Topic: How to control the display's backlight in the sketch? (Read 20478 times) previous topic - next topic
floresta
You always need a current limiting device when using an LED and a resistor is the simplest one you can have. Anyone who tells you different is wrong.
I was going to say the same thing but then I figured that someone would point out the exception, which would be if one happened to be using a current limiting supply.  Even then the resistor wouldn't hurt anything.
I agree - you should always use a current limiting resistor.
Don
Grumpy_Mike
This is covered by the "current limiting device " part of my statement.  :)
floresta
dhenry
But I'm confused: do I really need a resistor if I limit the PWM output to 3.3v (as in my code) ?
PWM 3.3v only means that the arduino is outputing 5v 3.3v/5v = 66% of the time, and 0v 33% of the time.
However, the answer to your question is yes and no.
Yes, you need a resistor for a proper design.
No, you don't need a resistor as the pin's internal limitations in its current capabilities serve as a "resistor", and the diodes are one of those electronic devices that can take a lot of abuses temporarily.
I would put one in myself. But I would encourage you to experiment by not putting one in just to see for yourself.
In case you are asking, I have shorted avr's output pins (when outputting a logic 1) without damaging any.
runaway_pancake
So I think I don't even need to add a resistor!
Sorry, I'm still newb to electronics :)
Why do they always fight "the resistor"?
Why resist?
Is it "the expense"?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
guix
#20
Oct 07, 2012, 01:35 am Last Edit: Oct 07, 2012, 01:58 am by guix Reason: 1
Okay but here: http://arduino.cc/en/Tutorial/PWM
I can read:
This on-off pattern can simulate voltages in between full on (5 Volts) and off (0 Volts) [...] The result is as if the signal is a steady voltage between 0 and 5v controlling the brightness of the LED.
So I supposed, limiting the PWM as in my code, will output a steady 3.3V. :smiley-zipper: Then, I used a led resistor calculator (the parallel calculator, since I suppose the LEDs of my display are mounted parallel)... which tell me that I need a resistor of 1 Ohm (AKA: I don't even need a resistor), when the input voltage is the same as the forward voltage of the LED, and doesn't matter how much current I enter as the "desired LED current".
Guys, I'm lost...
Why resist?
I don't, in fact I planned to add a resistor since the first post. I'm just wondering why I need one when a calculator tell me otherwise.
Put simply, I don't see what is the difference between these two:
PWM 66%  ---------> LEDs
PWM 100% ---[R]---> LEDs
dhenry
But that's the wrong assumption.
If you look at the page you linked to, the pwm waveform has a voltage output of either 5v or 0v, at any given point. If you were to held a steady 5v to your 3.3v led, it would have burned out quickly.
What pwm is doing to leds is to turn on the leds, abusively at 5v, quickly. Because of pov, the led looks dimmer when the duty cycle goes down.
The nice thing about diodes is that they are very good at taking high peak current for a short period of time  - sometimes 100x or 200x of their rated current.
floresta
In addition to everything in the previous post you have to also understand that:
(1) You do not know what the forward voltage of the LED might be.
(2) Even if you determine what it is for one diode under one particular set of circumstances it would be different ...
  (a) for a different diode under the same circumstances.
  (b) for the same diode under different circumstances.
  (c) for a different diode under different circumstances.
In other words - if you to try to design a circuit to drive an LED with some specific voltage you are doomed to failure.
Did you ever consider why it takes so long to earn an Engineering degree?
Don
dhenry
Ouch. That's harsh.
dhenry
Nothing says that you have to have resistors. All you need to know is why you may need resistors and what risks you are running without resistors, so that you can make an informed decision.
guix
#25
Oct 07, 2012, 06:17 am Last Edit: Oct 07, 2012, 06:53 am by guix Reason: 1
Ok, another try (before I give up :))
In this exact situation (for now, I don't need to know in other circumstances..), let's say my multimeter show: 20 mA
3.3V, 20 mA, no resistor between Arduino's 3.3v pin and LED-A pin. There may be a resistor between LED-A pin and LEDs, or not, I don't care.
So for 5V, using a PWM output instead of the trimmer, I would just need to add a resistor of value (5-3.3) / 0.02A = 85 Ohm, between the PWM output and LED-A pin.
Am I wrong once again?
codlink
I've attached what looks like info on that shield including datasheets, manuals, library, and example code.
I found more than one document so I attached them both.  Some are different, some are the same.
//LiNK
guix
#27
Oct 07, 2012, 06:49 am Last Edit: Oct 07, 2012, 06:51 am by guix Reason: 1
codlink, thanks for trying to help but I already have those documents: there is nothing in them, about backlight :)
codlink
//LiNK
dhenry
The answer will depend on your multi-meter. If it is a multimeter that reads "average" (an analog meter or an rms meter (not quite but close)), your math then works.
I think you are overthinking this. Put a resistor (start with something safe like 330) in, power it to rail (5v), and find a resistor value that gives you more light than you want, as your pwm will dial back the (average) current later.
Then  you are done.
