Topic: Accelometer Question (Read 990 times) previous topic - next topic
Kobra299
Hello Firstly I am sorry if this is the Wrong Section I hope an Admin will move it to Right one
here is what I want to do using a Wii Nunchuck which has a built in Accelometer I want to make a Different LED come on when its tilted one way or the other but I am not sure how to do this with a Arduino Uno I have a Connector for it just not sure how ir would be coded as never done this kind of Sensor before
wwbrown
Remember Google is your friend, I googled 'arduino Wii Nunchuck' and got the following top hits
http://www.windmeadow.com/node/42
and closer to home
http://www.arduino.cc/playground/Main/WiiChuckClass
See if these help,
wade
free-bee
If I understand correctly, I have done something similar once. What you need to do is learn what values define "level." Use the "pulseIn(pin,state)" command, where "pin" is the pin your accelerometer's x or y axis is on and "state" is the logic level (this is usually high, or "1"). After getting these values from using "Serial.println(pulseIn(pin,1))", use if then statements. I will give an example:
//this is to get the values of "level"
const int xPin = 2; // X output of the accelerometer
const int yPin = 3; // Y output of the accelerometer
   // initialize serial communications:
  // initialize the pins connected to the accelerometer
  // as inputs:
  pinMode(xPin, INPUT);
  pinMode(yPin, INPUT);
  Serial.println(pulseIn(xPin,HIGH));
  Serial.println(pulseIn(yPin,HIGH));
An example, with made-up numbers:
const int red_led = 4;          //connect red LED here
const int blue_led = 5;         //Blue LED here
  // as inputs:
  if ((pulseIn(xPin,HIGH) > 10) and (pulseIn(xPin,HIGH) < 5000))
  { digitalWrite(red_led,HIGH); }
  {digitalWrite(red_led,LOW);}
  if ((pulseIn(yPin,HIGH) > 1000) and (pulseIn(yPin,HIGH) < 1200))
  { digitalWrite(blue_led,HIGH); }
  {digitalWrite(blue_led,LOW);}
