Topic: Uncertain where to post this, is this coding correct? (Read 2520 times) previous topic - next topic
packocrayons
This is my first writing of arduino code and I'd like to know how well I've done.
The program is used to do two things:
1. fade one LED up and down in brightness.
2. Change the color of a multi color led from green to red.
This is to be loaded onto an arduino nano and more will likely be added.
Please tell me whether it is done correct or any tendencies that could compromise my coding at a more advanced level.
Code: [Select]
const int fadingled = 9; //fading led pin
const int brightness = 0; //brightness of the led
const int fadeamount = 5 //how much the led fades
const int colorchange1 = 11; //red dual color pin
const int colorchange2 = 12; //green dual color pin
int colorledstate1 = LOW; //red led state on/off
int colorledstate2 = LOW; //green led state on/off
long previousmillis = 0; //last time LED was updated
long interval = 500; //time between flashes
void setup()   {
  pinMode(fadingled,OUTPUT); //declare all LED's as outputs
  pinMode(colorchange1,OUTPUT);
  pinMode(colorchange2,OUTPUT);
void loop()   {
  analogWrite(led, brightness); //set the brightness to the LED
  brightness = brightness + fadeamount; //add or subtract to the brightness based on fadeamount
  if (brightness == 0 || brightness == 255) {
    fadeamount = -fadeamount;
  unsigned long currentmillis = millis();
  if currentmillis - previousmillis > interval)  { //if it has been more than 500 milliseconds
    previousmillis = currentmillis;
    //turn the led off if it's on and vice versa
    if (colorledstate1 == LOW)  {
      colorledstate1 = HIGH;  }
    else {
      colorledstate1 = LOW;  }
      //if the red LED is on, turn the green LED off and vice versa
    colorledstate2 = HIGH;
  else {
pluggy
"Programming Questions ?"
I'm a big fan of 'if it does what you want, its right.'  :)
http://pluggy.is-a-geek.com/index.html
packocrayons
:P
Arduino hasn't showed up yet. I want to get my code done and ready to go before it gets here.
Of course I bought two  ]:D
packocrayons
Well It's not working now :(
I put one LED to go high in the setup just so I know that it is running and it is, but it's never going through the loop.
Code: [Select]
int fadeamount = 5; //how much the led fades
void setup()   {
  analogWrite(colorledstate1, HIGH);
void loop()   {
  analogWrite(fadingled, brightness); //set the brightness to the LED
  if (currentmillis - previousmillis > interval)  { //if it has been more than 500 milliseconds
    else {
  else {
CrossRoads
Code: [Select]
colorledstate1 is not a pin,
try writing to one of your defined pins
Code: [Select]
packocrayons
You're right, I missed that. Either way, the led still goes high during the setup.
Modified code, still not looping though
Code: [Select]
int fadeamount = 1; //how much the led fades
void setup()   {
  analogWrite(colorchange1, HIGH);
void loop()   {
  analogWrite(colorchange1,colorledstate1); //write to the LED's
  analogWrite(colorchange2,colorledstate2);
    else {
  else {
PeterH
Well, it is looping in the sense that loop() is being called, but presumably the code inside loop() isn't doing what you intended.
I only provide help via the forum - please do not contact me for private consultancy.
CrossRoads
analogWrite(pin, # from 0 to 255);
I don't see you writing a number to the pins.
Try changing the low, high you have there now to something either is, or represents, a number.
packocrayons
#8
Oct 06, 2012, 05:07 am Last Edit: Oct 06, 2012, 05:47 am by packocrayons Reason: 1
Here's the modified code, the color change is working now but the fading LED just stays solid, it stays at a certain brightness depending on the value of fadeamount.
Edit: I forgot to put a delay, it's all working now.
Code: [Select]
int brightness = 1; //brightness of the led
void setup()   {
void loop()   {
 digitalWrite(colorchange1,colorledstate1); //write to the LED's
 digitalWrite(colorchange2,colorledstate2);
 brightness = brightness += fadeamount; //add or subtract to the brightness based on fadeamount
   else {
 else {
CrossRoads
Well, that would indicate this isn't doing what you want:
Code: [Select]
Try putting a Serial.print and see what's happening to brightness & fadeamount.
packocrayons
It's doing what I want now. All I need to do is figure out how to get around using the delay.
Thanks everyone for the help.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
