Topic: Arduino Mega2560 R3 pinouts photo (Read 148834 times) previous topic - next topic
BennX
Do i see it right, that there are 15 PWM outputs (2-13 + 44 45 46)? several sites of the shop do say, that there are just 14.  The 15 would be important for my project.
terryking228
Nantonos, Nice Work on this!
May I use this on the http://ArduinoInfo.Info WIKI? I'd link back to your original as well.
Thanks!
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
lemming
A table of pins 1-100 on the Atmega2560 with the corresponding Arduino Mega pin number mappings would be ideal.
lve0200
Hi there,
I noticed that the pdf drawing on the Arduino Product web page shows 2 crystals 16Mcs, however there's only one on the board??
Furthermore, the downloadable eagle files do not open in my Eagle: Invalid data error
I am experiencing communication probs, possibly coming from one clock source for the 2560 & 16U2, derived from 1 crystal, only.
Could you please clarify?
Thank's
hk
SkobyMobil
Hi there,
http://pighixxx.com/megapdf.pdf
http://pighixxx.com/atmega2560v3_0.pdf
Greeting and fun
Andreas
die zweite Maus bekommt den Speck...
TLuck
Just out of curiosity does an Ethernet shield connect the same way and is just as efficient on the mega? Or must I get a new style of shield.  One other question would be does the mega have a sufficient amount of memory more than the Uno for SRAM that it would make a difference for a solid grouping of text for multiple strings in a program?
sritter09
Thanks for posting this. That is a great reference to keep on hand.
Expand your horizons; unless the horizon is on fire. Then go a different direction.
stuartyh
This is a site which gives you pin-out of the various Arduino boards.
http://www.pighixxx.com/test
The "tripple x" in the site address does not mean it is a porn site except to show you the nakedness of the pins.
Hope it was of help.
Regards
bruceyuan95
I am wondering which pin is for DAC.
Thanks
CrossRoads
I2C DAC? SPI DAC? Parallel interface DAC?
Atmega2560 itself does not have a DAC.
bruceyuan95
Could you tell me how to convert PWM to Analog if it is possible?
Thanks
CrossRoads
#27
Apr 05, 2016, 09:42 pm Last Edit: Apr 05, 2016, 09:42 pm by CrossRoads
Run it thru an RC lowpass filter.
Here's PWM, from 0-25-50-75-100-125-150-175-200-225-250 with 10K resistor and 4.7uF cap.
Or may 4.7K resistor and 10uF cap, I forget which.
http://sim.okawa-denshi.jp/en/CRlowkeisan.htm
You may want different values depending on what frequency response you want to achieve.
bruceyuan95
Thanks a lot.
beddy
Nantonos: just add table with your image ;)
