Topic: (Solved)Arduino Uno only 1.5 volts from digital outputs instead of 5 volts (Read 15625 times) previous topic - next topic
wikitjuggla
i am trying to use my arduino with a rc receiver without pwm and a motor shield. i set my output speed pins to HIGH. i have 4 digital inputs for the receiver which just inputs 5 volts to the inputs and then is supposed to output to the corresponding motor shield pins and 6 digital outputs for the motor shield. i am using the if statement in my code telling the arduino to put HIGH power to the motor shield pins if it receives the high signal from the input pins but my arduino won't put out a steady 5 volts on the outputs, it only puts out 1.5 volts and sometimes it will vary on its own up to the 5 volts. when i run the motor shield demo sketch my arduino works just fine but i have tried 3 different sketches to make my set up work and can not seem to get it to work and have tried many different tests and determined it seems to be a problem with my arduino itself. Is it possible that this sketch is too much for the arduino to process? here is a copy of my primary code if someone thinks it is a sketch  problem. help would be greatly appreciated.
Code: [Select]
// Arduino code
// pins for r/c receiver
const int left = 2;
const int right = 3;
const int forword = 4;
const int reverse = 5;
// motor shield pins
const int pinI1=8;//define I1 interface
const int pinI2=11;//define I2 interface
const int speedpinA=9;//enable motor A
const int pinI3=12;//define I3 interface
const int pinI4=13;//define I4 interface
const int speedpinB=10;//enable motor B
 pinMode(pinI1,OUTPUT);
 pinMode(pinI2,OUTPUT);
 pinMode(speedpinA,OUTPUT);
 pinMode(pinI3,OUTPUT);
 pinMode(pinI4,OUTPUT);
 pinMode(speedpinB,OUTPUT);
 pinMode(left,INPUT); //my rc reciever input pins
 pinMode(right,INPUT); //which are not pwm compatable
 pinMode(forword,INPUT); //they put out what ever voltage
 pinMode(reverse,INPUT); //that is powering the reciever
 if (digitalRead(left) == HIGH)  {
   motor1_reverse();  // move left motor (motor1) reverse
   motor2_forward();  // move right motor (motor2) forward - this should make the robot turn left
   motor1_stop();  //otherwise, stop both motors
   motor2_stop();
 if (digitalRead(right) == HIGH) {
   motor1_forward(); // move left motor (motor1) forward
   motor2_reverse(); // move right motor (motor2) reverse - this should make the robot turn left
   motor1_stop();
   motor2_stop();
 if (digitalRead(forword) == HIGH) {
   motor1_forward();  // move motor1 forward
   motor2_forward();  // move motor2 forward
   motor1_stop();
   motor2_stop();
 if (digitalRead(reverse) == HIGH) {
   motor1_reverse(); // move motor1 reverse
   motor2_reverse(); // move motor2 reverse
   motor1_stop();
   motor2_stop();
// These functions make it easier to define the direction of each motor and the appropriate digitalWrite commands, so you can just call motor1_forward();
// You can change the code or names of any of these functions if your motors do not go the direction that they should.
void motor1_forward(){
 digitalWrite(pinI1, HIGH);
 digitalWrite(pinI2, LOW);
 digitalWrite(speedpinA, HIGH);
void motor1_reverse(){
 digitalWrite(pinI2, HIGH);
 digitalWrite(pinI1, LOW);
void motor1_stop(){
 digitalWrite(speedpinA, LOW);
void motor2_forward(){
 digitalWrite(pinI3, HIGH);
 digitalWrite(pinI4, LOW);
 digitalWrite(speedpinB, HIGH);
void motor2_reverse(){
 digitalWrite(pinI4, HIGH);
 digitalWrite(pinI3, LOW);
void motor2_stop(){
 digitalWrite(speedpinB, LOW);
spcomputing
You need to put your code in a "Code Block" (The pound (#) icon).
Anyhow, check out this thread:
http://arduino.cc/forum/index.php/topic,122825.0.html
Sounds like it might have the tips you are looking for.
Grumpy_Mike
Quote
No, a sketche's complexity has no effect on the digital output pins.
From your description it sounds like you are not setting the pins to be an output, however that code shows you are. The other thing is that you might be overloading the outputs, that is drawing too much current from the.
A schematic of what you have would be good.
fungus
i am trying to use my arduino with a rc receiver without pwm and a motor shield. i am using the if statement in my code telling the arduino to put HIGH power to the motor shield pins if it receives the high signal from the input pins but my arduino won't put out a steady 5 volts on the outputs, it only puts out 1.5 volts and sometimes it will vary on its own up to the 5 volts.
You're trying to drive motors directly from the Arduino pins? It won't work, motors draw too many amps. That's why you need a motor shield.
Don't continue without one. You can damage your Arduino.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
MarkT
We are told there is a motor shield, the output pins are driving that.
We are also told the motor demo works.
My suspicion is something to do with the supply voltage or common grounding is awry - a schematic of the wiring might be useful, but I'd suggest checking that all the supply voltages are correct during operation and all grounds are common.
wikitjuggla
i haven't been trying to drive the motors from the digital pins themselves, i have been testing my arduino by using the button wiring setup from the 5 volt pin output and connecting it one at a time to my input pins and testing my outputs with a multimeter and an LED and i just can't seem to get it to work right. as for a schematic i don't really have one since i haven't started much of a project, just been trying to get this rc thing to work and go from there and i am pretty new at this stuff, the motor shield just stacks on top of the arduino and i have been testing my arduino without anything connected to it and it still doesn't work right because at first i thought i had wired something wrong. thank you for your input
retrolefty
Quote
If you are testing the outputs by wiring a led to it and not using a series current limiting resistor, then you are causing too much current to be drawn from the output pin which will reduce it's output voltage as well as risk damage to the pin and the led.
Lefty
wikitjuggla
i am using a 270ohm resistor for the LED and i test the outputs with the multimeter w/o the LED connected
Grumpy_Mike
So when you remove the connections to the motor driver does the voltage recover?
retrolefty
Good. So are you sure whatever sketch you are using during these 'tests' is writing a steady HIGH output and not switching between high and low at some rate, as your meter will give a lower voltage reading in reponse to a changing digital output?
Lefty
wikitjuggla
Quote
Posted on: Today at 07:47:26 AM
Posted by: Grumpy_Mike
Insert Quote
No my voltage does not recover, my first thought was that i had caused a short circuit which would make my voltage drop but that was not the case
Quote
the above sketch is my primary sketch that am using and i have tried sever different variations of that sketch and seem to always get the same result. one of the sketches i wrote will give power to the motor pins correctly but the speed pins will sometimes work and sometimes not
nickgammon
Read this before posting a programming question
Quote
Which pin, exactly?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
wikitjuggla
pins 9 and 10 but depending on the sketch sometimes all of my designated output pins
retrolefty
I suggest you write a very simple sketch that in your setup function you make all pins output mode and set to HIGH and just have your loop function empty. Then go measure the output voltage on all the pins to gain confidence in your controller chip and your measurements, then report back.
Lefty
wikitjuggla
well each and every one of my outputs measured 5 volts on the money so that would probably signify its a problem with the sketch one would assume?
