Topic: serial interfacing (Read 878 times) previous topic - next topic
trvslamm
Hello all,
this seems very simple but being new to arduino and programming in general it is giving me a hard time. I have 3 sensors connected to analog inputs, with the arduino serial monitor i can only view one reading at a time. my question is this; is there a third party program that will take 3 inputs from the serial output of arduino and display them all on screen simultaniously?
AWOL
Quote
You've only got one A/D converter, so it sort of makes sense that you can view one result, but I don't see why you can't print all three results.
Post your code.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
trvslamm
Code: [Select]
void loop(){
digitalWrite(4, HIGH);
Serial.println(analogRead(0));//print bottom sensor value
delay(1000);//wait one second
Serial.println(analogRead(1));//print middle sensor value
Serial.println(analogRead(2));//print top sensor value
i see three values on the serial monitor, problem is i cant associate which value is which sensor
AWOL
Quote
Perhaps you should add a simple extra print to identify which is which.
liudr
Serial.print("Sensor 1:");
If you want the three numbers to appear on one line, do println for the last number. That println prints info and switches to a new line.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
AWOL
Or, even simpler, just print the three results on a new line.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
