) {
      eight = 1;
      total = 9;
      eight = 2;
      total = 9;
    else {
      eight == 0;
      total = 8;
    delay(2000);
  if (total == 9) {
      nine = 1;
      total = 10;
      nine = 2;
      total = 10;
    else {
      nine == 0;
      total = 9;
    delay(2000);
  if (total == 10) {
      ten = 1;
      total = 11;
      ten = 2;
      total = 11;
    else {
      ten == 0;
      total = 10;
    delay(2000);
  if ( start == 2)
    if (one == 1) {
      digitalWrite(12,HIGH);
      digitalWrite(12,LOW);
  if (one == 2) {
    digitalWrite(13,HIGH);
    digitalWrite(13,LOW);
  if (two == 1) {
  if (two == 2) {
  if (three == 1) {
  if (three == 2) {
  if (four == 1) {
  if (four == 2) {
  if (five == 1) {
  if (five == 2) {
  if (six == 1) {
  if (six == 2) {
  if (seven == 1) {
  if (seven == 2) {
  if (eight == 1) {
  if (eight == 2) {
  if (nine == 1) {
  if (nine == 2) {
  if (ten == 1) {
  if (ten == 2) {
  if (start == 2 && digitalRead(4) == 1) {
    total = 0;
Coding Badly
At this point, you need to assume the problem is hardware and you need to resolve the problem before you damage your Arduino.
Do you have current-limiting resistors in series with the LEDs?
How do you have the buttons wired?
norsk
#2
Oct 03, 2012, 08:15 am Last Edit: Oct 03, 2012, 08:18 am by norsk Reason: 1
i have an ardunio uno
so i have pin 12, 13 going through a 220 ohms resistors then LED then to ground
then i have the 5v pin hooked up to the 3 buttons,  pretty much setup like this (http://arduino.cc/en/Tutorial/DigitalReadSerial) but with 3 buttons and the 5v going to all 3 (might be my problem?) then i ground them all to the same ground.  and the inputs from the buttons are going to pin 2, 4, 7
i could take a pic and upload it if it makes it more clear
if i'm doing something wrong let me know i'm fairly knew to electronics and coding.
edit: oh yea i have 10k ohms resistors in between buttons and ground
Coding Badly
Quote
...my ardunio shuts off...
What do you mean by "shuts off"?  The green LED labeled ON near the reset button goes out?
rockwallaby
Maybe it might be of some use to start your serial in the setup function, as I don't see it anywhere?
For example
Code: [Select]
rockwallaby . .
PaulS
You appear to have a problem remembering things.
Code: [Select]
    start = 2;
Reading the various anonymous pins ONCE per pass through loop should be sufficient. It hardly seems likely that the state of the pin will have changed much in the time it takes to execute this code. But, what if that happened, while the switch was bouncing, maybe. What would that do to your code?
How are your switches wired?
norsk
Quote
yea the light goes out when ever i hit the button and my computer cant recognize the USB anymore until i hit button again. it is weird.
Code: [Select]
    start = 2;
you mean digitalRead(4)? but i want to make sure the the button is pushed and and its currently not reading any of the other 2 buttons. maybe i'm confused by what you mean. ( new to coding)
PaulS
Quote
Yes. There should be one call to digitalRead(4). Not three. That way, all the concerns about the state of pin 4 are concerned about the state of pin 4 AT THE SAME TIME, not at 3 different times.
At the risk of repeating myself:
Quote
Coding Badly
You have the buttons wired wrong.  You have to fix that problem before continuing.  You are damaging your Arduino and possibly your computer.
norsk
So like make an if statement with digitalRead being first test
Then have if for each "total" ?
Like this
If ( digitalRead(4) == 1) {
If (total == 0) {
  Start = 1;
If (total == 11) {
Etc
What about the other buttons?
I think this project was to hard for me for where I'm at in my learning  of coding
Also I thought I explained my wiring already? Is there a better way of explaining it?
Thanks for helping me out
PaulS
Quote
You said:
Quote
Quote
Yes. A switch has two legs. A wire has two ends. Describe how many wires there are (for one switch; we'll assume that they are all wired the same, unless you say otherwise). Describe where each end of each wires goes.
You don't mention any pullup or pulldown resistors. Without them, or the internal pullup resistors, the switches will float, and you will have all kinds of grief.
The simplest way to wire a switch is to connect one leg to the digital pin and the other leg to ground. Then, turn on the pullup resistor for that pin.
Code: [Select]
pinMode(somePin, INPUT);
digitalWrite(somePin, HIGH);
norsk
Ok so my buttons are setup almost  exactly like image in link
all 3 buttons are connected to the same 5v source, and are all connected to the same ground.
Then each button has a different input pin being used.
They are 4 pin not 2 pin
The resistor in the link is a pull-up resistor? Or pull down?
Hope that helps
Docedison
"all 3 buttons are connected to the same 5v source, and are all connected to the same ground.
Then each button has a different input pin being used." (Quoted from OP's post...)
This would explain why, Quoted from the thread title "Re: USB gets turned off?"...
When you connect a switch from power to ground and activate it (a N.O. Switch... obviously)
You've connected power to ground and after having done that, discovered there's no power left
to do anything else.
In the real world you would 1. connect a resistor (~1K to ~47K) from the input pin to EITHER power
OR ground and connect the switch from the input pin to the OPPOSITE of where you connected the
resistor to. In this manner of connection If the Switch goes to ground, testing the input pin will show
a high state EXCEPT when the switch is activated and a low state EXCEPT when the switch is activated.
Or 2. If the resistor is connected to ground and the input pin... and the switch is between power and the input pin.
will show a low state Except when the switch is activated and a high state when the switch is activated.
If the resistor is connected to ground and the input  ... and the switch is between power and the input pin
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
PaulS
Quote
4 physical legs does not equate to 4 pins. Two legs get connected to two other legs when the switch is pressed.
holmes4
What type of switches are you using? It sounds like you're using on/off switches (like light switches).
Mark
