Topic: Is it possible to use the digital OUTs as INs? [SOLVED] (Read 10016 times) previous topic - next topic
MDTech-us_MAN
#15
Oct 05, 2012, 09:14 pm Last Edit: Oct 06, 2012, 04:11 am by MDTech-us_MAN Reason: 1
Answer 1:
internal pullups:
Code: [Select]
  pinMode(53, INPUT);// assumes switch closure connects pin to Gnd
digitalWrite (53, HIGH);
// IDE 1.0.1 also supports:
pinMode(53, INPUT_PULLUP); // seperate digitalWrite not needed
EXACTLY! that is what I needed!!! I needed the digitalWrite part! The INPUT_PULLUP does not work on pins 22-53 on the Arduino Mega.
My aim is to make a miniature keyboard. (I will need 38 buttons for that  :) :P )
Where can I get A LOT of cheap miniature buttons?
CrossRoads
"The INPUT_PULLUP does not work on pins 22-53 on the Arduino Mega."
Really! Have to tuck that one away.
retrolefty
Well I would like to see a reference source for that before tucking it away?
Lefty
MDTech-us_MAN
Thanks for the help!
No now, I have 1 more question, where can I get 38+ miniature buttons?  :P
retrolefty
At a elves tailor shop?
CrossRoads
Is there something here that does do the Mega pins?
https://github.com/arduino/Arduino/commit/76c964d32b13f1fc01e3a5b07460d96f2dcaecd6
How small of a button? Like a tactile switch? Through hole? Surface mount?
MDTech-us_MAN
Lefty
I tried. But, someone else needs to confirm too (mine might be defective or damaged during the shipment from Hong Kong to Pennsylvannia, US).
CrossRoads
Arduino Mega's come from  Hong Kong now? Or did you get a clone?
retrolefty
Lefty
Well I sure would be suprized if that was the case. I just did a quick check on a copy of the Atmel mega1280 datasheet and it doesn't seem to exclude any pin or ports from having the avalible optional internal pull enabled:
Quote
13.2 Ports as General Digital I/O
The ports are bi-directional I/O ports with optional internal pull-ups. Figure 13-2 shows a functional
description of one I/O-port pin, here generically called Pxn
Lefty
MDTech-us_MAN
Lefty
Quote
Lefty
I have the ATMega2560 chip
Most likely is a worker of a factory that took it off the conveyor, put it in a package and sent it to me. LOL  :P :smiley-sweat:
About as small as the reset button on the Arduino, but, with only 2 legs.
I want something that might fit on a breadboard.
Maxwell D.
retrolefty
The same datasheet covers the 'family' of:
Quote
ATmega640/V
ATmega1280/V
ATmega1281/V
ATmega2560/V
ATmega2561/V
Lefty
MDTech-us_MAN
Quote
ATmega640/V
ATmega1280/V
ATmega1281/V
ATmega2560/V
ATmega2561/V
Lefty
Well... lets call it undecided. :~
Now All I need are the buttons. 8)
Quote
Maxwell D.
CrossRoads
Search for switch at taydaelectronics.com, lots of 4 pin tactile switches to choose from.
I have some 2-pin tactile switches like those, no idea where I got them.
Checked all the usual sources and am not seeing them.
They look like this
http://www.mouser.com/ProductDetail/CK-Components/PTS635VH39-LFS/?qs=sGAEpiMZZMsgGjVA3toVBBpDTNTTW0j3YRB1%252bcCi%2fno%3d
MDTech-us_MAN
They look like this
AWESOME! I will buy at the link you posted. But, will that button fit on a breadboard if I straighten the legs and maybe make them more rounded ?
MDTech-us_MAN
I found more buttons at http://www.pololu.com/catalog/product/1400 but they cost $0.72 each for 10-100, which will be $31.20 for 40 buttons (a lot for me).
