Author Topic: [SOLVED] USB 2 serial converter  (Read 1038 times)
I need to send data from arduino 1 board to a PC via rs232 interface. I need to know whether is possible to use the usb 2 serial converter (http://store.arduino.cc/ww/index.php?main_page=product_info&cPath=30&products_id=143) or it is only a programming device.
Thank you in advance and excuse me if this is not the correct section.
Wolfman
« Last Edit: October 07, 2012, 06:16:38 pm by Wolfman » Logged
Venezuela
Ground.......ground........always ground
Hello Wolfman. It's quite a difficult step. While many microcontrollers today offer slave USB, like Arduino, usually only 32-bit microcontrollers (e.g. ARM) offer usb host ports.
I don't know of USB host to RS232 converters, although in theory they could exist.
So if I were asked to solve this problem, I would search for a Linux implementation supporting USB on the smallest possible processor with embedded USB host port. Sounds expensive, but it does not need to be: 32 processors used  e.g. in GPS and game consoles consoles are below 20$, and if they can boot from flash (eg. SD card) the external parts are reduced to RAM and a few other chips. However, the software effort is formidable: putting the parts together (hardware, bootloader, operating system, drivers and application) is a daunting task (I'm after a 32-bit ARM board for more than five years with the help of a linux expert and yet the product is not finished...).
Hope this helps
Austin, TX
CMiYC
Why is a host necessary?  RS-232 is a two way protocol.  The PC can be host and an USB to Serial adapter can be the device just fine.
You mean an original Arduino board with RS232 interface?  I would suggest something like a FTDI cable or the Arduino USB to Serial board connected directly to pins 0 and 1 of the Arduino board.  This will allow for USB communication with the PC on an Arduino that doesn't have a USB to Serial chip already.
www.cmiyc.com - A guide to being an Enginerd
Boston area, metrowest
All you need Wolfman
http://store.nkcelectronics.com/rs232-to-ttl-3v--55v-convert232356.html
Connect to +5, Gnd, TTL Rx/Tx on your board.
Run RS232 cable to your PC.
Malaysia
A place for DIY projects
See Mini USB Host Microcontroller Board
http://www.kickstarter.com/projects/985890579/mini-usb-host-microcontroller-board-arduino-compat
Electronics and computer projects
http://ediy.com.my/
I need to monitor some internal state of Arduino UNO board during debug and I don't know if there is another way to debug the software instead of printout some lines via serial line.
Austin, TX
CMiYC
That's the method almost everyone uses.
The virtual serial port on the Uno is used for both programming and serial communication. You use the Serial commands to send stuff and open up Serial Monitor from the Arduino IDE.
You can also use the onboard L LED to indicate when your code has reached a certain point, or a function has been run - add a simple
digitalWrite(ledPin, HIGH);
delay(1);
digitalWrite(ledPin, LOW);
cut & paste it around as you debug the various sections.
Norfolk UK
Maybe Nick's excellent article on debugging over SPI interface http://www.gammon.com.au/forum/?id=11329
Thank you very much James. After a while it works on my Ubuntu 12.04.
« Last Edit: October 07, 2012, 06:16:57 pm by Wolfman » Logged
