Topic: endsWith Not working for me. (Read 3118 times) previous topic - next topic
123tcpip
I'm playing with the example sketchs using an Uno board and 1.01 and was looking at endsWith to read a string.
But the example  doesn't work for me.
startsWith seems OK though.
Can anyone else confirm?
I get the following results regardless of whether the sensor ends with 0.
HTTP/1.1 200 OK
Server's using http version 1.1
Got an OK from the server
sensor = 10. This reading is not divisible by ten
String startsWith() and endsWith():
HTTP/1.1 200 OK
sensor = 28. This reading is not divisible by ten
HTTP/1.1 200 OK
sensor = 4. This reading is not divisible by ten
HTTP/1.1 200 OK
sensor = 0. This reading is not divisible by ten
The actual code from the demo.
Can anyone else confirm if I'm going mad.
  String startWith() and endsWith()
Examples of how to use startsWith() and endsWith() in a String
created 27 July 2010
by Tom Igoe
This example code is in the public domain.
  Serial.println("\n\nString startsWith() and endsWith():");
// startsWith() checks to see if a String starts with a particular substring:
    String stringOne = "HTTP/1.1 200 OK";
    Serial.println(stringOne);
  if (stringOne.startsWith("HTTP/1.1")) {
    Serial.println("Server's using http version 1.1");
  // you can also look for startsWith() at an offset position in the string:
  if (stringOne.startsWith("200 OK", 9)) {
    Serial.println("Got an OK from the server");
  // endsWith() checks to see if a String ends with a particular character:
  String sensorReading = "sensor = ";
  sensorReading += analogRead(0);
  Serial.print (sensorReading);
  if (sensorReading.endsWith(0)) {
    Serial.println(". This reading is divisible by ten");
  else {
    Serial.println(". This reading is not divisible by ten");
// do nothing while true:
while(true);
johnwasser
Code: [Select]
Perhaps you meant:
Code: [Select]
if (sensorReading.endsWith("0")) {
or maybe
Code: [Select]
if (sensorReading.endsWith('0')) {
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AWOL
Is it just me, but this seems over complicated, when a simple % operator would do the job?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
123tcpip
John
Thanks for the quick reply.
This is the example sketch that came with the Arduino not code I have written
"0" doesn't compile
StringStartsWithEndsWith.cpp: In function 'void loop()':
StringStartsWithEndsWith:33: error: invalid conversion from 'const char*' to 'uint8_t'
StringStartsWithEndsWith:33: error: initializing argument 1 of 'int analogRead(uint8_t)'
and '0' doesn't work.
It is possible you could try it and see if the function is actually working.
cmiyc
"0" doesn't compile
Compiled and work fine for me in this code:
Code: [Select]
  sensorReading += analogRead(A0);
  else {
  delay(250);
As I expected sensorReading.endsWith(0) did not work.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
johnwasser
The argument to endsWith() is a "const String reference".  I think it tries to take the argument, in this case a constant 0, and construct a String out of it. In theory the constant should be treated as an 'int' and should thus be converted to a decimal String "0".  I think that the constant 0 may be taken as a 'char'.  In that case the a two-byte buffer would be constructed with the character (null) and a null terminator. The resulting string would be empty.  I suspect that is what is happening and why the "endsWith(0)" always return false.
Perhaps (int)0 would work.
AWOL
I still think "% 10" is a much simpler solution.
123tcpip
John
Sorry I changed the wrong 0 in my rush to test and get out of the house last night and as you say it compiles  and work fine if I use "0"
As this is the distributed example is it worth letting Arduino know?
AWOL
Could you explain %10 as I was unable to find any reference to it.
I assume it's means if it's divisible by 10 but I can't work out the syntax
Rob
AWOL
123tcpip
AWOL
Thanks for the pointer I couldn't get a result searching for % on the web or board.
I will go and have a play.
Rob
MarkT
In C and C++ anywhere a pointer or reference is accepted the null pointer is also accepted.  The null pointer is notated as 0.
ElectronicsNoobie
Quote
Pointers can be NULL (or 0) but references can not.
In this case I believe the compiler decided it could take your 0 and turn it into a string. However, looking at the reference for String, this should work.
