Loading...
Pages: [1]   Go Down
Author Topic: KY028 Temperature Sensor example  (Read 1058 times)
Wellington
Offline Offline
Newbie
View Profile
Hi
I am an Arduino newbee and have a Sensor set from DX.
I am trying to work my way through all the sensors but I can not find any example code for the KY028 (4 pin) Temperature module.
It looks like this
http://www.aliexpress.com/item-img/Temperature-sensor-module-KY028-ARDUINO-applicable/596737283.html
Any help gratefully accepted.
Bruce
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
What is the part number on the 8-pin chip on that board?
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Wellington
Offline Offline
Newbie
View Profile
Hi
It is a LM393.
7 of the modules in the kit have the same board. They all differ from the ones in the cutedigi kit in that these are all Red and have 4 pins labelled A0, G, + & D0.
They are Keyes Modules but I can not find any datasheets on any Keyes boards anywhere.
Thanks
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
The LM393 is a comparator. My guess is that the temperature sensor is a thermistor, and the output of the module is high or low depending on whether the temperature is above or below a target temperature, which you can select by adjusting the potentiometer on the board. So you can try connecting the power (+?) and ground (G?) pins of the module to Arduino +5V and ground respectively, and the output (D0?) to a digital input pin. The A0 pin is possibly an analogue output that you could connect to an analogue input pin to get a reading of temperature rather than just an above/below status.
« Last Edit: October 06, 2012, 04:28:31 pm by dc42 » Logged
Wellington
Offline Offline
Newbie
View Profile
Thanks DC
I'll give it a go and see what I end up with
Logged
Offline Offline
Newbie
View Profile
If I dump the analog output straight to the serial output I get numbers such as 220 for my household temp, 170 for my finger tip and 300+ after touching the tip with ice.  How would I translate this to actual temps?  Of course I must consider that these may be F temps, not C temps but higher for colder??  Do I need to us 'map' to convert values? Thanks.
Mark
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
It sounds as though the thermistor is the lower resistor (the one connected to ground) in a potential divider. If so, the resistance of the thermistor relative to the fixed resistor is equal to a/(1024 - a), where a is the analog reading, assuming the potential divider is being fed from +5V and you are using the default 5V analog reference. You can then calculate the temperature using the Steinhart-Hart equation, see http://www.daycounter.com/Calculators/Steinhart-Hart-Thermistor-Calculator.phtml.
Temperature sensors that give an output voltage linear in temperature (e.g. LM34, LM35, LM335), or that give a digital output (e.g. DS1820B) are easier to work with.
Logged
Pages: [1]   Go Up
Print
Jump to:
