Topic: Get value from RFID tag and store it as a string (Read 5758 times) previous topic - next topic
free-bee
I have looked for a couple hours now and the closest code I found didn't work. I have an RFID card reader from Parallax. I would like to get a tags value with it and print it to an LCD screen. However, I cannot find a way to get the tags value. I plan on using the RX pin of the arduino.  All I need is a simple program that gets the tag ID and convert it to a string. From there, I know how to send it to the LCD.
tkbyd
http://makeprojects.com/Project/Using-the-Parallax-RFID-Reader-with-an-Arduino/617/1#.UG0331HSBxA
Denbo
Also you could try this http://www.gumbolabs.org/2009/10/17/parallax-rfid-reader-arduino/
free-bee
I believe (after edits) that that may have gotten it. I'll have to check later, for I am currently working on another project at the moment.
free-bee
Well it didn't work. But it almost did. If someone wants to help, here's the code:
#define RFID_ENABLE 10   //to RFID ENABLE
#define CODE_LEN 10      //Max length of RFID tag
#define VALIDATE_TAG 1  //should we validate tag?
#define VALIDATE_LENGTH  200 //maximum reads b/w tag read and validate
#define ITERATION_LENGTH 2000 //time, in ms, given to the user to move hand away
#define START_BYTE 0x0A
#define STOP_BYTE 0x0D
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
//LiquidCrystal(rs, enable, d4, d5, d6, d7)
LiquidCrystal lcd(2, 3, 5, 6, 7, 8);
char tag[CODE_LEN];
  Serial.begin(2400);
  pinMode(RFID_ENABLE,OUTPUT);
lcd.begin(16,2) ;
  enableRFID();
  lcd.clear();
  getRFIDTag();
  if(isCodeValid()) {
    disableRFID();
    sendCode();
    delay(ITERATION_LENGTH);
    disableRFID();
    lcd.clear();
    lcd.print("Got some noise");
  Serial.flush();
  clearCode();
* Clears out the memory space for the tag to 0s.
void clearCode() {
  for(int i=0; i<CODE_LEN; i++) {
    tag[i] = 0;
* Sends the tag to the LCD.
void sendCode() {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("TAG:");
    //Serial.println(tag);
    lcd.setCursor(0,1);
    for(int i=0; i<=CODE_LEN; i++) {
      lcd.setCursor(tag[i],1);
      lcd.print(tag[i]);
/********************   RFID Functions  ***********************/
void enableRFID() {
   digitalWrite(RFID_ENABLE, LOW);
void disableRFID() {
   digitalWrite(RFID_ENABLE, HIGH);
* Blocking function, waits for and gets the RFID tag.
void getRFIDTag() {
  byte next_byte;
  while(Serial.available() <= 0) {}
  if((next_byte = Serial.read()) == START_BYTE) {
    byte bytesread = 0;
    while(bytesread < CODE_LEN) {
      if(Serial.available() > 0) { //wait for the next byte
          if((next_byte = Serial.read()) == STOP_BYTE) break;
          tag[bytesread++] = next_byte;
* Waits for the next incoming tag to see if it matches
* the current tag.
boolean isCodeValid() {
  byte next_byte;
  int count = 0;
  while (Serial.available() < 2) {  //there is already a STOP_BYTE in buffer
    delay(1); //probably not a very pure millisecond
    if(count++ > VALIDATE_LENGTH) return false;
  Serial.read(); //throw away extra STOP_BYTE
  if ((next_byte = Serial.read()) == START_BYTE) {
    byte bytes_read = 0;
    while (bytes_read < CODE_LEN) {
      if (Serial.available() > 0) { //wait for the next byte
          if ((next_byte = Serial.read()) == STOP_BYTE) break;
          if (tag[bytes_read++] != next_byte) return false;
  return true;   }
free-bee
Okay, I got it working for the most part. However, there is one huge problem. After the LCD displays the UID of the tag, the UID is replaced with some strange characters: each of them are decimal value 186. During that time, the code disables and re-enables the RFID reader. I did manage to use a longer time delay to get "Got some noise" to display instead of the strange characters. I have no idea what the crap is going on. I used Serial.println(tag) to show what the LCD was trying to display, and those strange dec186 characters return a blank character in the serial monitor. Here is my code:
#define ITERATION_LENGTH 5000 //time, in ms, given to the user to move hand away
#define green 12
#define red 13
char tag[CODE_LEN];
  Serial.begin(2400);
lcd.begin(16,2) ;
  enableRFID();
  delay(100);
  lcd.clear();
  lcd.print("TAG:");
  getRFIDTag();
  if(isCodeValid()) {
    disableRFID();
    sendCode();
    disableRFID();
    lcd.clear();
  Serial.flush();
  clearCode();
void clearCode() {
    tag[i] = 0;
void sendCode() {
    //lcd.clear();
    //lcd.setCursor(0,0);
    //lcd.print("TAG:");
    lcd.setCursor(0,1);
    for(int i=0; i <= 9; i++) {
      //lcd.setCursor(tag[i],1);
      Serial.println(tag[i]);
      lcd.print(tag[i]);
void enableRFID() {
   digitalWrite(red, HIGH);digitalWrite(green,LOW);
   digitalWrite(red, LOW);digitalWrite(green,HIGH);
void getRFIDTag() {
  byte next_byte;
    byte bytesread = 0;
* the current tag.
  byte next_byte;
  int count = 0;
  return true;   }
