Topic: Processing input emulation (Read 2340 times) previous topic - next topic
epicepee
As one of my first Arduino projects, I plan to turn the carriage (Is that what it is called? the slidey thing) from an old CD drive I got hold of into a linear webpage scroller. The motor that used to control it seems to be a simple DC motor, and is geared to the carriage. I plan to use Firmata and Processing to get the voltage from the two leads from the motor, and use Processing to emulate a hardware scroll wheel. ANy advice?
PaulS
How, exactly, do you propose to do that?
epicepee
I was planning on using the built-in pin-by-pin control. However, I decided to simplify this and just transmit the motion over serial.
The Arduino code:
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  int voltin0 = analogRead(A0);
  int voltin1 = analogRead(A1);
  Serial.println(voltin0 - voltin1);
  delay(5);
I haven't written the Processing code yet.
PaulS
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
The A0 and A1 aliases are for when you want to use analog pins as digital pins. That's what this part looks like you want to do.
But, this part of the code looks like you want to use the analog pins as analog pins. In which case none of that crap in setup() belongs there, since analog pins are, by definition, INPUT, and you do not want to be turning on the pullup resistors. Also, you want to use 0 and 1, not A0 and A1, to make it clear you know what you are doing.
  delay(5);
So, every 5 milliseconds, you want to write potentially the same value, as a string, to the serial port.
I'd think that it would make more sense to only write when the value changes.
If what is connected to the two analog pins is from the two sides of the motor, the voltage at those pins will be the same, so you will be writing a continuous stream of 0 to the serial port.
I can't see that being useful. Even if you measured accurately the voltage or current applied to the motor, how would that information be useful? What, exactly, is that motor doing?
What, exactly, is a "linear webpage scroller"?
epicepee
I have the hardware side totally working at this point, the only problem is mouse emulation.
I am pulling both pins up, then hooking the two leads from the DC motor to them. When I spin the motor, which I am using as a makeshift encoder (kludgy, yeah, but I don't have an optical encoder, and it fits perfectly), one pin gets pulled down, and the serial output is (pin1 - pin2), so it outputs the difference between them. Pulling them up is to keep them from floating and randomly scrolling tiny amounts.
A "linear webpage scroller" is like http://www.instructables.com/id/Spinner-Jog-Wheel-Inside-of-a-VCR-Head/, but linear instead of circular. You know, for ebooks and long webpages.
