Topic: Debounce in Bulk (Read 4030 times) previous topic - next topic
Coding Badly
Oct 05, 2012, 10:22 am Last Edit: Oct 05, 2012, 10:58 am by Coding Badly Reason: 1
Debouncing 14 digital pins using only 30 bytes of SRAM...
static const int NUM_PINS = 14;
uint16_t PreviousMillis;
typedef struct
 uint8_t stage;
 uint8_t previous;
debounce_t;
debounce_t debounce[NUM_PINS];
void setup( void )
 for ( uint8_t i=0; i < NUM_PINS; ++i )
   pinMode( i, INPUT_PULLUP );
   debounce[i].stage = 0xFF;
   debounce[i].previous = 0xFF;
void loop( void )
 uint16_t ThisMillis;
 ThisMillis = millis();
 if ( ThisMillis - PreviousMillis >= 3 )
     debounce[i].stage = (debounce[i].stage << 1) | digitalRead( i );
     if ( (debounce[i].stage != debounce[i].previous)
         && ((debounce[i].stage == 0x00) || (debounce[i].stage = 0xFF)) )
       // 8 bits * 3 milliseconds per bit = 24 milliseconds at the same state
       // debounce[i].stage is the state of the pushbutton
       debounce[i].previous = debounce[i].stage;
   PreviousMillis = ThisMillis;
marcello.romani
- pedantic mode on -
#define NUM_PINS 14
- pedantic mode off -
:P
Also:
digitalRead( 2 )
or
digitalRead(pinNumber[i])
(but some more SRAM bytes...)
Coding Badly
#2
Oct 05, 2012, 10:54 am Last Edit: Oct 05, 2012, 10:59 am by Coding Badly Reason: 1
digitalRead( 2 )
...fixed.
pedantic...
...as you wish.
marcello.romani
_pedantic mode on myself on_
dont' use #defines, use const ints
_pedantic mode on myself off_
:smiley-roll-sweat:
