Topic: Problem with color sensor (Read 2828 times) previous topic - next topic
amruth11
Hi all , i am having trouble with making this color sensor work. I dont know what i have done wrong in my code but i am not able to get it to work.
This is the code i am using:
char color[19];
void setup(){
  Serial.write("Ready");
  Serial.println();
  delay(100);
void loop(){
  if(Serial.available() != 0){
    for(int x=1; x<18; x++){
      color[x] = Serial.read();
      if(color[18] == 0x0A){
        Calibrate();
void Calibrate(){
  int R;
  int G;
  int B;
  R = (((color[3]-'0')*100) + ((color[4]-'0')*10) + (color[5]-'0'));
  G = (((color[9]-'0')*100) + ((color[10]-'0')*10) + (color[11]-'0'));
  B = (((color[15]-'0')*100) + ((color[16]-'0')*10) + (color[17]-'0'));
  Serial.println(R);
  Serial.println(G);
  Serial.println(B);
  Serial.println();
And this is the datasheet of the sensor:  http://www.sunrom.com/files/1185-datasheet.pdf
I need advice and help on how to get this working fast.
Thx in advance.
Amruth
AWOL
#1
Oct 06, 2012, 08:29 pm Last Edit: Oct 06, 2012, 08:32 pm by AWOL Reason: 1
Usual problem - check to see if there's at least one character available to read, then go ahead and read all 18 of them.
Also, array indices usually begin at zero.
You need to define what "work" means to you in this context.
amruth11
i get my readings but they are all gibberish, i have set baud rates correctly but still the readings are in negative and above 1000.
AWOL
No, there're mostly -1.
Re-read reply #1
amruth11
Not able to figure out anything  =(
AWOL
#5
Oct 06, 2012, 09:18 pm Last Edit: Oct 06, 2012, 09:29 pm by AWOL Reason: 1
Look at your code
Is there a single character in the serial receive buffer?
Yes, so read all eighteen of them.
Does that seem like a sensible thing to do?
Some useful reading:
http://arduino.cc/en/Serial/Available
Hint: you're not the first person to make this mistake.
Nantonos
#6
Oct 06, 2012, 09:31 pm Last Edit: Oct 06, 2012, 09:34 pm by Nantonos Reason: 1
I agree that is a problem with the code as posted.
They do, but oddly, part of the code (the read loop) is 1-based while another part (the parsing) is correctly 0-based.  As an example, the first bit of actual information is the fourth character, "Red Value Hundreds Character ASCII" and the code correctly accesses this fourth item as
(color[3]-'0')*100)
AWOL
At 9600 it is never going to be particularly fast.
