Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Running high power led's without drivers.  (Read 3256 times)
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Well I think the OP has probably checked out and we are just all preaching to ourselves.
Probably didn't get the answers he was hoping for. smiley-wink
Logged
Offline Offline
Edison Member
View Profile
Quote
Another thing: The voltage range for (eg.) my LED at 700mA is:
Min: 2.79   Typical: 3.55   Max:3.99
Q: Given the above curves and the variance in voltage, what value resistor should you pick...?   A: Don't even try.
Wrong question.
Quote
This is also why you don't commit sin number (2) of the original list, ie. connect LEDs in parallel.
Q: What happens if you pair a 2.79V LED with a 3.99V LED?    A: The 2.79V LED doesn't last very long.
It is actually a lot more complicated than that, and again, not answerable based on the information you have.
Now, I can turn it around and ask a better-defined question: if you were to power the 2.89v/3.99v led pair from a 12v source + 12ohm resistor, which led will light up? and why?
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Maybe. LEDs seem so simple when you only have a little knowledge - you just apply a voltage and they light up!
Still, it's fun to look at some real-life curves as a bit of revision.
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
From the curves I just looked at it would make a great thermometer, a remote unit with controllable constant current sourcing for an led and a photo cell might well be an accurate CDS LDR based thermometer from the near strait line delta in light output. The simple advantage would be that anyone could build and calibrate one.
 Relatively inexpensively too and extremely unusual use of available technology...   IMO
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
BTW, consider extending the curve Fungus posted, which tops out at about 3.7, to the 4.2V that a fresh li-ion is capable of sourcing...
Logged
Offline Offline
Newbie
View Profile
Direct-drive works, but it's the most annoying way to drive an LED.  The light output starts out very high, then declines rapidly (exponentially), but full depletion takes a long time and isn't necessarily matched to the minimum voltage that the battery can tolerate.
Logged
Offline Offline
Edison Member
View Profile
Quote
At that point, current is exactly 0ma.
Logged
Offline Offline
Edison Member
View Profile
I've trie this "overclocking" method just out of curiosity,  I mounted the led to a copper heatpad(about 12 ga thick) mounted to a thermoelectric cooler, mounted to a large aluminum heatsink with 2 fans,
I powered a 3.8v UV led with 5v directly from a computer psu and pushed 3.8 amps thru it(almost 11x current and basically 120x the heat) and it worked fine for hours without me noticing it being any dimmer, until I powered it back at 350ma compared to a fresh one and realized it was 1/10 as bright at the same current, it was being damaged in regards to light output
basically after wastig the 3$ led I found there is no point in exceeding the limits, just like everyone else says
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Looking at the graphs again: I'm wondering if it might be possible to get more light from a LED by running it at less than rated current if your heatsink isn't perfect.
eg. If you get 20% less light output at 70 degrees C, could you get the same light by running it at 450mA and not heating it up so much? Most of these LEDs get far too hot to touch if you run them at rated current so the loss due to temperature must be very real.
Logged
Offline Offline
Edison Member
View Profile
Possible but not likely.
The light output doesn't go down as much. For this particular device, light output goes down 10% from 25 -> 75c, and down another 15-20% from 75c -> 150c.
The problem of high current for high-powered leds is really high temperature (from a thermal run-away) and the resulting low life (which leads to low light output in the long run).
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks for all the replies.  I admit, some of the info in the debates was a little over my head, but I realize now theres not much point in running the LED's without a driver.
I'm still confused though why my numbers aren't adding up on this setup I made.  I have some 3w led's that say they are rated at 700ma max current.  I also bought a driver that is supposed to put out 2800ma.  Seems like a perfect fit, 4x 700 = 2800ma. I wired up the driver, and had 4 of these led's in parallel, and using a 18650 battery, which is a single cell lithium ion battery.  However, at full power, this setup  only seems to be drawing about 700ma for all 4 of them, not the 2800 I was expecting.  I read specs on the 18650 battery, brands vary, but they all seem to put out a minimum of 3 amps, many putting out 9 amps.
Out of frustration I did bypass the driver and hooked the battery directly up to the 4 led's in parallel, and they were only pulling 1A, again not the 2800 I was expecting. (note: one person claims i damaged the led's doing this, but I only did this AFTER already having hooked them up through the driver, and them only drawing 700ma)
PS: I was expecting these 4 led's to total 12w of power, and be a touch brighter than my cree xml-t6 flashlight which uses a single led which is 10w, but as is, they are nowhere near as bright.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Which driver are you using?  The behavior you're describing pretty much matches what I'd expect to see with a "buck" or step-down driver intended for 2*Li-Ion cells in series (8.4V input.)  For example, this driver claims to put out 2800mA, and explicitly says that it is designed for 8.4V input.
Driving a high-power LED from a single LiIon cell is actually somewhat difficult, because power supply circuits that output a voltage NEAR their input are atypical.  (Of course, driving LEDs has become a popular application, and there ARE circuits that will do this, but you have to make sure you get the right one...)
The direct-connection behavior is harder to explain.  But since white LEDs have a voltage requirement of about 3.7V, and the battery has a nominal voltage of about 3.7V (which might be expected to "sag" somewhat under heavy loads), it could be that the battery just isn't capable of driving the 4 parallel LEDs at full power.  (that's not a good sign for running them from a driver, either.  But it might work.)
Logged
Offline Offline
God Member
Arduino rocks
View Profile
The 18560 cells are available both with and without charge/discharge limitation. If you have cells with built in protection, this could explain why they max out at 1A.
Logged
Offline Offline
Newbie
View Profile
Quote
No two LEDs are exactly the same! One of the for LEDs you wired in parallel will start conducting at a slightly lower voltage than the others. This one will get most of the current, and limit the voltage (and thus the current) for the other LEDs. If the difference between the LEDs is large enough, the conducting one can actually get a lot more current than it's rated for, and become a SEDD (Smoke Emitting Dead Diode), after that the other LEDs will follow one by one. Each LED MUST have it's own current control wired in series. In your case, the forward voltages were close enough to prevent instant meltdown, but in the long run the LEDs would have failed one by one. If you want to drive 4 LEDs you can wire them in series using one 700 mA driver (this requires a higher voltage or a step-up driver), or in parallel using four separate 700mA drivers.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Quote
While this is true in theory, the reality is that a set of LEDs from the same batch seem to match Vf pretty closely, and the number of commercial products that parallel LEDs directly and still seem to work (with even brightness) pretty well is quite large.
To demonstrate the effect, try paralleling a red and green LED after the current limiting resistor.
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
