Author Topic: [Debutant] aide pour mon code  (Read 220 times)
Bonjour à tous,
j'ai déjà envoyé mon code c dans l'arduino et je souhaite bouclé celui va me permettre d'allumer et éteindre ma led en c#
j'utilise une arduino uno et un internet shield
voici mon code c#
public partial class Gestion_des_lumières : Page
        SocketPermission permitSocket = new SocketPermission(NetworkAccess.Connect, TransportType.Tcp, "192.168.1.177", SocketPermission.AllPorts);
        // Socket _scl = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
        // IPEndPoint _scl, sender;
        // Socket arduino;
        //SocketPermission _scl = new SocketPermission(NetworkAccess.Connect, TransportType.Tcp, "192.168.1.177", SocketPermission.AllPorts);
        public Gestion_des_lumières()
            InitializeComponent();
            permitSocket.AddPermission(NetworkAccess.Accept, TransportType.Tcp, "192.168.1.177", 1337);
           // _scl = new IPEndPoint(IPAddress.Parse("192.168.1.177"), 1337);
           // arduino = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            // _scl.Connect(IPAddress.Parse("192.168.1.177"), 1337);
        private void button11_Click(object sender, RoutedEventArgs e)
            Page1 precedent = new Page1();
            this.NavigationService.Navigate(precedent);
        private void button12_Click(object sender, RoutedEventArgs e)
            Programmation prog = new Programmation();
            this.NavigationService.Navigate(prog);
        private void button1_Click_1(object sender, RoutedEventArgs e)
            try
                byte[] Message = Encoding.ASCII.GetBytes("1");
                // Message = permitSocket.send
                // int OctetsEnvoyes = _scl.Send (Message);
                // arduino.SendTo(Message, Message.Length, SocketFlags.None, _scl);
            catch(Exception ex)
                MessageBox.Show(ex.Message);
        private void slider1_ValueChanged(object sender, RoutedPropertyChangedEventArgs<double> e)
            int pwm;
            pwm = Convert.ToInt32(slider1.Value);
j'ai un problème de permission
j'ai ce méssage d'érreur
Échec de la demande d'autorisation de type 'System.Net.SocketPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
et je n'arrive pas a finir mon code pour envoyé la commande a l'arduino
            try
            catch(Exception ex)
Apres plusieurs essai je commence à désespérer
Pouvez vous m'aider s'il vous plait?
Merci
