Topic: Sunlight readable graphic displays (Read 2269 times) previous topic - next topic
bcthom
Hi
Can anyone reccomend a graphic display that is readable in bright light conditions - preferably full sun. I am currently using Displaytech 128x64 pixel monochrome display and the GLCD library. Everything is really good except I cant read it outdoors. I have destroyed one display already by increasing current in backlight to the point where the LEDS failed.
I have heard OLED displays are better, but because they are usually colour they are very slow, I need to refresh parts of the display 3 or 4 times per second.
Grateful for any help
olikraus
For monochrome OLEDs, the Arduino does not need to transfer too much data.
So 3 to 15 FPS should be possible with U8glib (depends on the display content):
http://www.newhavendisplay.com/nhd2712864ucy3-p-3621.html
EA offers displays for different environment conditions.
http://www.lcd-module.com/eng/pdf/grafik/dogm128e.pdf
For bright light conditions you probabaly want a display which is readable without backlight: DOGM128L or DOGM128W.
Backlight LED is sold as an option for the DOGM128, it can be replaced if damaged  ;)
i think the trick is, not to use the backlight LED at all, but let the sun do the lightning work for you.
Both displays are supported by U8glib (http://code.google.com/p/u8glib/)
Oliver
dhenry
dhenry
Should have a resistor there.
