Loading...
Pages: 1 [2]   Go Down
Author Topic: Sound Localization  (Read 2130 times)
Offline Offline
Newbie
View Profile
So as well as the code for determine the position of the servos that you mentioned should i also remove this
Code:
for ( uint8_t i = 2; i < MIRROR; i++)  // LIMITS: 150 HZ
        {                                      // Electrical grid interference, Motor Vibration.
          vremn = 0;
          if ((x_r[0][i] != -1) && (x_r[1][i] != -1))
            vremn = x_r[0][i] - x_r[1][i];
            if (vremn >  1024) vremn -= 2048;
            if (vremn < -1024) vremn += 2048;
            vremn = (32 * vremn) / i;
            vremn -= 256;                      // MIC Time Offset Correction (1 ADC, 25 usec delay).
          if (lokaVect[directin][i] < vremn) lokaVect[directin][i] += srvoAccl[directin];
          if (lokaVect[directin][i] > vremn) lokaVect[directin][i] -= srvoAccl[directin];
Or just a section of this, as it is filtering the motor sound right?
Thank you
John
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
No, chunk of code is filtering multipath propagation / reverberation
Logged
Offline Offline
Newbie
View Profile
This is the code i am currently employing however i am fairly sure my coefficient is completely wrong. I understand it should have a relation to the distance of the microphones but not sure how to calculate or determine what this should be. Do I need to workout what the average time it would take for the sound to travel the distance between them and use that as the coefficient?
I have tried a few completely random values for this but as im sure you can guess had no positive results.
Code:
float coefficient = 400;
float soundAngleY = srvoPosn[y];
soundAngleY = asin (coefficient * summa / 2048.0) * 180.0 / PI;
Logged
Montreal
Offline Offline
Edison Member
View Profile
WWW
Key is the arcsin function definition [-1; +1].  Print out "summa" via serial and see what you get. Than you adjust coeff. so total parameter passing to arcsin would be -1 < p < 1.
 Sound wave coming "flat" to both mics, should produce summa=0, shifting left-right 'd change sign and magnitude.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
