Loading...
Pages: 1 [2]   Go Down
Author Topic: What to use for a Light Barrier ?  (Read 1404 times)
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
I already also heard, that the batteries are a bit more than 1.5V, maybe 1.6V or 1.7V. A new "1.5V"-battery I measured had a bit more than1.6Volts. That means that 1.6V*3=4.8V should be definitely still in the acceptable range for the laserpointer. Most of them are from China and hence don't have a manual with technical parameters.
The new Nickel-Zinc batteries are 1.8 volts when fully charged and a nominal voltage of 1.65 (http://en.wikipedia.org/wiki/Nickel%E2%80%93zinc_battery).
I recall last year in the camera forums, people were shouting about using the new NiZn batteries because it sped up their flash recharge times, and then about 6 months later reality set in, when it became apparent that some/all flashes weren't prepared for the higher voltage.  And if you mentioned using NiZn batteries, manufacturers might not honor warranties (http://strobist.blogspot.com/2011/01/nizn-batteries-long-term-update.html).  smiley-roll
Logged
USA
Offline Offline
God Member
View Profile
The new wave NiZn recharagables have some interesting features, and the nominal voltage much closer to alkalines is one of them.  However, this does illustrate the point I was making rather well, you have to ensure your device can handle the total voltage of a battery pack at all charge levels.  Otherwise it can cause malfunctions and/or damage.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
