Topic: >> Resolved << : MEGA with cardinfo.h and "LC studio" SD card reader dont work (Read 29067 times) previous topic - next topic
LibertyCareche
The same in French at (Le même en Français à) http://arduino.cc/forum/index.php/topic,125710.msg945043.html#msg945043
Hi every body,
When I started to work on this SD card reader, I thought to have 15 minutes to start to learn all the functions of the library (SD in the case).
Perhaps is there something I don't understand but nothing is correctly going on.
I m working on MEGA with an "LC studio" SD card reader.
If you read French, U can see this post (in FRench) : http://arduino.cc/forum/index.php/topic,125710.0.html
I m tring now to expose the problem here.
At every time I open the serial monitor, MEGA send this message :
Initializing SD card...initialization failed. Things to check:
* is a card is inserted?
* Is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
The program in the ATMEGA2560 of the MEGA is the one you can find by : Files/Exemples/SD/cardinfo of the 1.0.1 ARDUINO version. I modified it to fit well to MEGA.
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 53;
  while (!Serial) {     ; // wait for serial port to connect. Needed for Leonardo only  }
 Serial.print("\nInitializing SD card...");
 // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
 // Note that even if it's not used as the CS pin, the hardware SS pin
 // (10 on most Arduino boards, 53 on the Mega) must be left as an output
 // or the SD library functions will not work.
 pinMode(53, OUTPUT);     // 10 change this to 53 on a mega
 if (!card.init(SPI_HALF_SPEED, chipSelect)) {    Serial.println("initialization failed. Things to check:");
etc
I tryed with another MEGA card,... with another SD card (64Mo and 32Go Fat formated by Windows  7)
I can see on oscilloscope the MOSI signal from the MEGA to the SD and the answer (I think) from SD to MEGA on MISO (see attached pictures) when CS is at low state. SCK seems to be correct too.
The connection is as follows:
MEGA pin 50 -> miso (Master in) Card Reader "LC studio"
MEGA pin 51 -> mosi (Master Out)
MEGA pin 52 -> sck (Serial Clock)
MEGA pin 53 -> CS (Chip Select)
In Final ... the perennial failure message above recalled.
I did a voltage matching on the outputs of the player to the MEGA (see diagram image)
Seeking an electrical problem on the SD card reader, I found that the ground pin of the regulator AMS1117 was not connected to the ground of the reader, then I fixed the error and voltages are stable and nominal. I found 52Ko and not 0 Ohms between the Voltage controler's ground and the reader's card ground, measured by Fluke 185. This is a problem, sometimes on this type of player because I found a post on this, once I had identified the problem and the components in question, providing the necessary keywords to search on the net... Chinese electronics...   ( http://arduino.cc/forum/index.php?topic=122947.0 )
I'm interested in any new info, result of experience or constructive idea and thank you in advance.
Cordially.
LibertyCareche
#1
Oct 07, 2012, 09:34 pm Last Edit: Oct 08, 2012, 01:01 am by LibertyCareche Reason: 1
Great news for me... I did not become sénileet !!
I tryed with an Arduino Uno. The firts tests let me think that I could have to retire early ... but finaly I removed again the 64MB SD card to try an 32GB in FAT32 formatted. Result :
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
Besides the first electronic bug, I wonder if :
1) the MEGA coupled to an SD card can be a problem for SD.h
2) a 64MB SD card can be a problem for SD.h
3) a 10 years old Card wich is working fine (I test regularly every hour) can cause problems for SD.h
4) Contrary to what you may read on the official site, the FAT16 could pose a problem SD.h
_ _ _ _ _ /_ _ _ _ _ /_ _ _ _ _ /_ _ _ _ _ Subsequently , why SD.h can't find the FAT? _ _ _ _ _ /_ _ _ _ _ /_ _ _ _ _ /
SurferTim
My 4GB card works fine in my ethernet shield sd slot on a Mega, and I am using the SD library. So I think it is neither the Mega nor the library.
Are there any files that violate the 8.3 filename format on the sd?
The SD library finds mine ok
fat16lib
#3
Oct 07, 2012, 11:35 pm Last Edit: Oct 07, 2012, 11:40 pm by fat16lib Reason: 1
Is the 64 MB card an MMC card?  Also some old cards don't comply with the SD spec.
SD.h only supports SD cards that comply with the SD standard.  Macs and Windows machines support old cards but SD.h does not since this would increase the size of the library and few people use cards produced before the standard was finalized.
Also the SD standard requires 64MB cards to be formatted FAT12.  SD.h does not support FAT12 file systems.
How did you format the cards?  If you used Mac or PC utilities, the card may be formatted with a GUID partition table instead of MBR. PCs and Macs accept GUID partition tables but SD.h does not.
The SD standard requires a MBR partition table.  The best way to format SD cards is to use SdFormatter https://www.sdcard.org/downloads/formatter_3/.
It would be helpful if you downloaded SdFat http://code.google.com/p/sdfatlib/downloads/list and ran the QuickStart and SdInfo examples and posted any error codes from these programs.  These programs are in the SdFat/examples folder.
You can also force the 64 MB card to be formatted FAT16 by using the SdFormatter example in the SdFat/examples folder.
LibertyCareche
Thank you for answer to me SurferTim,
There is just one file in 8.3 format name.
As I wrote, I change the MEGA to be sure that the problem can't be imputed to it.
                    I think that it will be funny to write an answer
                    to the scrolling question in your scrolling texte
Thanks too for your answer Fat16Lib,
The 64MB sd card is marked "Multimedia card", so... I think its an MMC...
Thank you for all these tips.
I formatted the cards with SDFormater V3.1.    I'll try SdFat and post the results.
it is certain that writing a library as SD.h is a big job. Successful work indeed! Admittedly, this is a big library for a card Uno but perhaps it could be made more efficient for the more powerful cards, such as MEGA and those that will probably come out in the coming months or years...
Are you the author of this library? I think I read somewhere your username !...
anyway, thank you very much
LibertyCareche
I tryed it, Fat16Lib,
here is the result :
SdFat version: 20120719
type any character to start
card.init failed
SD errorCode: 0X8
SD errorData: 0X1
fat16lib
The card is not an SD card.  It must be a MMC (MultiMediaCard) since the error code is 0X8.
SD I/O can be a bit faster with a Mega but not much.  AVR SPI is not very efficient.
I have developed a version for Cortex M processors and will release it for the Arduino Due and Teensy 3.0.  It runs much faster than the AVR version.
I will provide an option in the AVR library to speedup the Mega a little.  Very few people use the Mega and most people use Print to write text files which is very slow.  Most people use the Uno and memory is precious with this board.
I have released examples that allow writing binary data much faster.  See AnalogIsrLogger20120810.zip http://code.google.com/p/beta-lib/downloads/list.  This example logs binary data from an analog pin at up to 100 ksps.  It uses a special API to create contiguous files and stream data using multi-block SD write commands.
LibertyCareche
I don't know if its an MMC, Fat16Lib...
see picture...
have a good day
fat16lib
#8
Oct 08, 2012, 02:53 pm Last Edit: Oct 08, 2012, 03:14 pm by fat16lib Reason: 1
This card is a SDHC card so it should work with both SdFat and SD.h libraries.
The card fails on CMD58 which checks whether the card is a standard capacity card or high capacity card and returns the Vdd range supported by the card.
The card returns a status that it is not in a ready state.  This means power on initialization has not completed correctly.
CMD58 is only used in SPI mode.  A different set of commands is used by a PC or Mac in SDIO mode.  This card may work in a PC or Mac but fail in SPI mode.
Does it always return error code 0X8 with error data 0X1?
MMC cards also fail on CMD58 but your card is clearly an SDHC card.  MMC cards often fail with error code 0X8 and error data 0X5.
LibertyCareche
I am going to buy another SD card... 2GB. Appoint it (nominate) SDb, want you ?
I formated it as you told me with SDFormatter.
the result with SDInfo is :
card.init failed
SD errorCode: 0X2
SD errorData: 0X57
card.init failed
SD errorCode: 0X2
SD errorData: 0X57
init time: 47 ms
Card type: SD2
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
card.init failed
SD errorCode: 0X2
SD errorData: 0X4F
card.init failed
SD errorCode: 0X2
SD errorData: 0X57
card.init failed
SD errorCode: 0X2
SD errorData: 0XAB
card.init failed
SD errorCode: 0X2
SD errorData: 0XAB
card.init failed
SD errorCode: 0X2
SD errorData: 0X55
init time: 39 ms
Card type: SD1
readCID failed
SD errorCode: 0XF
SD errorData: 0X0
It's not the same result for each tests.
For the 32GB of yesterday,... Appoint it SDa,... I have some different results too :
card.init failed
SD errorCode: 0X8
SD errorData: 0X1
card.init failed
SD errorCode: 0X8
SD errorData: 0X7F
init time: 47 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 47 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 4 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 75 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
card.init failed
SD errorCode: 0X8
SD errorData: 0X3
init time: 28 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 30 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 31 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
init time: 30 ms
Card type: SDHC
readCID failed
SD errorCode: 0X10
SD errorData: 0XFF
card.init failed
SD errorCode: 0X2
SD errorData: 0X55
fat16lib
A new card seems like a good idea.
I worry that the problem may be noise on the SPI bus.  There are often SPI problems with modules like the LC Studio.  Most reliable modules have a 5V to 3.3V level shifter based on a buffer chip.   Level shifters based on resistors and diodes work poorly with some cards.
Some cards use edge detectors and the sharp signals of a buffer chip work better.
If you new card does not fix the problem, make sure the SPI wires are as short as possible.
LibertyCareche
That's exactly what I was telling myself  :)
It's only the difference... the voltage adaptation. If you saw the electronic diagram I made based on the LC studio card reader (black components) and my adaptation système, you can see three diodes... I recommend Schottky diodes like BAT85 and now I just have some 1N4148... then the high level is 3.3V but the low one is 0,6V. it is certainly not ideal. I'll work with (on)  that now.
thank you very much for your advice
Have a good evening, although it is perhaps a little early for you at this time...
Best regards
LibertyCareche
#12
Oct 08, 2012, 11:03 pm Last Edit: Oct 08, 2012, 11:15 pm by LibertyCareche Reason: 1
With SDb & UNO :
init time: 3 ms
Card type: SD2
Manufacturer ID: 0X6F
OEM ID:
Product: SMI
Version: 1.0
Serial number: 0
Manufacturing date: 7/2012
cardSize: 3887104 (512 byte blocks)
flashEraseSize: 128 blocks
eraseSingleBlock: true
SD Partition Table
part,boot,type,start,length
1,0X0,0X6,131,3886973
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT16
blocksPerCluster: 64
clusterCount: 60726
freeClusters: 60725
fatStartBlock: 132
fatCount: 2
blocksPerFat: 238
rootDirStart: 608
dataStartBlock: 640
With SDa & UNO :
init time: 2 ms
Card type: SDHC
Manufacturer ID: 0X1B
OEM ID: SM
Product: 00000
Version: 1.0
Serial number: 2330206577
Manufacturing date: 10/2011
cardSize: 61315072 (512 byte blocks)
SD Partition Table
1,0X0,0XC,8192,61295848
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT32
clusterCount: 957491
freeClusters: 957490
fatStartBlock: 9614
fatCount: 2
blocksPerFat: 7481
rootDirStart: 2
dataStartBlock: 24576
Tomorrow, I'll try with the MEGA
LibertyCareche
#13
Oct 09, 2012, 09:56 pm Last Edit: Oct 09, 2012, 10:03 pm by LibertyCareche Reason: 1
Is it bad luck ?
First test:
64 MB SD card, 10 years old.
Arduino MEGA under SD.h & CardInfo.
SD card reader (LC studio) on witch one the ground pin of the tension controler 3.3V AMS1117  was not connected to the card ground.
Result :
Negative.
Second test :
Same cards but bug repaired (see pictures above)
Result :
Negative.
Third test :
Exchange SD card for 32GB
Same cards.
Result :
Negative.
Fourth test :
Same cards but with level adaptation 5V MEGA / 3,3V SD card
(See Levels Adaptation Diagram above)(with 1N4148 instead of BAT83 I advocate).
Result :
Negative.
Fifth test :
Exchange SD card for 64MB 10yo
UNO card...
Resultat :
Negative.
Sixth test :
UNO under SDFatLib & SDInfo.
Result :
Negative.
Seventh test :
Result :
 half positive(reporting error codes by the program).
Eighth test :
Exchange SD card for a new 2GB.
Result :
Ninth test :
exchange 1N4148 (See Levels Adaptation Diagram above) for some BAT83.
Result :
Positive
Tenth test :
Exchange SD card for 32GB.
Result :
Positive
Eleventh test :
Exchange SD card for 64MB.
Result :
Negative.
Twelfth test :
Uno under SD.h  & CardInfo.
Result :
Positive
Thirteenth test :
MEGA under SD.h  & CardInfo OR under SDFatLib & SDInfo.
Result :
Positive
Conclusions :
  • SD cards that was existing before the SD standard completion are not preferred.
  • The cards are sensitive to the shape of the signals.
  • Some "LC studio" card readers have a mass default.
Thank you very much, Fat16Lib and Jean-François for your help.   :)
Nantonos
Looking at this image and also at the related thread in the French section of the forum, a better English translation of « Certains lecteurs de carte "LC studio" ont un défaut masse » would be "Some "LC studio" card readers have a ground fault".
