Grand Rapids Mi
Offline
Jr. Member
« Reply #30 on: October 16, 2012, 09:13:48 am » |
This is the schematic, Each LED you see in the schematic is actually 15 leds. What should I Do to make it brighter?
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #31 on: October 16, 2012, 09:21:48 am » |
So what do you guys think?
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #32 on: October 16, 2012, 09:33:11 am » |
No replies? Cmon
Logged
Eugene, Oregon
Offline
Sr. Member
« Reply #33 on: October 16, 2012, 09:42:51 am » |
There is a limit to how much light 30 LEDs will make, but its possible they can be brighter w/out damage. LEDs have a forward voltage rating, you should not exceed this voltage, which is why you. usually see a resister on each LED. The Arduino should put out 5vs at 40ma per pin, and each LED probably uses 20ma at around 3v. Pin 13 should be resistered, so that you can hook up an LED, w/out resister. If you use a different pin, you probably want to put some resister on your LED, or it may burn up. You can calculate what resister Heres a wesite that helps you figure out what resister to use with your LEDs. Then use those resisters, and use a different pin on the arduino (13 is resistered, so use 9, or whichever one you like), then change the code to whichever pin you use. http://ledcalc.com/If you hooked up an LED directly to the 9volt battery, it should have burned up almost instantly.
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #34 on: October 16, 2012, 09:46:20 am » |
/* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */ // Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 13;
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(led, OUTPUT); }
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(43200000); // wait for 12 hours digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(43200000); // wait for 12 hours } How can I use 2 pins at once then? IN example pin 13 and 12 are running the same way.
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #35 on: October 16, 2012, 09:52:04 am » |
Anyone??
Logged
Eugene, Oregon
Offline
Sr. Member
« Reply #36 on: October 16, 2012, 09:54:32 am » |
You can actually use many pins at one time. you are using pin 12 for ground, leave that the way it is. Instead of using pin 13, use pin 12, or 11, or 10, or 9... Here is code configured to use pin 9 instead of 13 /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */ // Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 9;
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(43200000); // wait for 12 hours digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(43200000); // wait for 12 hours } Here is code for using one LED on pin 13, AND one LED on pin 9. /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */ // Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 9;
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) digitalWrite(13, HIGH); delay(43200000); // wait for 12 hours digitalWrite(led, LOW); digitalWrite(13, LOW); // turn the LED off by making the voltage LOW delay(43200000); // wait for 12 hours }
Logged
Eugene, Oregon
Offline
Sr. Member
« Reply #37 on: October 16, 2012, 09:55:54 am » |
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #38 on: October 16, 2012, 09:57:58 am » |
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) digitalWrite(13, HIGH); delay(43200000); // wait for 12 hours digitalWrite(led, LOW); digitalWrite(13, LOW); // turn the LED off by making the voltage LOW delay(43200000); // wait for 12 hours } Thanks! Im going to try it like this and see how it goes, Hope I dont have to come back again! Thanks!
Logged
Grand Rapids Mi
Offline
Jr. Member
« Reply #39 on: October 16, 2012, 10:18:04 am » |
It didnt work, the same problem, I think I might have burnt out my arduino :-/
Logged
Eugene, Oregon
Offline
Sr. Member
« Reply #40 on: October 16, 2012, 11:00:03 am » |
Its kinda hard to tell from here, but my guess is that you got leds backwards, and they wont light, or hooking up leds to 9v batteries has finally burned them up.
The arduino has built in LEDs that should light up when hooked up to power or USB.
Logged
Gosport, UK
Offline
Faraday Member
« Reply #41 on: October 16, 2012, 11:19:24 am » |
That's certainly possible. I'm sure one of the electronics gurus will be able to tell you the current requirement of thirty parallel LEDs.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #42 on: October 17, 2012, 02:01:19 am » |
That's certainly possible. I'm sure one of the electronics gurus will be able to tell you the current requirement of thirty parallel LEDs. About ten times more than needed to burn an Arduino pin...
Logged
