Topic: GSM and XBEE with Arduino Uno (Read 2709 times) previous topic - next topic
jahnavi
I am using Arduino Uno. Can i connect Cellular Shield with SM5100B i.e GSM and the Xbee Shield in stack of layers with Arduino Uno. Does the GSM and XBee modules will operate on the same ports?
Thank you
PaulS
Quote
Yes. Or no. It all depends on WHICH shields you are planning on using.
Quote
Yes. Or not. See above.
jahnavi
I would like to use "Cellular Shield with SM5100B" and "XBee Shield V1.4" with Arduino Uno.
Thank you
PaulS
Quote
I clicked those links. Nothing happened. I guess you can't use them.
jahnavi
https://www.sparkfun.com/products/9607  -------- link for GSM Shield
http://www.liquidware.com/shop/show/XBS/Arduino+XBee+Shield   --------- XBee shield
Please see the above links for reference and let me know whether i can use them or not.
Thank you
PaulS
Looking at the schematic for the GSM shield, it uses pins 0 and 1 or pins 2 and 3 for communication between the Arduino and the GSM shield.
There are at least three different XBee shields. That one is, by far, the worst. It uses the hardware serial pins (0 and 1) to communicate with the Arduino.
So, you could use both shields, with the GSM shield jumpered to use pins 2 and 3, using SoftwareSerial to communicate with the GSM shield, and using Serial to communicate with the XBee.
Forget about trying to debug anything.
jahnavi
Can you tell me which of the Xbee Shield is the better one.
Thank you
PaulS
Sparkfun's XBee shield has the same switch as the GSM shield, allowing you to select either pins 0 and 1 or pins 2 and 3.
You could put the GSM shield on 2 and 3, using SoftwareSerial to talk to it, and put the XBee on 0 and 1, and use Serial to talk to it, or do it the other way around.
