Loading...
Pages: [1]   Go Down
Author Topic: light sensor circuit  (Read 553 times)
Offline Offline
Newbie
View Profile
i want a bulb/led to light up with an intensity dependent upon the amount of light that hits the analogue light sensor...do i really need arduino or any programming? , or can i just connect the battery ,the light sensor and the bulb in a simple circuit??
Logged
Offline Offline
Edison Member
View Profile
Quote
A 555 + photoresistor will do that for you.
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes you can but the components will have to be exactly the right type to get everything balanced. For example if you use a light dependent resistor you need to make sure that it can take the current and that the fully lit resistance is sufficient to turn your light on. I have done this sort of thing in the past and I have also use a relay directly connected to a light dependent resistor. I was able to use the normally closed contacts to light a flash light bulb that dropped the resistance of the light dependent resistor, thus turning it on, breaking the contact, turning the bulb off which robbed the sensor of light, turned the relay off thus turning the bulb on again. This made a simple oscillator.
Logged
Offline Offline
Edison Member
View Profile
Quote
What "the current" are you talking about?
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
The current that it will pass in what ever circuit arrangement you end up with.
Logged
Offline Offline
Edison Member
View Profile
Quote
When was the last time you have used a photoresistor that cannot take the current going through it?
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
Back in 1965, have you never used these?
Logged
Offline Offline
Edison Member
View Profile
Quote
Back in 1965,
Maybe it is time for an update on modern photoresistors?
Quote
I have never used a 1965's photoresistors.
Logged
Pages: [1]   Go Up
Print
Jump to:
