Servo library?
You mean just use the functions in "servo.h" ?
Does it have control structures with using the Wii NunChuck's joyStick_x and joyStick_y functions? I found something that might help.
Here is my entire code so far. My LED with continuosly flash when the C Button is pressed, but it pauses the servos from still following my movement until I release:
// This code has the servos pause when the LED is flashed or Z button is pressed//
#include <Wire.h>
#include <string.h>
#include "Arduino.h"
uint8_t outbuf[6];
int cnt = 0;
int ledPin = 9; //pin #9 is LED+
int ledPin2 = 13; //pin #13 is onboard LED
int servoPin = 6; //pin #6 is top servo or elevation
int servoPin2 = 5; //pin #5 is bottom servo or azimuth
int pulseWidth = 0;
int pulseWidth2 = 0;
long lastPulse = 0;
long lastPulse2 = 0;
int z_button = 0; // initializes the z button as LOW or not pressed.
int c_button = 0; // initializes the c button as LOW or not pressed.
int refreshTime = 20;
int minPulse = 1000;
int minPulse2 = 500;
int dtime=10;
#define pwbuffsize 10
long pwbuff[pwbuffsize];
long pwbuffpos = 0;
long pwbuff2[pwbuffsize];
long pwbuffpos2 = 0;
Serial.begin (19200);
Wire.begin ();
nunchuck_init ();
pinMode(servoPin, OUTPUT);
pinMode(servoPin2, OUTPUT);
pinMode(ledPin, OUTPUT); // sets the digital pin as output
pinMode(ledPin2, OUTPUT);
pulseWidth = minPulse;
pulseWidth2 = minPulse2;
Serial.print ("Finished setup\n");
void nunchuck_init()
Wire.beginTransmission (0x52);
Wire.write ((byte)0x40);
Wire.write ((byte)0x00);
Wire.endTransmission ();
void send_zero()
int t = 0;
t++;
long last = millis();
if( t == 1) {
t = 0;
Wire.requestFrom (0x52, 6);
while (Wire.available ()) {
outbuf[cnt] = nunchuk_decode_byte (Wire.read ());
digitalWrite (ledPin2, HIGH);
cnt++;
if (cnt >= 5) {
// printNunchuckData();
int z_button = 0;
int c_button = 0;
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
switch (c_button) {
case 1:
switch (z_button) {
case 0:
break;
case 1:
muovi();
break;
break;
case 0:
switch (z_button) {
case 0:
break;
case 1:
digitalWrite(ledPin, HIGH); // sets the LED on
delay(50); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
break;
break;
cnt = 0;
send_zero();
} // if(t==)
updateServo();
delay(dtime);
void updateServo() {
if (millis() - lastPulse >= refreshTime) {
digitalWrite(servoPin, HIGH);
delayMicroseconds(pulseWidth);
digitalWrite(servoPin, LOW);
digitalWrite(servoPin2, HIGH);
delayMicroseconds(pulseWidth2);
digitalWrite(servoPin2, LOW);
lastPulse = millis();
int i=0;
void printNunchuckData()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2]; // * 2 * 2;
int accel_y_axis = outbuf[3]; // * 2 * 2;
int accel_z_axis = outbuf[4]; // * 2 * 2;
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print (i,DEC);
Serial.print ("\t");
Serial.print ("X: ");
Serial.print (joy_x_axis, DEC);
Serial.print ("Y: ");
Serial.print (joy_y_axis, DEC);
Serial.print ("AccX: ");
Serial.print (accel_x_axis, DEC);
Serial.print ("AccY: ");
Serial.print (accel_y_axis, DEC);
Serial.print ("AccZ: ");
Serial.print (accel_z_axis, DEC);
Serial.print (z_button, DEC);
Serial.print (" ");
Serial.print (c_button, DEC);
Serial.print ("\r\n");
i++;
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
void muovi (){
float tilt = (700 - outbuf[3]*2*2);
float tilt2 = outbuf[2]*2*2;
tilt = (tilt);
pulseWidth = (tilt * 5) + minPulse;
tilt2 = (tilt2-288);
pulseWidth2 = (tilt2 * 5) + minPulse2;
pwbuff[pwbuffpos] = pulseWidth;
pwbuff2[pwbuffpos2] = pulseWidth2;
if( ++pwbuffpos == pwbuffsize ) pwbuffpos = 0;
if( ++pwbuffpos2 == pwbuffsize ) pwbuffpos2 = 0;
pulseWidth=0;
pulseWidth2=0;
for( int p=0; p<pwbuffsize; p++ ){
pulseWidth += pwbuff[p];
pulseWidth2 += pwbuff2[p];
pulseWidth /= pwbuffsize;
pulseWidth2 /= pwbuffsize;
