Loading...
Pages: 1 [2]   Go Down
Author Topic: Tension on shutted down gpio  (Read 1396 times)
Offline Offline
God Member
Arduino rocks
View Profile
Yea, the Vf spec is of just passing interest, we know that a 5 volt signal will fully turn on the positive clamping protection diode on a input digital pin on a 3.3 volt powered board, what we want to know is how much continous current the diode can withstand, that is the datasheet spec of interest.
It seems as if Atmel is a bit candid about this limitation. There is an AVR application note on zero crossing however, where they use a digital pin directly connected to mains. In this note, maximum continues forward current is quoted as 1mA. The relevant text reads as follows:
Quote
The series input resistor is a 1 MΩ resistor. It is not recommended that the clamping
diodes are conducting more than maximum 1 mA and 1 MΩ will then allow a maximum
voltage of approximately 1,000V.
Any voltage higher than 1,000V would probably be spikes or surges. The clamping
diodes are able to handle spikes for a short period of time but not surges. The application
note will not go into how to protect against surges, but simply recommend
implementing protection against surges in the design.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Yes, that 1ma maximum recommended continuous current rings a bell. So for a 5 volt signal wired to a 3.3 volt input pin, 1700 ohms or more series current limiting resistor should be OK.
Lefty
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
