You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
« Reply #15 on: October 05, 2012, 03:28:42 pm » |
Tom, I think the OP wants to store the value of the char variable c into the first element of two_character_string, not the letter 'c'. // otherwise, just print all normal characters two_character_string[0] = c; two_character_string[1] = 0; // this can be put in setup() LCDString(two_character_string);
Leeds, UK
Once the magic blue smoke is released, it won't go back in!
« Reply #16 on: October 05, 2012, 03:56:26 pm » |
Ahh right, in which case you just need to remove the ' ' char two_character_string[2] = {c,0};
~Tom~
Seattle, WA USA
Seattle, WA USA
« Reply #17 on: October 05, 2012, 08:24:05 pm » |
It should be this: Most definitely not. The [2] index is all wrong for an array that has two elements.
Leeds, UK
« Reply #18 on: October 06, 2012, 03:38:05 am » |
I'm sorry, in what way is the [2] wrong? It is a declaration of an array with two elements, which is initialised with two characters, 'c' and 0 (or in my last post is initialised with the value stored in the variable c and a 0).
~Tom~
Seattle, WA USA
Seattle, WA USA
« Reply #19 on: October 06, 2012, 07:00:44 am » |
I read your previous post too quickly. It was correct. I was wrong. My apologies.
« Reply #20 on: October 07, 2012, 03:46:59 pm » |
i still get the same problem
UK
« Reply #21 on: October 07, 2012, 03:48:18 pm » |
Which "same" is that?
« Reply #22 on: October 07, 2012, 04:52:31 pm » |
i still get the same error
« Reply #23 on: October 07, 2012, 05:07:37 pm » |
Leeds, UK
« Reply #24 on: October 07, 2012, 06:24:55 pm » |
Right, I went back to you first post and worked from what you said was wrong. A couple of corrections later: #define PIN_SCE 7 #define PIN_RESET 6 #define PIN_DC 5 #define PIN_SDIN 4 #define PIN_SCLK 3 int ledlight = 13; #define LCD_C LOW #define LCD_D HIGH
#define LCD_X 84 #define LCD_Y 48 #include <PS2Keyboard.h>
const int DataPin = 8; const int IRQpin = 2; PS2Keyboard keyboard; static const byte ASCII[][5] = { {0x00, 0x00, 0x00, 0x00, 0x00} // 20 ,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 ! ,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 " ,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 # ,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $ ,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 % ,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 & ,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 ' ,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 ( ,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 ) ,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a * ,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b + ,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c , ,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d - ,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e . ,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f / ,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0 ,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1 ,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2 ,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3 ,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4 ,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5 ,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6 ,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7 ,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8 ,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9 ,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a : ,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ; ,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c < ,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d = ,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e > ,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ? ,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @ ,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A ,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B ,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C ,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D ,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E ,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F ,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G ,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H ,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I ,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J ,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K ,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L ,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M ,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N ,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O ,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P ,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q ,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R ,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S ,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T ,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U ,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V ,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W ,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X ,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y ,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z ,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [ ,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥ ,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ] ,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^ ,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _ ,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 ` ,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a ,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b ,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c ,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d ,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e ,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f ,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g ,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h ,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i ,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j ,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k ,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l ,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m ,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n ,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o ,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p ,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q ,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r ,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s ,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t ,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u ,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v ,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w ,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x ,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y ,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z ,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b { ,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c | ,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d } ,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ← ,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f → };
void LcdCharacter(char character) { LcdWrite(LCD_D, 0x00); for (int index = 0; index < 5; index++) { LcdWrite(LCD_D, ASCII[character - 0x20][index]); } LcdWrite(LCD_D, 0x00); }
void LcdClear(void) { for (int index = 0; index < LCD_X * LCD_Y / 8; index++) { LcdWrite(LCD_D, 0x00); } }
void LcdInitialise(void) { pinMode(PIN_SCE, OUTPUT); pinMode(PIN_RESET, OUTPUT); pinMode(PIN_DC, OUTPUT); pinMode(PIN_SDIN, OUTPUT); pinMode(PIN_SCLK, OUTPUT); digitalWrite(PIN_RESET, LOW); digitalWrite(PIN_RESET, HIGH); LcdWrite(LCD_C, 0x21 ); // LCD Extended Commands. LcdWrite(LCD_C, 0xB1 ); // Set LCD Vop (Contrast). LcdWrite(LCD_C, 0x04 ); // Set Temp coefficent. //0x04 LcdWrite(LCD_C, 0x14 ); // LCD bias mode 1:48. //0x13 LcdWrite(LCD_C, 0x0C ); // LCD in normal mode. LcdWrite(LCD_C, 0x20 ); LcdWrite(LCD_C, 0x0C ); }
void LcdString(const char characters[]) { LcdString((char*)characters); }
void LcdString(char* characters){ while (*characters) { LcdCharacter(*characters++); } }
void LcdWrite(byte dc, byte data) { digitalWrite(PIN_DC, dc); digitalWrite(PIN_SCE, LOW); shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data); digitalWrite(PIN_SCE, HIGH); }
void setup(void) { delay(1000); keyboard.begin(DataPin, IRQpin); LcdInitialise(); LcdClear(); LcdString("Hello World!"); }
void loop(void) { if (keyboard.available()) { // read the next key char c = keyboard.read(); // check for some of the special keys if (c == PS2_ENTER) { LcdString("\r\n"); } else if (c == PS2_TAB) { LcdString("[Tab]"); } else if (c == PS2_ESC) { LcdString("[ESC]"); } else if (c == PS2_PAGEDOWN) { LcdString("[PgDn]"); } else if (c == PS2_PAGEUP) { LcdString("[PgUp]"); } else if (c == PS2_LEFTARROW) { LcdString("[Left]"); } else if (c == PS2_RIGHTARROW) { LcdString("[Right]"); } else if (c == PS2_UPARROW) { LcdString("[Up]"); } else if (c == PS2_DOWNARROW) { LcdString("[Down]"); } else if (c == PS2_DELETE) { LcdString("[Del]"); } else { // otherwise, just print all normal characters LcdCharacter(c); } } } First as pointed out, this: int ledlight = 13 Should be this: int ledlight = 13; Secondly this: LcdString(c); Should be this: LcdCharacter(c); Finally, you cant use this: void LcdString(char* characters){ while (*characters) { LcdCharacter(*characters++); } } with constant string literals. You have to have a seperate function to handle them. Fortunately C++ can handle overloaded function calls where you have two functions with the same name, but take different parameters/variables in the call. So lets overload LcdString and add the ability to add constant strings (the clue is in the name: const) Lets add this: void LcdString(const char characters[]) { LcdString((char*)characters); } Which takes the constant string and type casts it to the non constant version. Of course this can be achieved with a simple type cast as such: LcdString((char*)"[Del]"); But it makes the code less messy to have a seperate function.
~Tom~
« Reply #25 on: October 09, 2012, 06:49:15 pm » |
Hello again, I really appreciate all your help and I am sorry that I can not do this by myself. Just to clear things up, I believe my current problem started once i started the double array. I reread all the corrections and I placed them in. Here is my error, again Lcd_screen___keyboard:16: error: expected constructor, destructor, or type conversion before '=' token Lcd_screen___keyboard:17: error: expected constructor, destructor, or type conversion before '=' token Lcd_screen___keyboard:19: error: 'c' was not declared in this scope Lcd_screen___keyboard.cpp: In function 'void setup()': Lcd_screen___keyboard:180: error: invalid conversion from 'const char*' to 'char' Lcd_screen___keyboard:180: error: initializing argument 1 of 'void LcdCharacter(char)' Lcd_screen___keyboard.cpp: In function 'void loop()': Lcd_screen___keyboard:194: error: invalid conversion from 'const char*' to 'char' Lcd_screen___keyboard:194: error: initializing argument 1 of 'void LcdCharacter(char)' Lcd_screen___keyboard:198: error: 'LCDString' was not declared in this scope Here is my code corrected and updated #define PIN_SCE 7 #define PIN_RESET 6 #define PIN_DC 5 #define PIN_SDIN 4 #define PIN_SCLK 3
const int DataPin = 8; const int IRQpin = 2; two_character_string[0] = c; two_character_string[1] = 0;
char two_character_string[2] = {c, 0};
PS2Keyboard keyboard; static const byte ASCII[][5] = { {0x00, 0x00, 0x00, 0x00, 0x00} // 20 ,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 ! ,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 " ,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 # ,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $ ,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 % ,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 & ,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 ' ,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 ( ,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 ) ,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a * ,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b + ,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c , ,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d - ,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e . ,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f / ,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0 ,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1 ,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2 ,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3 ,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4 ,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5 ,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6 ,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7 ,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8 ,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9 ,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a : ,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ; ,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c < ,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d = ,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e > ,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ? ,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @ ,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A ,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B ,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C ,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D ,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E ,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F ,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G ,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H ,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I ,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J ,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K ,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L ,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M ,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N ,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O ,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P ,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q ,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R ,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S ,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T ,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U ,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V ,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W ,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X ,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y ,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z ,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [ ,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥ ,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ] ,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^ ,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _ ,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 ` ,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a ,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b ,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c ,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d ,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e ,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f ,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g ,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h ,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i ,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j ,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k ,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l ,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m ,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n ,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o ,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p ,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q ,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r ,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s ,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t ,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u ,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v ,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w ,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x ,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y ,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z ,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b { ,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c | ,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d } ,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ← ,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f → }; void gotoXY(int x, int y) { LcdWrite(0, 0x80 | x); // Column. LcdWrite(0, 0x40 | y); // Row. ? }
void LCDClear(void) { for (int index = 0 ; index < (LCD_X * LCD_Y ) ; index++) LcdWrite(LCD_D, 0x00); gotoXY(0, 0); //After we clear the display, return to the home position }
void setup(void) { keyboard.begin(DataPin, IRQpin); LcdInitialise(); LCDClear(); LcdCharacter("Ready!"); }
void loop(void) { LCDClear(); if (keyboard.available()) { // read the next key char c = keyboard.read(); // check for some of the special keys if (c == PS2_ENTER) { } else if (c == PS2_TAB) { LcdCharacter("[Tab]"); } else {
LCDString(two_character_string); }
} } The error highlights ; this two_character_string[0] = c; in the code
Melbourne, Australia
Have you tried turning it off and on again?
« Reply #26 on: October 09, 2012, 07:10:45 pm » |
You are missing your overloaded function.
« Reply #27 on: October 10, 2012, 02:11:56 am » |
Please see my comments in the code identified by <==== #define PIN_SCE 7 #define PIN_RESET 6 #define PIN_DC 5 #define PIN_SDIN 4 #define PIN_SCLK 3
const int DataPin = 8; const int IRQpin = 2; two_character_string[0] = c; // <======= c is undefined two_character_string[1] = 0;
char two_character_string[2] = {c, 0}; // <======= c is undefined
LCDString(two_character_string); // <========= what does two_character_string contain ? }
UK
« Reply #28 on: October 10, 2012, 02:26:33 am » |
...not only that, but "two_character_string" is undeclared!
« Reply #29 on: October 10, 2012, 03:59:44 am » |
It is declared, but after the (incorrect) assignments to its elements.
