Loading...
Pages: [1] 2   Go Down
Author Topic: atMega8L -- any external components required at all?  (Read 1334 times)
Offline Offline
Sr. Member
View Profile
I've got some atMega8L chips ordered I intend to run at 3.3V, 8MHz from the internal oscillator.
I'm not intending to use the analog ADC, but the datasheet says I should supply power to AVcc as well as Vcc anyway.
Is there any need for any external components (e.g., caps) at all in this setup? I've seen some mega8 chips setup with small filter caps on AVcc and AREF to GND, but not sure if this will be beneficial at all if not using the ADC. The datasheet itself doesn't have anything definite to say on the matter AFAICT.
Thoughts?
« Last Edit: October 04, 2012, 12:14:37 pm by pico » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Thoughts?
.1 ufd caps mounted close to Vcc and Avcc for sure. If your not going to use ADC then bypassing Aref not really required. Chip manufacures almost always recommend applying standard Vcc bypassing as standard industry practice.
Lefty
Logged
Valencia, Spain
Online Online
Edison Member
View Profile
Atmel recommends a 220nF ceramic capacitor for decoupling and a 4.7k pullup resistor on RESET. That's it.
http://www.atmel.com/Images/doc0484.pdf
http://www.atmel.com/images/doc2521.pdf
Bear in mind that the internal 8mHz clock rate varies with temperature/voltage. Timing won't be very accurate, serial comms won't work except at slow speeds.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
A problem easily rectified with tuning.
Logged
Offline Offline
Edison Member
View Profile
Quote
You don't have to have them. But it is better to have them.
Quote
It actually requires far more than that. RC oscillators suffer a few issues: temperature drift, accuracy and jitter. Accuracy at a given temperature is easy to deal with. Jitter for long-time horizon applications can be dealt with. Temperature drift is difficult to resolve. fungus is right on target on this one.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
The target accuracy is "good enough for reliable serial communication at high speeds".  I stand by what I said.
Logged
Offline Offline
Edison Member
View Profile
Quote
Not sure how "high" of a high speed you are talking about but set the mcu on internal oscillator and run it at 38400 bps. Put your solder iron to the mcu and watch what happens on the transmission.
It is not pretty.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I can't tell if you're serious so I'll assume you are.  Grossly exceeding the temperature specification is not a valid test.
Logged
Offline Offline
Edison Member
View Profile
Quote
Which part of it exceeded the temperature specification?
Logged
Australia
Offline Offline
Sr. Member
Arduino rocks
View Profile
The data sheet specifies an operating temperature way below the ~300C degrees of a soldering iron.
Unless the OP's application requires a soldering iron to be constantly applied (while on) to the micro, I don't think this will pose a problem for its day-to-day operation.
Logged
Offline Offline
Edison Member
View Profile
You can get a peek at the internal rc's performance by looking an atmel app note (053), figure 2-1, p4.
Logged
Offline Offline
Edison Member
View Profile
Most people do not understand the distinction between the internal rc's accuracy vs. (thermal) drift.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Over the entire voltage-temperature envelope of the 328P processor, with a goal of 38400 baud, the error is -6.73% to 3.92%.  Well within range for serial communications to work.
Assuming the application does not require the full voltage range (1.8 to 5.5), the error over the temperature range drops to -3.60% to 2.66%.  Low enough for serial communications to be considered reliable.
Logged
Offline Offline
Sr. Member
View Profile
The internal pullup by itself isn't reliable? Surprising.
Quote
Thanks for the links! Useful reference material there.
BTW, just for some context, the discussion regarding the internal clock accuracy is interesting and useful for the general situation, but in this particular application I won't be using serial comms at all. Actually, I'll be using the atMega8L to replace an atTiny85, which works fine with an internal oscillator at 8MHz for this application, so I had assumed the atMega8L would too.
In this situation, since I'm not using ADC, or anything requiring a high clock accuracy, I was just wondering what external components (if any) I must/would be advised to have for an atMega8L.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
It's "weak".  30K to 60K ohms.  In some situations that makes it unreliable.
And, the cost of a single 4.7K to 10K resistor is how much?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
