Author Topic: Need help with webserver  (Read 536 times)
Buena Vista, CO
I'm trying to set up a webserver which accepts comands fron the internet. I used
as an example the program at
http://www.charmcitynetworks.com/techblog/web-controlled-window-air-conditioner-using-and-arduino/
my code:
#include <[color=#CC6600]SPI[/color].h>
#include <[color=#CC6600]Ethernet[/color].h>
#define BUFSIZ 100
[color=#CC6600]byte[/color] mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
[color=#CC6600]byte[/color] ip[] = {192,168,0,14};
[color=#CC6600]Server[/color] server(80);
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
  [color=#CC6600]Ethernet[/color].[color=#CC6600]begin[/color](mac, ip);
  server.[color=#CC6600]begin[/color]();
  [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]begin[/color](9600);
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
  [color=#CC6600]char[/color] clientline[BUFSIZ];
  [color=#CC6600]char[/color] c;
  [color=#CC6600]int[/color] index = 0;
  [color=#CC6600]int[/color] stat = 0;
  [color=#7E7E7E]// listen for incoming clients[/color]
  [color=#CC6600]Client[/color] client = server.[color=#CC6600]available[/color]();
  [color=#CC6600]if[/color] (client)
    [color=#CC6600]boolean[/color] currentLineIsBlank = [color=#CC6600]true[/color];
    [color=#CC6600]while[/color] (client.[color=#CC6600]connected[/color]())
      [color=#CC6600]if[/color] (client.[color=#CC6600]available[/color]())
        [color=#CC6600]char[/color] c = client.[color=#CC6600]read[/color]();
        [color=#CC6600]if[/color] (c != [color=#006699]'\n'[/color] && c != [color=#006699]'\r'[/color]) {
          clientline[index] = c;
          index++;
          [color=#CC6600]if[/color] (index >= BUFSIZ)
            index = BUFSIZ -1;
          [color=#CC6600]continue[/color];
        clientline[index] = 0;
        [color=#CC6600]if[/color] (strstr(clientline, [color=#006699]"GET / "[/color]) != 0)
          [color=#7E7E7E]// send a standard http response header[/color]
          client.[color=#CC6600]println[/color]([color=#006699]"HTTP/1.1 200 OK"[/color]);
          client.[color=#CC6600]println[/color]([color=#006699]"Content-Type: text/html"[/color]);
          client.[color=#CC6600]println[/color]();
          client.[color=#CC6600]println[/color]([color=#006699]"<html>"[/color]);
          client.[color=#CC6600]println[/color]([color=#006699]"<body>"[/color]);
          client.[color=#CC6600]print[/color]([color=#006699]"<FORM action=\"http://192.168.0.14/\" >"[/color]);
          client.[color=#CC6600]print[/color]([color=#006699]"<INPUT type=\"hidden\" name=\"status1\" value=\"1\">"[/color]);
          client.[color=#CC6600]print[/color]([color=#006699]"<INPUT type=\"submit\" value=\"Led On\"> </FORM>"[/color]);
          client.[color=#CC6600]print[/color]([color=#006699]"<INPUT type=\"hidden\" name=\"status0\" value=\"0\">"[/color]);
          client.[color=#CC6600]print[/color]([color=#006699]"<INPUT type=\"submit\" value=\"Led Off\"> </FORM>"[/color]);
          [color=#CC6600]break[/color];
        [color=#CC6600]else[/color] [color=#CC6600]if[/color] (strstr(clientline, [color=#006699]"status0"[/color]) != 0)
         [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color](clientline);
         doZero;
        [color=#CC6600]else[/color] [color=#CC6600]if[/color] (strstr(clientline, [color=#006699]"status1"[/color]) != 0)
          doOne;
          client.[color=#CC6600]println[/color]([color=#006699]"HTTP/1.1 404 Not Found"[/color]);
    [color=#CC6600]delay[/color](1);
    client.[color=#CC6600]stop[/color]();
[color=#CC6600]void[/color] doZero()
[color=#CC6600]void[/color] doOne()
it works somewhat, using my test program shows two buttons. The Serial monitor shows that clicking
the on button gives:
GET /?status1=1 HTTP/1.1
and clicking the off button gives:
GET /?status1=0 HTTP/1.1
The problem is that the browser then gives error message
The connection was reset
and browser address line is
http://192.168.0.14/?status1=1  or 0
what I need is to reload 192.168.0.14, how do I do that?
Jim
8000ft above the average
Gosport, UK
Can you re-copy your code from the IDE please? Don't use the copy for forum option, as it puts all those color tags in, and makes it impossible to read.
Western New York, USA
You might get better results if you post this question in one of the other forum areas.  My guess would be to try the Networking, Protocols, and Devices area.
Don
Buena Vista, CO
Don
Would the moderator of this forum move this to Networking, Protocols, and Devices
Jim
i might be able to help you on this...
so you want to clidk on a button and then do something else? like move to another weppage or update values?
