Loading...
Pages: [1]   Go Down
Author Topic: arduino and multiple thermo sensor  (Read 1084 times)
Offline Offline
Newbie
View Profile
hello,
I am projecting a kind of woodstove controlling system.
After designing my plan, I realised that I need 18 diff thermo sensors ( K or tmp35)
This quite too much for one arduino uno v.3 as there are not enough analog.
Anyway I cannot believe it shouldn't be possible to do so.
I am not an expert ( far from ), but if something like a multiplexer should be the solution...
if somebody could suggest me a kind of easy solution, it would be great,
thanks,
Philippe
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
If you are using a K-type themocouple you will need some kind of conditioning amplifier anyway.  You can get one with a digital interface (I2C) and use an I2C multiplexer if the units don't have adjustable addresses.
For any temperatures below 125°C you can use a string of DS18B20 OneWire thermometers on a single pin.  Each has a 64-bit unique address.
Logged
Offline Offline
Newbie
View Profile
thanks for your reply,
For the K sensors, I intend to use a RC and OAP.
Your idea to convert into digital sounds nice, I will investigate with I2C
I've found 'Analog/Digital MUX Breakout' on SparkF, with 16 AD ports which seems to be very easy to use. ( still missing two AD ports but I can use those on the UNO, so my problem seems to be solved at this time.
regards,
Phil
Logged
Offline Offline
Newbie
View Profile
Why don't you use a digital sensor, like DS18B20?
Logged
Offline Offline
Newbie
View Profile
Good point,
because I already bought the K-type and tmp36 ;-)
but you are right dig sensor should have been better.
thanks,
Phil
Logged
Offline Offline
Newbie
View Profile
also, I am not 100% sure that with a woodstove, 125° is sufficent, it MUST but sometime water may boil and reach xxx ° before exploding the tubes.
One reason to create this controlled woodstove.
Just for expl.
woodstove is a non interruptible process. I need to spread the hot water following a prioritised route. But when reaching all the thresholds ( heating circuit, buffer tank and sanitary hot water) where can I divert the excess of t°?
Thanks to these proj. It will advise ( my wife or me ) to stop loading wood BEFORE or to load more,
regards,
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You can control the wood stove heat output by controlling the rate it receives oxygen.  You can close the dampers to reduce heat and blow in air to increase heat.
Logged
Offline Offline
Newbie
View Profile
oulala,
new item in my project,
oxygen control ? yes i  will investigate
blowing or reducing the air input ? wouh, it's a very basic woodstove,
only manual intervention is possible to reduce the ventilation, otherwhise putting new diy mechanism on it and...
my wife will be ...
I don't know how you say that in USA,
Hmmmm,
say strange
phil
Logged
Pages: [1]   Go Up
Print
Jump to:
