Topic: Amarino (Read 2378 times) previous topic - next topic
ygobi
Hello, I've ordered a motor shield and I want to make this project at http://arduino.cc/forum/index.php/topic,90809.0.html but my motor shield used is the ladyada motor shield and the code is written for another motor shield. I've tried to fix this so it would work with my motor shield which is coming some time soon, it seems to compile without any errors but I just want someone that knows way more than me at this to help and see if this would work.
#include <AFMotor.h>
AF_DCMotor frontleft(1, MOTOR12_64KHZ);
AF_DCMotor frontright(2, MOTOR12_64KHZ);
AF_DCMotor backleft(3, MOTOR34_1KHZ);
AF_DCMotor backright(4, MOTOR34_1KHZ);
//Acceleration sensor from the smartphone is used to drive the robot forward backwords left and right
//inspired from http://www.arduino.cc/playground/Code/HTCDesire
//arduino + amarino + HTC Wildfire
#include <MeetAndroid.h>
#define IDLE 0
#define RINGING 1
#define OFFHOOK 2
MeetAndroid meetAndroid;
    meetAndroid.registerFunction(phoneorient, 'A');
      int input=0;
      frontleft.setSpeed(255);
      frontright.setSpeed(255);
      backleft.setSpeed(255);
      backright.setSpeed(255);
    meetAndroid.receive(); // you need to keep this in your loop() to receive events
  void phoneorient(byte flag, byte numOfValues)
    //Phone Orientation Controller
    int values[]={0,0,0};
    meetAndroid.getIntValues(values);
  int Steer=values[1];   //
  int Delta=values[2];   //
  int Heading=values[3];    //
  if (Steer >=5)
    {   //left
    frontright.run(BACKWARD);
    frontleft.run(FORWARD);
    backleft.run(FORWARD);
    backright.run(BACKWARD);
  else if (Steer <=-5)
  { //right
    frontright.run(FORWARD);
    frontleft.run(BACKWARD);
    backleft.run(BACKWARD);
    backright.run(FORWARD);
   else if (Delta >=5) { //forward
     else if (Delta <=-5) { //back
    frontright.run(RELEASE);
    frontleft.run(RELEASE);
    backleft.run(RELEASE);
    backright.run(RELEASE);
    Serial.println(values[1]);  //Throttle  , Pitch
    Serial.println(values[2]);  //Steering, Roll
    Serial.println(values[3]);  // Heading, degree
It's a 4WD ground robot, I'm using a Galaxy Nexus and going to use a JY-MCU bluetooth module. Please reply to this thread, it would really help.
ygobi
And I almost forgot, I want to add LED's to this project, which 4 pins would be available for my needs?
PaulS
You would need someone else with an Android phone and a LadyAda motor shield to tear their project down and set yours up, to test that code. What do you suppose the odds are of that happening?
Just looking at the code, though, I can tell you that it won't work. It isn't just a shield issue, though.
A hint: Array indices start at 0.
nickgammon
       int input=0;
What does "input" do?
ygobi
I'm not sure, should I remove it?
nickgammon
Yes, it's not doing anything.
As PaulS hinted, this is wrong:
Arrays start at 0, not 1. So (other things being equal) that should read:
  int Steer=values[0];   //
  int Delta=values[1];   //
  int Heading=values[2];    //
holmes4
Do one thing at a time - so first work on the motors drop all the rest!
Then sort the BT.
Then added them together.
But while you wait for the motor shield you could try making the built in LED on pin 13 blink.
Mark
