Topic: Code help (Read 7084 times) previous topic - next topic
marcello.romani
Tom, I think the OP wants to store the value of the char variable c into the first element of two_character_string, not the letter 'c'.
// otherwise, just print all normal characters
two_character_string[0] = c;
two_character_string[1] = 0;    // this can be put in setup()
LCDString(two_character_string);
Tom Carpenter
Ahh right, in which case you just need to remove the ' '
char two_character_string[2] = {c,0};
~Tom~
PaulS
It should be this:
Most definitely not. The [2] index is all wrong for an array that has two elements.
Tom Carpenter
I'm sorry, in what way is the [2] wrong? It is a declaration of an array with two elements, which is initialised with two characters, 'c' and 0 (or in my last post is initialised with the value stored in the variable c and a 0).
~Tom~
PaulS
I read your previous post too quickly. It was correct. I was wrong. My apologies.
jonathanped
i still get the same problem
AWOL
Which "same" is that?
jonathanped
i still get the same error
marcello.romani
Tom Carpenter
Right, I went back to you first post and worked from what you said was wrong. A couple of corrections later:
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
int ledlight = 13;
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
#include <PS2Keyboard.h>
const int DataPin = 8;
const int IRQpin =  2;
PS2Keyboard keyboard;
static const byte ASCII[][5] =
{0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ?
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f ?
void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);
void LcdClear(void)
  for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
void LcdInitialise(void)
  pinMode(PIN_SCE, OUTPUT);
  pinMode(PIN_RESET, OUTPUT);
  pinMode(PIN_DC, OUTPUT);
  pinMode(PIN_SDIN, OUTPUT);
  pinMode(PIN_SCLK, OUTPUT);
  digitalWrite(PIN_RESET, LOW);
  digitalWrite(PIN_RESET, HIGH);
  LcdWrite(LCD_C, 0x21 );  // LCD Extended Commands.
  LcdWrite(LCD_C, 0xB1 );  // Set LCD Vop (Contrast).
  LcdWrite(LCD_C, 0x04 );  // Set Temp coefficent. //0x04
  LcdWrite(LCD_C, 0x14 );  // LCD bias mode 1:48. //0x13
  LcdWrite(LCD_C, 0x0C );  // LCD in normal mode.
  LcdWrite(LCD_C, 0x20 );
void LcdString(const char characters[])
  LcdString((char*)characters);
void LcdString(char* characters){
  while (*characters)
    LcdCharacter(*characters++);
void LcdWrite(byte dc, byte data)
  digitalWrite(PIN_DC, dc);
  digitalWrite(PIN_SCE, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
  digitalWrite(PIN_SCE, HIGH);
void setup(void)
{ delay(1000);
   keyboard.begin(DataPin, IRQpin);
  LcdInitialise();
  LcdClear();
  LcdString("Hello World!");
void loop(void)
  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
      LcdString("\r\n");
    } else if (c == PS2_TAB) {
      LcdString("[Tab]");
    } else if (c == PS2_ESC) {
      LcdString("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      LcdString("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      LcdString("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      LcdString("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      LcdString("[Right]");
    } else if (c == PS2_UPARROW) {
      LcdString("[Up]");
    } else if (c == PS2_DOWNARROW) {
      LcdString("[Down]");
    } else if (c == PS2_DELETE) {
      LcdString("[Del]");
      LcdCharacter(c);
First as pointed out, this:
int ledlight = 13
Should be this:
int ledlight = 13;
Secondly this:
LcdString(c);
Should be this:
LcdCharacter(c);
Finally, you cant use this:
  while (*characters)
with constant string literals. You have to have a seperate function to handle them. Fortunately C++ can handle overloaded function calls where you have two functions with the same name, but take different parameters/variables in the call. So lets overload LcdString and add the ability to add constant strings (the clue is in the name: const)
Lets add this:
Which takes the constant string and type casts it to the non constant version. Of course this can be achieved with a simple type cast as such:
LcdString((char*)"[Del]");
But it makes the code less messy to have a seperate function.
~Tom~
jonathanped
Hello again, I really appreciate all your help and  I am sorry that I can not do this by myself.
Just to clear things up, I believe my current problem started once i started the double array. I reread all the corrections and I placed them in.
Here is my error, again
Lcd_screen___keyboard:16: error: expected constructor, destructor, or type conversion before '=' token
Lcd_screen___keyboard:17: error: expected constructor, destructor, or type conversion before '=' token
Lcd_screen___keyboard:19: error: 'c' was not declared in this scope
Lcd_screen___keyboard.cpp: In function 'void setup()':
Lcd_screen___keyboard:180: error: invalid conversion from 'const char*' to 'char'
Lcd_screen___keyboard:180: error: initializing argument 1 of 'void LcdCharacter(char)'
Lcd_screen___keyboard.cpp: In function 'void loop()':
Lcd_screen___keyboard:194: error: invalid conversion from 'const char*' to 'char'
Lcd_screen___keyboard:194: error: initializing argument 1 of 'void LcdCharacter(char)'
Lcd_screen___keyboard:198: error: 'LCDString' was not declared in this scope
Here is my code corrected and updated
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
char two_character_string[2] = {c, 0};
void gotoXY(int x, int y) {
  LcdWrite(0, 0x80 | x);  // Column.
  LcdWrite(0, 0x40 | y);  // Row.  ?
void LCDClear(void) {
  for (int index = 0 ; index < (LCD_X * LCD_Y ) ; index++)
  gotoXY(0, 0); //After we clear the display, return to the home position
void setup(void)
  LcdInitialise();
LCDClear();
   LcdCharacter("Ready!");
void loop(void)
{ LCDClear();
       LcdCharacter("[Tab]");
    }  else {
The error highlights ; this two_character_string[0] = c; in the code
InvalidApple
You are missing your overloaded function.
marcello.romani
Please see my comments in the code identified by <====
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
two_character_string[0] = c;    // <======= c is undefined
char two_character_string[2] = {c, 0};    // <======= c is undefined
void setup(void)
 LcdInitialise();
LCDClear();
void loop(void)
{ LCDClear();
   }  else {
      LCDString(two_character_string);    // <========= what does two_character_string contain ?
AWOL
...not only that, but "two_character_string" is undeclared!
marcello.romani
It is declared, but after the (incorrect) assignments to its elements.
