Loading...
Pages: [1]   Go Down
Author Topic: What Atmel samples would you choose?  (Read 1453 times)
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 I got signed-up for samples from Atmel by simply filling out their form on the Atmel site. I found that they have EEproms, and most of the micro-controller chips available.
 I am looking for interesting things to try such as the ATTiny line of chips. Possibly the SAM chips but, I am not sure if SAM chips are available or if I could figure out how to use those.
 What EEprom, memory, or micro-controller do you think you would try if you got to choose?
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
The ATtiny84 is a good choice.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Got a link to the form?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
How about wireless MCU?
http://www.atmel.com/products/wireless/zigbee/single-chip_solutions.aspx
Logged
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
My last two:
2   ATF1508ASV-15AU100   IC CPLD 128 MACRO 15NS 100TQFP
2   ATF1508AS-7AX100   IC CPLD 7NS 100TQFP
I have not configured them yet but I have an idea for two projects with CPLDs and I am going to use these.
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Greenville, IL
Offline Offline
Edison Member
View Profile
 Thanks for all replies so far!
Got www.atmel.com and type in "samples" or got to this link and click on first link on page http://www.atmel.com/search.aspx?filter=0&output=xml_no_dtd&ie=UTF-8&oe=UTF-8&sort=date%3AD%3AL%3Ad1&ud=1&getfields=*&exclude_apps=1&q=samples&site=en_collection
 You can not see the samples available until you register. My answer for company was " No company".
You can not use a gmail account for an E-mail account. I had to use my provider e-mail account.
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
Yes it is available! We need to figure out if we can get a PCB made that would work with that! 4 versions of the ATmega128RFA1.
IC AVR MCU 2.4GHZ XCEIVER 64QFN
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
My last two:
Are those basically huge I/O expander chips?
Logged
Samplefinger
Offline Offline
God Member
View Profile
My last two:
Well, they could be.  They are programmable logic with a complexity between older PAL/GAL and newer FPGA chips.  So you can design them to be whatever you want, within some limitations, within a certain number of gates.   If you wanted them to be shift registers they could certainly do that, or ALUs, or decode/encode logic.  My idea is to make them counters that monitor one or more rotary encoders so the microcontroller does not have to and to have multiple channels.  But I will probably not get to it for several weeks, I am busy finishing up several projects right now.
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
 I made a part request today of 4 chips. I answered all questions as truthfully as possible. I did not claim to be a business, and even stated I was going to use the chips for hobby use\development.
 I will follow up as results come in.
Chips ordered,
Atmega 2560 ...... curious if I can solder this one.
Atmega 1284 SMT .... I want to try 20Mhz and I have one PCB left over to solder this to.
ATtiny 84 ..... I have never used this one before.
ATmega128RFA1, IC AVR MCU 2.4GHZ XCEIVER 64QFN .........WIFy chip, I hope I can make this work, it would be awesome!
Logged
Samplefinger
Offline Offline
God Member
View Profile
Chips ordered,
Anyone can solder an ATMega2560 if you go ahead and buy one of the Schmartboard adapters.  Too bad they cost $10 each.  I posted about it here and most everyone has a better idea than spend $10 but it does work, it worked for me just fine:
http://arduino.cc/forum/index.php?topic=112531.0
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
 Thanks JoeN for the information!
Quote
 I looked into the chips you mentioned, I think they are interesting but, well above my ability at this point. I hope to here how you do with the chips and what it takes to work with them.
Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
Quote
ATmega128RFA1
This one so that I can implement or atleast experiment with Zigbee protocol and 802.15.4 Ipv6 6LowPan standard, I'm basically looking to develop very small internet connected object's that also save a lot of power and Ipv6 does the same and much more like a lot of addressing capacity.
Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Greenville, IL
Offline Offline
Edison Member
View Profile
 I found a Sparkfun evaluation board that has Eagle files! I think the board could use a SD card slot for starters but, it is nice that there is a footprint already made for the chip!
Quote
ATmega128RFA1
https://www.sparkfun.com/products/9734
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
  A little late on an update but, here we go...
 I received all my chips around Sept.28th, all neatly packed in their silver bags. Free shipping and it took about a week to get to my house.
 Last night, I got the ATtiny84 to run the "blink" and "fade" examples using the MIT code and Arduino as ISP! The 84 is a neat little chip! Only extra components I used for the two sketches were a resistor and LED! Talk about minimal Arduino!
 My other chips will need boards for them which, I hope to come up with for fall projects and experimentation.
Conclusion, Atmel made me very happy by providing me with the samples with a minimum amount of hassle.
Thank you Atmel!
Mark
Logged
Pages: [1]   Go Up
Print
Jump to:
