Topic: Export Leonardo second serial port as a tty on Linux and COM under windows (Read 1 time) previous topic - next topic
ynsta
I would like to be able to use the second serial port of the Leonardo (pin 0 & 1) through USB.
Is there an easy solution to export this port to my OS as a COM port on Windows and a ttyUSB on linux. (There is already one exported for the bootloader and communications through Serial.*)
More generally, where is the good place to code usb capability extensions for the Leonardo (Ideally available from sketches).
I think it's in hardware/arduino/cores/arduino/USBAPI.h
I'm new to Arduino, but I'm experienced in bare mcu programming.
Thanks.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
