Topic: Unwanted shut down of outputs. (Read 6980 times) previous topic - next topic
taz3m
Hi all,
Im actually writing some tutorial codes with my arduino UNO. . they were good at start now when i put some own modifications, it seems not working. Im quite afraid it is coming from hardware.
A simple sketch, is i pressed the pushbutton to light all my 5 leds, and i pressed the same to put them to low.
However, when the leds are on, they goes out without me pressing the button again after a while, as if an off delay is present.
I tried to figure out what is happening, and i wrote some codes to monitor within the serial monitor, when the serial monitor is opened, i can see all my variables being read, and my leds i.e. output work normally, no shut off delay.
As soon as i close my serial monitor, same thing happen leds goes out within a delay. quite weird. :)
I tried to change my sketch with something else, a blinky state this time, same system, ON state with button and same push button to OFF mode. Again same thing happening, as if an off delay is present though it is not in my code.
Can someone please advise, Thanks . . .
The code below:
 *  Blink ON & OFF with same switch . . .
 int switchPin = 2;            // switch is connected to pin 2
 int LED1 = 12;                // LED1 connected to pin 12
 int LED2 = 11;                // LED2 connected to pin 11
 int LED3 = 10;                // LED3 connected to pin 10
 int LED4 = 9;                 // LED4 connected to pin 9
 int LED5 = 8;                 // LED5 connected to pin 8
 int buttonState;              // variable to hold the last button state
 int val;                      // Variable to compare with buttonState
 int val2;                     // Variable to read the debounced status
 int lightMode = 0;            // Variable to set LEDs ON / OFF depending on mode.
   pinMode(switchPin, INPUT);   // Set the switch pin as input
   pinMode(LED1, OUTPUT);       // Set LED1 as ouput
   pinMode(LED2, OUTPUT);       // Set LED2 as ouput
   pinMode(LED3, OUTPUT);       // Set LED3 as ouput
   pinMode(LED4, OUTPUT);       // Set LED4 as ouput
   pinMode(LED5, OUTPUT);       // Set LED5 as ouput
Serial.begin(9600);                       // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);  // read the initial state
void loop(){
  val = digitalRead(switchPin);      // read input value and store it in val
Serial.print("val=");
Serial.println (val);
delay(10);
 val2 = digitalRead(switchPin);      // Read input again to check for bounces
Serial.print("val2 =");
Serial.println (val2);
 if (val == val2){
  if (val != buttonState) {          // the button state has changed!
    if (val == LOW) {                // check if the button is pressed
    if (lightMode == 0){             // Check status of lightMode
  lightMode = 1;                     // Sets lightMode to high, LEDs ON
      digitalWrite(LED1,HIGH);
      digitalWrite(LED2,HIGH);
      digitalWrite(LED3,HIGH);
      digitalWrite(LED4,HIGH);
      digitalWrite(LED5,HIGH);
   else{
   lightMode = 0;                    // Sets lightMode to Low, LEDs OFF
      digitalWrite(LED1,LOW);
      digitalWrite(LED2,LOW);
      digitalWrite(LED3,LOW);
      digitalWrite(LED4,LOW);
      digitalWrite(LED5,LOW);
  buttonState = val;  // save the new state in our variable
 Serial.print("buttonState =");
Serial.println (buttonState);
Looking forward ..
Thanks
Taz ...
PaulS
You haven't explicitly set the switch pin to INPUT.
You haven't enabled the pullup resistor on the switch pin.
You haven't told us how the switch is wired.
Matching names, like currState and prevState, make a lot more sense, and really appear to be logically related, than buttonState and val.
taz3m
Hello,
{Hello Paul : u remember we had a small discussion on a doing a garduino, and having to do a scada along with the Arduino, to be able to change different customise settings. So i started . . :%}
- I did set it to Input:  pinMode(switchPin, INPUT);   // Set the switch pin as input
Doing it explicitly . . how ??
- I did connect the switchButton, using the pull up resistor connection as below:
"see attached file"
- Is there anything i need to enable on software side ?
It will certainly look good and make sense if i match the names of variables with these.
taz
PaulS
I missed that. Sorry.
That looks fine. It uses two external resistors when none is really required, but it works.
Not since you have external hardware.
I was suspecting a floating pin condition, but that does not appear to be your problem.
Perhaps seeing the serial output would be useful.
taz3m
Can you kindly explain that part, though these external resistors are not required.
I taken a look on the schematic for pin 0 and 1 and noted a 1k ohm connected.
I read some few things while using an IO pin as input and using serial communication that creates some trouble . . ???
Furthermore, my Arduino was powered through my usb, i just transfered to an external power supply (9 Vdc) and get my code running as perfect, and forever . . .
Any explanation on that ?
liuzengqiang
Do you have resistors in series with your LEDs?
MarkT
The code does debouncing with a delay of 10ms, but then uses the button state to set the LEDs directly, so they will only be on with the button is pressed (and upto 10ms afterwards due to the debounce delay).
You want the button being active to toggle the state, something like
    buttonState = val ;
    if (!val)  // button was pressed
      ledState = !ledState ; // toggle
    digitalWrite(LED1, ledState);
    digitalWrite(LED2, ledState);
    digitalWrite(LED3, ledState);
    digitalWrite(LED4, ledState);
    digitalWrite(LED5, ledState);
Using an array of pin numbers will make the code less voluminous!
PeterH
The code looks correct, although I had to correct that horrible indentation before I could convince myself about that. Isn't this clearer?
delay(10);
if (val == val2)
if (val == LOW)
if (lightMode == 0)
I suggest you remove the Serial.print statements at the top of loop, and put one inside the block of code where "the button state has changed!" so you can see whether you're getting spurious switch inputs. Maybe the switch wiring has the odd glitch. Also put a print statement in setup(), or make it go through an obvious LED flashing sequence, so that it's obvious if the board has reset.
taz3m
Hi all,
It seems i figured out what is happeninng exactly, i changed my sketch and observed the problem.
In fact my UNO board is being reset at every interval of approx. 3 mins, sometimes less, when connected through USB.
Please take note that i am using the MAKERSHIELD board on top.
Any idea about what really happening here.
Thanks
taz ...
PeterH
Does the reset only happen when the makershield is connected?
retrolefty
If you are talking about pin0 (rec comm) on the arduino, it is already pulled-up via the 1k resistor wired to the USB serial converter chip, so it will not see a 'floating' input condition.
It could be (most likely) that your full setup of external hardware is just drawing too much +5 volt current. The USB 5 volt power coming from your PC is limited by the on-board thermofuse, rated at 500ma max. If however you are running using external power then the on-board 5 volt regulator is supplying the current and it has a little higher max current rating then when using USB power.
Lefty
liuzengqiang
It is strange that you figured out the period of your problem (I wish my students were this good) and more but failed to answer such a simple question.
taz3m
Lefty
[/quote]
Thanks for the information.
However, i removed my maker shield board and tested my UNO R3 board again.
I applied a simple sketch of blinking 1 led only, here again my Board resets itself repeatedly after an interval of 1 min or less.
However when connected to an external power, and removed the USB connection, my board does not reset
For now, i have only 1 LED connected, it comes from pin 13, set as output, goes through my LED from +ve pin to -ve via a 1K ohm resistor and eventually to the ground.
For my previous sketch, i was using 5 LEDS, each one connected seperately to their respective output pins, and each have their resistance through their LEDS.
Hope this answers the line, if my resistors were connected in series to my LEDs. . . Sorry for late reply. .  ;)
Can someone kindly please help me, is there anything i can do to restore this problem of reseting through using the USB port?
I will be late in preparing my Garduino ..  =( , on top i need to submit that too.
Thanks
taz .. ..
nickgammon
Just to clarify. You have a Uno board, no shield at all, connected to a single LED on pin 13, via a 1K resistor (to ground). Is that right? And running what sketch?
And it resets after 1 minute?
How do you know it resets?
taz3m
Yes an UNO R3 BOARD.. i removed my shield for trouble shooting purpose..
so as is now, my UNO board is without any shield at all and 1 LED is connected to pin 13, through a 1k resistor to ground..
Moreorless, it resets every 1 min or smetime less.
Please Note that i encountered this prob wen i was doing some other sketch.. see my first post.
For simplicity in troubleshooting, i change my circuit to a single led and watch my connected Led whch is blinks within a delay of 1000 ms..
Wen it resets you can see visually the blinking of my on board led connected to pin 13 n my led connected externally blinks just the same a wen as u press reset button.
If i try my code from my first post, my outputs goes out automatically and i need to press my switch again(input), clearly knowing that areset has been performed..
Taz ..
