Loading...
Pages: [1] 2 3   Go Down
Author Topic: WavePro Shield - Beta Testers wanted  (Read 4115 times)
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
For some time now I have been designing the new WavePro shield for the Arduino.
Simply, it is a shield with a dsPIC33FT128GP802 microcontroller on it linked to an SD card.
The firmware on the dsPIC reads WAV files from the SD card, and plays them through its internal audio DAC.
It also has rudimentary recording abilities.
It can play WAV files up to 48KHz 16 bit stereo at a nice high quality.
The project has reached the stage now where I need people "in the field" to test it and feed back to me their ideas and experience with it.
So, I am looking for a couple of willing beta testers to try out a board and experiment with it.
I won't give these out to just anyone though. I am looking for a couple of people who:
1. Are willing to spend time testing the board and feed back their findings to me.
2. Have the ability to program a dsPIC chip (using a pickit2 or pickit3, etc).
3. Have a good grasp of digital and analogue electronics.
4. Can perform modifications to predominantly SMD based boards.
5. Have good knowledge of the WAV file and its structure.
If you are interested, please PM me telling me why you think you should be considered for this beta program.
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
*Bump*
C'mon guys, someone here must want a free high quality WAV playing shield to play with...
Logged
USA, FL
Offline Offline
God Member
A life? Where can I download one of those?
View Profile
Looks like you want a few "professional" testers that specialize in just one area.  There might be a few here...  But, maybe not...
I am working on an audio project that I could possibly use your shield.
1. Have plenty of time for testing and could give some feedback.
2. Could learn
3. I am not a genius with Digital or Analog, but I know the difference.
4. I can do that.
5. I have worked with WAV before...
As far as testing, obviously it works, but what are you looking to get out of it being tested?  Better quality sound, easy set-up, bugs, etc..?
Logged
//LiNK
UK
Offline Offline
Edison Member
View Profile
WWW
You don't need to be professional, no.
Just willing to spend some time playing with it and let me know what you think - but most importantly have the ability to upload new versions of the firmware to the dsPIC on the shield.  That means you need at least a pickit2 or better hardware programmer.
There should be no need to do any hardware mods, but at this stage who can tell for sure?
And by knowing the WAV format, I mean being able to create and edit WAV files in various formats for testing of the different features and settings.  You don't need intimate knowledge of the internals of the file format.
Logged
Nice, France
Offline Offline
Full Member
View Profile
The set of people who would like a WAV sheild to play with and the set of people who are competent PIC programmers and skilled SMD solder/reworkers may be disjoint.
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Quote
I don't mean people who can write programs for the PIC - I mean people who have the ability to upload firmware to a PIC.
Logged
Taiwan
Offline Offline
Newbie
View Profile
WWW
This sounds right up my alley - I've sent a PM (or two?)
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
I have a PICKit2 programming still lying around...
and I have played with a few WAV type shields..
(mine and the Adafruit Waveshield)..
Outside of this being PIC based.. how does it differ from the RuggedCiruits Audio board they have out?  (curious is all)
Love that it takes the stress off the main Arduino chip though.. (in both projects)
Have you worked up any code examples or libraries for it?
I am curious if you can:
1.) layer/mix audio sounds?  (ie: having a back ground track playing.. and layer/mix other sounds/samples over it?
2.) SEAMLESS looping?
I can solder just fine... even some SMD stuff..
have re-flowed a few parts..and custom boards/projects as well..
Let me know
(located in the US....Wisconsin to be more exact)  smiley-wink
thanks!
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Well, that is the main core of the difference really.
The RuggedCircuits one uses the ATxmega32A4.  That is an 8 bit chip, just like on the Arduino itself.  Yes, it has a DAC on-board the chip, but it's only 12-bit, so unless RC are using an external DAC of some form, even 16-bit WAV files will only play back at 12 bit resolution.  The dsPIC, in comparison, is not only a 16 bit controller (with all the associated benefits that come with that), but has a 16 bit sigma-delta (audio) DAC on the chip, so you get the full 16 bit resolution out of 16 bit WAV files.  Not only that, the dsPIC has a DSP module in it, so complex filtering and other intensive signal processing can be performed (the firmware doesn't do this yet, but it could).
The site for the board is at http://sf.net/projects/wavepro and there is a library available there to download.  It's a fully open-source project, so you could have a go at building your own - schematics are on the site there.
Not at the moment - it's single sample only at the moment - however, it is in its infancy, and multiple sample playing may well be on the cards.
Again, not at the moment, but as before, it's something that could easily be added to the firmware if people want it, so it may well happen.
I'll drop you a PM to get your details.
Logged
Offline Offline
Edison Member
If you're not living on the Edge, you're taking up too much space!
View Profile
I would like to help test it!  PM me.
Logged
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
Nice, France
Offline Offline
Full Member
View Profile
This does sound like an interesting shield. I didn't want you to conclude from lack of (qualified) beta testers that there was no interest. In particular, the 16-bit DAC and DSP features are very useful.
I hope that this shield will be compatible with the Mega in terms of pin allocation (and not blocking pins). If you can do that, and make it switchable 5V 3.3V then it should work with  Due too? I mention this because the Due is likely to be more suitable for digital audio projects than the current 8-bit line, and its general pinout is very Arduino Mega2560-like.
« Last Edit: October 16, 2012, 04:36:59 pm by Nantonos » Logged
UK
Offline Offline
Edison Member
View Profile
WWW
The board is aimed at the Uno-style layout.  It will be blocking a couple of pins below the normal Uno portion of the mega. The board outline follows the Uno almost exactly, so I would guess that at most maybe 2 pins will be blocked.
The board itself runs of 5V, and has its own 3.3V regulators on-board (separate power supplies for digital and analogue portions).  The communication pins on the dsPIC are 5V tolerant, so will run off a 5V or a 3.3V board as long as there is a power supply greater than about 3.6V to run the LDO regulators.  As it stands, all the audio processing / IO is performed by the dsPIC chip, so the power of the "host" controller is pretty irrelevant.  I may well be adding portions to the firmware to allow playing of audio data direct from the host controller through SPI, however if that is the main usage you want from it, and the host controller is powerful enough, then an I²S codec chip would probably be a better option.  This board is aimed at off-loading the audio processing and SD card IO from the host controller on to the audio board, thus freeing up the host controller for more important tasks.
Logged
Offline Offline
Newbie
View Profile
Hello. I was wondering if you still needed testers, I am an audio engineer in Canada and I am involved in a few projects that might need something like this. Please give me an email if you still need help. Elijahlucian@gmail.com
Logged
Offline Offline
Newbie
View Profile
I would love to beta test this. I can program the dspic chip. Thanks again for this awesome work.
pm sent
Pat Star
« Last Edit: October 25, 2012, 11:25:21 pm by patstar » Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Unfortunately I am out of beta boards now.  I may be making some more in the near future, so I'll keep you in mind and let you know.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
