Hello everyone,
I'm working on a home automation project of my own and one of the things I'd like to do is to be able to determine if things (like lights or my TV) are on or off without having to hack anything. I was recommended to use a non-invasive current sensor so I built one my self using this instructable:
http://www.instructables.com/id/2-Carabiner-split-core-AC-transducer/and made an extension cable with every cable separated so I was able to place the sensor around just one of the cables as you would do with a current clamp (which I have tried and it worked)
and wired it to my arduino using this diagram
Burden = 27 ohm, C1 = 10uf capacitor, Rvd = 1k ohm
my code is just a regular analog read and output to serial
int sensorValue = analogRead(A0);
Serial.println(sensorValue);
but all I'm getting is 511 or 512 values both when the TV is on and off...
any ideas?
I've already tried many different resistance values, different capacitors but no results...
