Loading...
Pages: [1]   Go Down
Author Topic: Is there a mature and accurate way to log remote temperature to computer?  (Read 1125 times)
Offline Offline
Newbie
View Profile
I am thinking a on-site arduino and temp sensor and connect to ethernet since I can have a cable from my hub to the place.
Thanks
Logged
Offline Offline
Full Member
View Profile
You could use labview or profilab expert to import data;process and store them in excel format for instance. Then process them further in excel if needed.
Logged
Offline Offline
Newbie
View Profile
Thanks,  software side doesn't bother me much. I just need more info on the hardware side.
Do I just need a Arduino mother border, a ethernet shield and a DHT11? do I need do some wielding? or just wire connects?
And I heard DHT11 is not stable for temperature connection, any idea in that?
Logged
Brunsbüttel, SH, F.Rep.GERM
Offline Offline
God Member
View Profile
WWW
i like to use a LM35 solderd to an ATtiny13, which talks via a single cable...
the LM35 needs an analog pin and is quite accurate...
that should work with an arduino and UART/Ethernet, too...
Logged
-Arne
Offline Offline
Newbie
View Profile
ATtiny13 is cheap, it is good if it works, could you give me more info about LM35+ATtiny13 and talks to PC?
Thanks
Logged
Offline Offline
Newbie
View Profile
Also, what about LHT11 compare to LM35, I would rather do less soldering, if LHT 11 is not accurate enough, will LM35 be?
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
You haven't stated what level of accuracy (or more likely precision) that you require, but you can find those specs if you do a little googling. Also, if the sensor (just one sensor?) will not be within a few feet of the Arduino please state so.
Logged
Offline Offline
Newbie
View Profile
The sensor will be with Arduino, and thinking connect Arduino to main PC by ethernet. The idea is I can have a Arduino on-site to monitor everything and feed back to main server by wire.
Logged
Offline Offline
God Member
View Profile
WWW
do u mean this:
http://www.micropik.com/PDF/dht11.pdf ?
u need to measure humidity, 2?
this one is more accurate (regarding temperature), but unable to measure humidity:
http://www.ti.com/lit/ds/symlink/lm35.pdf
Logged
-Arne
Offline Offline
Newbie
View Profile
do u mean this:
Right, I know there are DHT11 and LM35, and kind know LM35 is more accurate, but as I asked above, they are not same, DHT11 is a board, while LM35 is just a part, not sure what are the right words for them, I mean it seems LM35 is very basic and need more welding work, not something just plug or wired like DHT11.
Logged
Offline Offline
God Member
View Profile
WWW
u can plug the LM35 into the arduino sockets, too...
without any soldering...
just wrap a wire tightly around its legs and then secure it with duct tape...
the DHT would need some wires, 2...
Logged
-Arne
Offline Offline
Newbie
View Profile
Thanks, that is what I want to know.
Logged
Offline Offline
God Member
View Profile
WWW
MacGyver rulz...  smiley-cool
Logged
-Arne
Belgium
Offline Offline
Full Member
Just Do it (with Arduino of course)
View Profile
DHT is not really "a board", but doesn't "need wires" either. It's probably best described as a thru-hole component ;-)
So you can either plug it in Arduino pins or in a remote PCB or solder wires on its pins.
The DHT22 (4-5USD in China) has a better (0.1 degree) resolution. But more important, it has a digital interface, hence is not sensible to analog noise on a wire ! Also sold as PCB modules with pull up and decoupling cap for  a few bucks more.
Logged
Pages: [1]   Go Up
Print
Jump to:
