Pages: 1 [2] 3   Go Down
Author Topic: Voice Recognition Module programming issue  (Read 1929 times)
Seattle, WA USA
Online Online
Seattle, WA USA
i want to do StateChangeDetection with the word "red" so when i say red the led goes high and when i say red again the "led" goes "low" my problem is the statechangedetection reads from a pin which i dont have in the software.
If you are referring to an example called "StateChangeDetection", the pin doesn't matter.
All you need to do is keep track of whether the red LED is on or off. When you get a "red", change the state to the other state, and write the new state to the red LED's pin.
2) How do i program the unit to go into a specific Case and stay looping in that case untill i give it a command to exit back to the main program? currently it keeps reverting back to the top of the code.
We'd need to see your code. You can define loops in a case, but you must provide a way for that loop to end.
Hi Paul
okay iv had a rethink on the way i want the VR module code to work. in the manual it states that the VR unit can handle 3 groups of 5 words each , and only one group can be used at a time, this seems like an issue but it is not, see i have desided to break my code into 3 groups.
group 1 is environmental group ie which room in the house do i want to control ,
group 2 is for which appliance in that room do i want to select
group 3 is the control action i want to apply to that appliance.
currently i have all 3 groups in a switch case , but because i can only have one group imported at a time only that words that imported works out of the whole switch case.
in my code below i used "bar" in group 1  "lights" in group 2 and "start" in group 3
so what should happen is i call out "bar lights start" and the bar lights should switch on, now my problem is when i declare in setup what the bar lights pin is it does switch on as intended and off but because i want to use group 3 as a control group of words, the pinout  must be vairable and be int. each time I enter that appliance void function. I have tried creating a global vairable called " int SwitchPin = Pin; " and "int Pin =0;" then when i enter group 2 "lights" in the lights void i " int Pin =9; " and then when i say "start" it should switch on ... it doesnt
#include <SoftwareSerial.h> // use for software serial tobe able to monitor serial output will speaking into the VR module
SoftwareSerial mySerial(2, 3); // RX, TX software serial pin selection
// Variables declaration
int Pin = 0;
int redPin = 11;   // R petal on RGB LED module connected to digital pin 11
int greenPin = 9;  // G petal on RGB LED module connected to digital pin 9
int bluePin = 10;  // B petal on RGB LED module connected to digital pin 10
byte com = 0;      // Reply from voice recognition
// Program Setup
  // Serial communication Speed
  Serial.begin(38400);
  mySerial.begin(38400);
 // PinMode declaration
pinMode(redPin, OUTPUT); // sets the redPin to be an output
pinMode(greenPin, OUTPUT); // sets the greenPin to be an output
pinMode(bluePin, OUTPUT); // sets the bluePin to be an output
pinMode(Pin,OUTPUT);
 //Device Setup via AT commands
  mySerial.write(0xAA);
  mySerial.write(0x37); // Switch module into compact mode
  mySerial.write(0x21); // Import Group1 of 5 words
// Program starts
{ while(mySerial.available())
{ com =  mySerial.read();
     Serial.println(com,HEX);
     switch(com)
// Rooms
  case 0x11:
break;
  case 0x12:
break;
  case 0x14:
break;
  case 0x13:
break;
  case 0x15:
    barGroup(); // turn the RGB LED off
break;
// Appliance
  case 0x31:
    Serial.println("BAR");
break;
  case 0x32:
    Serial.println("lights");
    lights();
break;
  case 0x33:
    Serial.println("Garage");
break;
  case 0x34:
    Serial.println("Music");
break;
  case 0x35:
    Serial.println("Strobe");
// Control
break;
  case 0x21:
    Serial.println("start");
  Start();
break;
  case 0x22:
    Serial.println("off");
break;
  case 0x23:
    Serial.println("dim");
break;
  case 0x24:
    Serial.println("stop");
break;
  case 0x25:
    Serial.println("all off");
    off();
break;
void barGroup()
  mySerial.write(0x23); // Import Group3 of 5 words
       Serial.println("bargroup activated");
      Serial.println("reading serail");
void CtrlGroup()
  mySerial.write(0x22); // Import Group2 of 5 words
       Serial.println("controls activated");
void Start()
   digitalWrite(SwitchPin,HIGH);
void off()
   digitalWrite(SwitchPin,LOW);
void lights()
int Pin = 9;
  CtrlGroup();
how do i create function that switches pin outs for a function like start() and Stop()
LOL murhpy is a bastard , as i finished posting i found the answer
Seattle, WA USA
Online Online
Seattle, WA USA
But, you don't want to share it?
yes i will just want to finish it for all 5 groups ,  question when im a switch case and i want to reset to go back to the main loop is there a Arduino function to reset the code or go back to the start ?
got the answer , by sending
i directly kick the loop back to the first group of words  so the above is in a void called exit() and exit is one of the commands in the 3 group of words
90% finished code its working but needs cleaning up
int Pin;
int redPin = 9;   // R petal on RGB LED module connected to digital pin 11
int greenPin = 8;  // G petal on RGB LED module connected to digital pin 9
int bluePin = 7;  // B petal on RGB LED module connected to digital pin 10
int barPin =  11;
int lightPin =  12;
int garagePin = 10;
int musicPin = 6;
int strobePin = 5;
// Program Setup
  Serial.println(" Please say which environment you would like to control");
// Program starts
     switch(com)
/////////////////////////////////////////////////////////////////////////// Rooms set
  case 0x11:
  Serial.println("Jarvis");
  jarvis();
break;
  case 0x12:
  Serial.println("Lounge");
   lounge();
break;
  case 0x13:
  Serial.println("Garden");
  garden();
break;
  case 0x14:
  Serial.println("All off");
   all_off();
break;
  case 0x15:
  Serial.println("Bar");
break;
/////////////////////////////////////////////////////////////////////// Appliance  set
  case 0x31:
    Pin = barPin;
    CtrlGroup();
    break;
  case 0x32:
    Pin = lightPin;
    CtrlGroup();
   break;
   case 0x33:
    Pin = garagePin;
    CtrlGroup();
   break;
   case 0x34:
    Pin = musicPin;
    CtrlGroup();
  break;
  case 0x35:
    Pin = strobePin;
    CtrlGroup();
    break;
/////////////////////////////////////////////////////////////////////// Control set
  case 0x21:
    Serial.println("started Device");
  Start();
break;
  case 0x22:
  off();
break;
  case 0x23:
    Dim();
break;
  case 0x24:
    Stop();
break;
  case 0x25:
    off();
break;
//////////////////////////////////////////////Group 1 void functions////////////////////////////////////////////////////////////////////
void jarvis()//0x11
       Serial.println("jarvis selected");
      Serial.print("voice results:");
void lounge()//0x12
       Serial.println("lounge selected");
  void garden()
       Serial.println("Garden selected");
     void all_off()
       Serial.println("all off ");
void barGroup()
       Serial.println("bar Selected");
/////////////////////////////////////////////////////////////////Group 2 void functions //////////////////////////////////////////////////////////////////////////////////
void CtrlGroup()
       Serial.println("controls active");
//////////////////////////////////////////////////////////////////////Group 3 void functions /////////////////////////////////////////////////////////////////////////////
void Start()//0x21
  Serial.print("output pin :");
  Serial.println(Pin);
   digitalWrite(Pin,HIGH);
void off()//0x23 and 0x25
   digitalWrite(Pin,LOW);
void Dim()//0x24
   analogWrite(Pin,150);// object to be dimmed must be connected to analog pin
void Stop()//0x22
Seattle, WA USA
Online Online
Seattle, WA USA
And to be posted properly. Check out the Tools + Auto Format menu item, too.
Also, take a look at some C or C++ books. There are two main styles concerning placement of open and close curly braces.
Either:
if(someCondition) {
  // code goes here
or, what I prefer:
if(someCondition)
  // code goes here
There are no recognized styles that allow for code on the same line as the curly brace, following the curly brace. There are no styles that allow two close braces on the same line, or any that allow the close brace on the same line as any other code.
Whichever style you adopt, apply it consistently. It will make your code easier to read.
Hi Paul
thanx for the heads up , i was going to do that the last 10% i needed to do. for future is there any advantages of writing code like this other then ease of readability ?
Hi Paul
a other question that i have that i think you might be the correct person to ask is. is there any difference in  power consumption/cycle time and program size programming in Arduino vs C++ vs  C#?
 so lets say i take a program and write the same program for Arduino C++ and C# which is better to use when speaking in terms of the 3 points of concerns mentioned above ?
Seattle, WA USA
Online Online
Seattle, WA USA
Isn't ease of readability a sufficient goal in and of itself? It certainly is for me. Proper indenting, judicious use of white space, sufficient, but not over use of, comments, consistent naming conventions, etc. can make it easy to remember what code is doing when you look at it again later.
You may not think that that will happen, but I have code I wrote in 2001 that I still look at at least once a month. That class is 14,000 lines long. For me, ease of readability is a huge help in maintaining that code.
Seattle, WA USA
Online Online
Seattle, WA USA
Since you can't program the Arduino using C#, this is a rhetorical question. There is an answer, though. By the time the compiler gets done, the object files that the C++, the C, and the C# compiler produce are nearly indistinguishable.
By the time the linker gets done, they hex files are indistinguishable.
So, the language doesn't matter.
so having libraries and classes imported via arduino vs writting all the code in C# does not matter at the end of the day the compiled size and performance would be the same . just the compilation would take longer i geuss.
Seattle, WA USA
Online Online
Seattle, WA USA
Yes, it will take longer to compile C# code for the Arduino. First, you need to write the compiler...
okay thank you  Paul.
here is the code again formatted properly.
int Pin;
int barPin =  11;
int lightPin =  12;
int garagePin = 10;
int musicPin = 6;
int strobePin = 5;
// Program Setup
  Serial.println(" Jarvis,Lounge,Garden,Bar ");
// Program starts
    switch(com)
    case 0x11:
      jarvis();
      break;
    case 0x12:
      lounge();
      break;
    case 0x13:
      garden();
      break;
    case 0x14:
      all_off();
      break;
    case 0x15:
      break;
    case 0x31:
      Pin = barPin;
      CtrlGroup();
      break;
    case 0x32:
      Pin = lightPin;
      CtrlGroup();
      break;
    case 0x33:
      Pin = garagePin;
      CtrlGroup();
      break;
    case 0x34:
      Pin = musicPin;
      CtrlGroup();
      break;
    case 0x35:
      Pin = strobePin;
      CtrlGroup();
      break;
    case 0x21:
      Start();
      break;
    case 0x22:
      off();
      break;
    case 0x23:
      Dim();
      break;
    case 0x24:
      Stop();
      break;
    case 0x25:
      off();
      break;
void jarvis()//0x11
    Serial.println(" Please say which Appliance you would like to control");
    Serial.println("Options: Lights, BAR lights,Garage door, Music, Strobe ");
void lounge()//0x12
    Serial.println("Options: Lights, Music, Strobe ");
void garden()
    Serial.println("Options: Lights,pool light,Garage door, Music ");
void all_off()
void barGroup()
    Serial.println("Options: Lights, Pool table lights,Garage door, Music, Strobe ");
void CtrlGroup()
void Start()//0x21
void Dim()//0x24
void Stop()//0x22
Pages: 1 [2] 3   Go Up
