Pages: [1] 2 3 4   Go Down
Author Topic: Is it possible to use the digital OUTs as INs? [SOLVED]  (Read 1811 times)
Hello ALL,
How is it possible to use the pins named "DIGITAL" as digital INs?
Final answers:
1. http://arduino.cc/forum/index.php/topic,125731.msg946047.html#msg946047
2. http://arduino.cc/forum/index.php/topic,125731.msg946400.html#msg946400
« Last Edit: October 06, 2012, 07:42:35 am by MDTech-us_MAN » Logged
Maxwell D.
Owner and Webmaster of www.MDTech.us
If you are asking if they could be used as inputs and outputs, then yes all you have to do is say if it is an input or output in the void setup, here is more http://arduino.cc/en/Reference/Setup
As jonathanped said, they can be used for either input or output.  You have to call the pinMode function
So to make digital pin 10 an input
pinMode(10, INPUT);
To set it for output
pinMode(10, OUTPUT);
One thing to add though is that it doesn't have to happen in the setup function but almost always that is where you want to set it.   It can be set anywhere at anytime and you can even change the mode in the same program.  This is rare however and the only time I can think when one does this is with the PING sensor which requires you to send and receive a signal on the same pin.
Hope that doesn't add to the confusion.  smiley
Ok, how do I print "0" or "1" if the button on pin 53 is pressed and the other number if not.
Maxwell D.
California
Online Online
Have you looked at any of the examples that come with the Arduino software?
Have you tried a felt / marker type pen?
"Ok, how do I print "0" or "1" if the button on pin 53"
pin 53? if (digitalRead(53)==true)
    Serial.println("Pin 53 is true");
 //sort of, is it printlin or writeln, i can never remember unless front of the IDE.
it IS println I'm currently testing that...
Maxwell D.
Seattle, WA USA
Seattle, WA USA
The digitalRead() function returns HIGH or LOW, not true or false. If you are going to do an explicit compare, as you should, then use the right thing on the other side of the equality operator.
Wiscon
Admin whatisacnc.com
Hello ALL,
First choose the programming language you want to use for building an interface (GUI).
Second you set the I/O as either "high" or "low" to receive and send data, so if you wanted to use I/O Number 9 to turn a servo motor either right or left you can do it pretty easily.
Here is some VB.NET 2010 code for the computer side, AKA your GUI.
All you need are two buttons...
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        With SerialPort1
            SerialPort1.Close()
            SerialPort1.PortName = "com4" 'change com port to match your Arduino port
            SerialPort1.BaudRate = 9600
            SerialPort1.DataBits = 8
            SerialPort1.Parity = Parity.None
            SerialPort1.StopBits = StopBits.One
            SerialPort1.Handshake = Handshake.None
            SerialPort1.Encoding = System.Text.Encoding.Default 'very important!
        End With
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        SerialPort1.Open()
        SerialPort1.Write("3")
        SerialPort1.Close()
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        SerialPort1.Open()
        SerialPort1.Write("4")
        SerialPort1.Close()
    End Sub
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
        End
    End Sub
As you can see the "SerialPort1.Write("4")" and "SerialPort1.Write("3")"  under each button are the commands being sent to the Arduino threw USB in the form of a packet.
As you can imagine the sketch has the number 3 and 4 defined as I/O 9 and each one moves the motor 180 degrees from each other.
Hope this helps,
Rob
http://whatisacnc.com
The frustration of a CNC
Austin, TX
Online Online
CMiYC
Hello ALL,
What on earth does this have to do with the original poster's question?
www.cmiyc.com - A guide to being an Enginerd
Wiscon
Hello ALL,
How does it not relate to the posters question?
I am saying yes you can "use the pins named "DIGITAL" as digital INs"
At least this is my take on it, maybe I am wrong?
Whats the problem?
Whats the problem?
The original poster was asking if an Arduino sketch that can perform digital reads on the digital pins.   You stated you need a GUI front end and then proceeded to give him a Visual Basic program that talks over the serial port (and you left out the corresponding sketch to boot).
Discussing a GUI front end in VB it is about as far away from "is it possible to use the pins named "DIGITAL" as digital INs" as one can get.
Not trying to be a jerk about it but your post is a bit off topic.
Hello ALL,
Whats the problem?
YES, Thanks for the VB code! (I would need it later any way), but, I need the -> ARDUINO <- code now.
I need to accurately print the current state of the button (1 if pressed, 0 if not). If I use:
Serial.println(digitalRead(53));
I get a VERY in accurate result (takes time to switch from 0 to 1 (first a couple 1s here and there then more and more and finally everything is 1)).
Is the a better way?!
Setup code:
pinMode(53, INPUT);
Maxwell D.
EDIT: Now I get ALL 0s:
Entire code:
  pinMode(53, INPUT);
« Last Edit: October 05, 2012, 01:12:13 pm by MDTech-us_MAN » Logged
Maxwell D.
UK
How is the switch on pin 53 connected.
You're not using the built-in pull ups; what else have you got on that pin?
Boston area, metrowest
Online Online
internal pullups:
  pinMode(53, INPUT);// assumes switch closure connects pin to Gnd
digitalWrite (53, HIGH);
// IDE 1.0.1 also supports:
pinMode(53, INPUT_PULLUP); // seperate digitalWrite not needed
Pages: [1] 2 3 4   Go Up
