Topic: Rotary Switch--5 Position? (Read 2460 times) previous topic - next topic
abidethedude
Hey guys, I'm looking for a rotary switch that has 5 positions. I'm basically using the rotary switch as so:
http://s3.amazonaws.com/satisfaction-production/s3_images/101962/arduino-rotary-switch.png
I just want to confirm that it has to be a 1 polarize correct? What does it mean by deck? I'm asking because I'm having hard time finding the right one on digikey
retrolefty
Could you rephrase that 'polarize' statement, as I don't understand the question? If you mean are you only needing a single pole, five position rotary switch, that is correct. By the way in that drawing you show using external pull-up resistors. You really can save some trouble and not use them, but rather just enable the internal pull-up resistors for those specific pins, it's free and it works.
Lefty
johnwasser
The number of decks will probably not be a concern since you have only a single 'Pole' and five 'Throws' (SP5T).  If you had two (Double) Poles and 5 Throws (DP5T) you might have a choice of having both switches share a single Deck or having two Decks with one switch each. A Deck can contain roughly 12 Throws so for Double Throw, Triple Throw, and 4-throw switches you can fit more poles in a small space if you have multiple poles per deck.
For that diagram just pick a SP5T rotary switch.
If you are attaching a knob you probably want one with a "Flatted" shaft.  The "Flush" shaft style has to be turned with a screwdriver.
abidethedude
Lefty
Sorry about that. Yes I meant 1 pole .
I am actually going to be using the Atmega328 chip on a PCB board, hence it setup this way.
Thanks for the reply everyone!
MarkT
You used to be able to get rotary switches with 12 detents and configurable end-stops.  The one-pole version could do 2 to 11 way with the stop in place, or 12 way with no end stop.  2-pole 6-way and 3-pole 4-way variants were available, probably 4-pole 3-way too.
